i am playing with ATtiny85 and i found something intresting that i can't understand.
Up till now i though that delay(1000) means 1 second of delay if clock speed is set to 16 mhz and 2 seconds if speed is set to 8 mhz (because procesor runs half time slower). Is that correct? What about millis() if clock is set to 8 mhz? How are they counted?
First i set ATtiny85 to 8 mhz internal clock and use delay(500) for blink test, but led didn't blink in 1 second interval, it was more like 3 seconds interval. Than i set internal clock to 1 mhz and use delay(1000).. Blinking interval was correct, with 1 second delay. I am happy that it works but how is that possible? Why so?
In boards.txt there is a line where the clock speed is set.
I think if you have that set to match the hardware, then delay(1000); will result in 1 second delay.
You have to check that and the fuse settings when you are making tests like this.
