Let's say one is using serial and one is using the proper level shifters.
One could send sentences.
A sentence could be structured with a beginning of sentence marker, data, data separetors, and end of sentence marker.
Something like
< !,2,4,5> Where < is the beginning of sentence marker, the characters !@#$%^&* are function designators, the ", " is a data separator, and the > is an end of sentence marker.
Here is ESP32 code to receive the thing
void fReceiveSerial_LIDAR( void * parameters )
bool BeginSentence = false;
sSerial.reserve ( StringBufferSize300 );
char OneChar;
for ( ;; )
EventBits_t xbit = xEventGroupWaitBits (eg, evtReceiveSerial_LIDAR, pdTRUE, pdTRUE, portMAX_DELAY);
if ( LIDARSerial.available() >= 1 )
while ( LIDARSerial.available() )
OneChar = LIDARSerial.read();
if ( BeginSentence )
if ( OneChar == ‘>’)
if ( xSemaphoreTake( sema_ParseLIDAR_ReceivedSerial, xSemaphoreTicksToWait10 ) == pdTRUE )
xQueueOverwrite( xQ_LIDAR_Display_INFO, ( void * ) &sSerial );
xEventGroupSetBits( eg, evtParseLIDAR_ReceivedSerial );
sSerial.concat ( OneChar );
if ( OneChar == ‘<’ )
sSerial = “”; // clear string buffer
BeginSentence = true; // found begining of sentence
} // while ( LIDARSerial.available() )
} //if ( LIDARSerial.available() >= 1 )
xSemaphoreGive( sema_ReceiveSerial_LIDAR );
vTaskDelete( NULL );
} //void fReceiveSerial_LIDAR( void * parameters )
here is esp32 code to parse the data
void fParseLIDAR_ReceivedSerial ( void * parameters )
// distribute received LIDAR info
String sTmp = "";
sTmp.reserve ( 20 );
String sMessage = "";
sMessage.reserve ( StringBufferSize300 );
for ( ;; )
EventBits_t xbit = xEventGroupWaitBits (eg, evtParseLIDAR_ReceivedSerial, pdTRUE, pdTRUE, portMAX_DELAY) ;
xQueueReceive ( xQ_LIDAR_Display_INFO, &sMessage, QueueReceiveDelayTime );
// Serial.println ( sMessage );
int commaIndex = sMessage.indexOf(',');
sTmp.concat ( sMessage.substring(0, commaIndex) );
sMessage.remove( 0, (commaIndex + 1) ); // chop off begining of message
// Serial.println ( sTmp );
if ( sTmp == "!" )
xSemaphoreGive ( sema_LIDAR_OK );
// Display info from LIDAR
sLIDAR_Display_Info = sMessage;
if ( sTmp == "$" )
xEventGroupSetBits( eg1, evtResetWatchDogVariables );
if ( sTmp == "#")
// Serial.println ( "#" );
xSemaphoreTake( sema_LIDAR_Alarm, xSemaphoreTicksToWait );
sLIDAR_Alarm_info = sMessage;
xSemaphoreGive( sema_LIDAR_Alarm );
xEventGroupSetBits( eg, evtfLIDAR_Alarm );
// Serial.println ( "parse serial ok" );
sTmp = "";
sMessage = "";
xSemaphoreGive( sema_ParseLIDAR_ReceivedSerial );
// Serial.print( "fParseReceivedSerial " );
// Serial.print(uxTaskGetStackHighWaterMark( NULL ));
// Serial.println();
// Serial.flush();
} // void fParseReceivedSerial ( void * parameters )
