Hey Guys,
I try to understand the following for-loop from the standard code 03.analog => Smoothing
for (int thisReading = 0; thisReading < numReadings; thisReading ++) {
readings [thisReading] = 0:
I was wondering if it counts an extra number at thisReading after it finish the code between {} or does it counts before the code {}
So is the first indexnumber 0 or does it starts with the indexnumber 1
I hope you can help me, I'm just a beginner and try to understand the code.
Many thanks!
Starts at 0. It will increment to 1 after the first iteration. A for loop will always execute the code in the {} at least 1 time.
Allright, Thanks for you help groundFungus!
Why don’t you write a small code with that for loop and print the numbers and see? That would be a whole lot faster than asking the forum and you wouldn’t have to take our word for it. Lots of stuff you can just test yourself like that.
Delta_G:
Thanks for the tip Delta_G, i will try that next time
groundFungus:
Uhmm, no... Try
for(byte i = 0; i < 0; i++){
Serial.println("line!");
and see how many lines it prints
