understanding how rtc works
hi there.
im trying to turn on my light relay on for 2 different timing.
why would it not turn on like so? how would you advise me to improve this part?
/****set LIGHT TIMER ****/
  if ((now.hour() == 17) && (now.minute() == 51) && (now.minute() == 53))
    digitalWrite (light, HIGH);
    digitalWrite (light, LOW);
this are the full code.
/* YourDuinoStarter Example: DS1307 Real Time Clock
  - WHAT IT DOES: Set and/or Run DS1307 Real Time Clock
  - SEE the comments after "//" on each line below
  - CONNECTIONS:
   Function  Arduino Pin  Mega Pin
   -         Gnd          Gnd
   +         +5V          +5V
   SDA       Analog A4    20
   SCL       Analog A5    21
  - V1.02 04/26/2015
   Questions: terry@yourduino.com */
/*-----( Import needed libraries )-----*/
#include <Wire.h>
#include "RTClib.h"
/*-----( Declare Constants and Pin Numbers )-----*/
// Not needed: RTC Lib expects connections as above
/*-----( Declare objects )-----*/
RTC_DS1307 rtc;    // Create a RealTimeClock object
/*-----( Declare Variables )-----*/
// NONE because the library handles this...
/*------(Declare LIGHT)--------*/
#define light 8
void setup()   /****** SETUP: RUNS ONCE ******/
  Serial.begin(9600); // Set up for Serial Monitor to be able to see this work
  // Set this in the lower right of the Serial Monitor screen
  Serial.println("YourDuino.com DS1307 Real Time Clock - Set / Run Utility");
  /*----( These lines allow code to work also on Arduino DUE )----- */
#ifdef AVR
  Wire.begin();
#else
  Wire1.begin(); // Shield I2C pins connect to alt I2C bus on Arduino Due
#endif
  rtc.begin(); // Start the RTC library code
  /*----( SET the date and time.  Comment OUT these lines after setting )----*/
  // Put these "//" in front of the line you do NOT want to use
  // following line sets the RTC to the date & time this sketch was compiled
  rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
  // This line sets the RTC with an explicit date & time, for example to set
  // May 21, 2015 at 6pm you would call: (use 24 hour time)
  //    rtc.adjust(DateTime(2015, 5, 21, 18, 0, 0));
  /****SET LIGHT OUTPUT***/
  pinMode(light, OUTPUT);
}//--(end setup )---
void loop()   /****** LOOP: RUNS CONSTANTLY ******/
  DateTime now = rtc.now();  // Read data from the RTC Chip
  Serial.print(now.year(), DEC); //
  Serial.print('/');
  Serial.print(now.month(), DEC);
  Serial.print('/');
  Serial.print(now.day(), DEC);
  Serial.print(' ');
  Serial.print(now.hour(), DEC);
  Serial.print(':');
  Serial.print(now.minute(), DEC);
  Serial.print(':');
  Serial.print(now.second(), DEC);
  delay(3000);
}//--(end main loop )---
/*-----( Declare User-written Functions )-----*/
//NONE
//*********( THE END )***********
dannable:
im trying to turn it on for minute 51 and minute 53.
for example 16:51 and 16:53
If you want it to turn on for 2 separate minutes
  if (now.hour() == 17 && (now.minute() == 51 || now.minute() == 53) )
