I want to use the library NeoSWSerial to create two serial instances on pin (8,9) and (10,11) but when i try, i only receive on one of them and not both.
Do you know if it’s possible to create multiple instances on NeoSWSerial or not ? And is there a specific method to use like listen or end ?
PS: Sorry for my english since it’s not my native language
Yes, but you can only listen to one at a time. No data will be received or stored from the other instance.
Yes, either nord.listen() or sud.listen().
However, it would be better to use Serial for one of the two instances. You would also see the messages on your Serial Monitor.
And it would be better to use AltSoftSerial on pins 8 & 9. You should use this on the receiver, too.
Could you do this on the sender:
#include <AltSoftSerial.h>
#define BAUDRATE 9600
#define nord Serial
AltSoftSerial sud; // always on 8 & 9 on an UNO
int envoi=0;
nord.begin( BAUDRATE ); // same as Serial
sud .begin( BAUDRATE );
if(envoi==0)
nord.print("nord");
envoi=1;
else if(envoi==1)
sud.print("sud");
envoi=0;
You should not try to print from the attachInterrupt function. Could you try this on the receiver:
#define baudrate 9600
AltSoftSerial nord; // always 8 & 9 on an UNO
nord.begin(baudrate);
if (nord.available()) {
char c = nord.read();
Serial.print( c );
When you use Serial for one of the devices on the sender, you must disconnect pin 0 (RX) from the device to upload new sketches over USB.
Could you use Serial for one of the devices on the sender?
Thank you for your fast answer. In fact, for my project, I need 4 serial instances so i need to create at least 3 myself if I use the serial hardware as the forth one.
I will try and do as you say asap and tell you how it went!
Thank you very much again
