Understanding Pass-by-Value
Hello,
I came across this code to tell you whether a year is a leap year (Beginning C for Arduino, 2nd edition, Jack Purdum).
And I wonder how it is possible that mydata gets altered when readline is using pass-by-value in readline(mydata). I thought pass by value meant that readline make a copy of mydata and uses it in its function. So I don't get how it alters the array that mydata is. Or do I miss something? Is mydata maybe altered another way?
So basically: how does what i type in the serial monitor end up in int year? I just don't see it..
I'm a noobcake i'm sorry! thanks
#define MAXCHARS 10
  if (Serial.available() > 0){
    int buffercount;
    int year;
    char mydata[MAXCHARS + 1];
    buffercount = readline(mydata);
    year = atoi(mydata);
    Serial.print("year: ");
    Serial.print(year);
    Serial.print(" is ");
    if (isleapyear(year) == 0){
      Serial.print("not ");
    Serial.println("a leap year");
int isleapyear(int yr){
  if(yr % 4 == 0 && yr % 100 != 0 || yr % 400 == 0){
    return 1;
    else{
      return 0;
int readline(char str[]){
  char c;
  int index = 0;
  while (true){
    if(Serial.available() > 0){
    index = Serial.readBytesUntil('\n',str, MAXCHARS);
    str[index] = '\0';
return index;
int readline(char* str)Any clearer now?
absoluyely not :o haha
You're passing an array (str) by reference in "readline". Passing by reference is similar to passing by pointer - in that it allows the function to edit "str".
Arrays are always passed by reference, rather than by value...
Rather than passing an array, I much prefer to pass a pointer to the first object in the array i.e. position 0 and also pass the length of the array. I personally don't like passing an array.
andyh-1963:
The name of the array is a pointer to the first element.
