Understanding Resistance...:S
I am using a piezo buzzer on my arduino and need some advise on resistance. Basically, can I use a resistor as high as 10KOhms to reduce the volume of the buzzer?
I understand that resistors are required to stop too much current being drawn but is it also bad for the arduino if there is too much resistance?
I have done some reading on Ohms law and I can do the calculations but there are still many grey areas for me.
Thank in advance,
Tom
That depends on the buzzer's ratings. Do you have a datasheet?
That's is correct.
No. In fact, if you write a pin to HIGH when it's not connected to anything, electricity is still flowing (through near infinite resistance).
Here is the buzzer: http://www.coolcomponents.co.uk/catalog/product_info.php?cPath=50_75&products_id=341
I am a strong programmer, software engineer by profession, but I am just starting out with electronics.
I used a 220Ohm resistor to first test the buzzer but on discovering it was ear piercingly loud I moved to a 10KOhm and its perfect volume but just wanted to be sure I am OK to do this.
Cheers,
Tom
Yes it is fine you can put what ever value you like in series with it.
