Understanding Serial.available()
@GolamMostafa, Serial.read() returns an int, not a byte. So you should store it in an int and rerun your tests.
Does it mean that the serial FIFO buffer is word oriented? If so, it agrees with our good old days’ knowledge of UART Port of IBMPC. The upper 8-bit of the return value contains the status bits and the lower 8-bit contains the actual character received. In Arduino IDE, execution of byte x = Serial.read(); automatically takes the lower 8-bit of the 16-bit buffer location. In old days, we had to do it in a different way. (Thanks to clever Arduino IDE.)
Old Days’ Method:
#include	<stdio.h>
#include	<bios.h>
#include	<conio.h>
#define 	COM1INI	bioscom(0x00, 0xC7, 0x0000)  /*c7=2SB, C3=1SB */
#define 	COM1WR  bioscom(0x01, ch1,   0x0000)
#define 	COM1RD  comval.z=bioscom(0x02, 0x00, 0x0000)
#define 	COM1STS comval.z = bioscom(0x03, 0x00, 0x0000) /* Status Read */
#define	TxRDY   ((comval.ch2[1])& 0x20) /*!=0x00 */
#define	RxRDY	((comval.ch2[1])& 0x01)
#define 	RxDATA  (comval.ch2[0])
void main(void)
   unsigned char ch1 ;
  union 	{
			int z;
			unsigned char ch2[2];
      		} 	comval;
  clrscr();
COM1INI; 		/* COM1 initialize at 4800Bd,NP,2-SB */
While ((ch1 = getche()) != ‘Q’)	/* read ASCII code of pressed down key */
		COM1STS ;	/* reading COM1 status after executing bioscom(0x03, , );*/
		if (TxRDY != 0x00)
		COM1WR ;	/* write ASCII code of the pressed down key on COM1 port */
		If (RxRDY !=00)
			COM1RD ;	/* Data has arrived at COM1 port and read it */
			putchar (RxDATA) ;	/* show the received character on screen */
	exit(0);
GolamMostafa: Does it mean that the serial FIFO buffer is word oriented?
No, it means that, when no data is available to read, Serial.read() returns a value (-1) that cannot possibly be read from the serial port. When there is data available, Serial.read() returns a value in the range 0 to 255. There are no status bits with Serial.read().
In short, Serial.read() returns 256 values (-1 to 255) which cannot possibly be contained in an 8 bit data type thus Serial.read() returns a number of signed int type.
adwsystems: In short, Serial.read() returns 256 values (-1 to 255) which cannot possibly be contained in an 8 bit data type thus Serial.read() returns a number of signed int type.
Correction: Serial.read() can return one of 257 values. 0 through 255 is 256 values (which can be stored in a byte), and -1 is a 257th value.
