Hi all,
I bought a cheap seven-segment display from sparkfun here: 7-Segment Display - 4-Digit (Blue) - COM-09481 - SparkFun Electronics
...and while I have no problem getting it to work using the example code given here: http://dlnmh9ip6v2uc.cloudfront.net/datasheets/Components/LED/_7Seg_Example.pde
I'm having some difficulty just understanding the code in general. I do understand from the datasheet schematic (featured below) that the digits are turned on using pwm pulses within the code to control brightness/current flow to the leds and the segments required for each number is controlled with specifically defined digital pulses in a switch case.
But the thing I'm having trouble understanding is how the arduino controls the segments for each individual digit. The confusion comes into play due to the inputs on all the segments for each digit being all tied together as seen on the datasheet. If all the segments are tied together for each digit shouldn't every digit be the same? I know this isn't the case because I've tested the code and as far as I can tell it counts up perfectly.
If anyone could shed some light on this I would be quite grateful.
