Understanding special syntax, void(* resetFunc) (void) = 0;
I found this in:
http://forum.arduino.cc/index.php?topic=42436.0
//declare reset function @ address 0
I don't get a single bit of it. Is this just an alternative one-way method of defining a function? How would that function have looked like in another format?
What does it mean that a function is at address 0?
Sincerely
It's a crude method of doing a software reset. It defines a pointer to a function, and sets that pointer to zero, so when you call the function, you transfer control to the reset vector at address zero.
What is the reset vector? A function?
The reset vector is first thing the processor fetches after a hardware reset to point it to the start of whatever code it is supposed to execute immediately after a hardware reset.
If you want, you can read about it in the processor's datasheet, available from the Atmel website.
And this is totally non portable. Assigning integer 0 to a pointer gets you the null pointer which is not guaranteed to be all-bits-zero.
If you want a way to figure out complex data definitions, like:
double (*(*pf)())[3][4];
take a look at a summary of my Left-Right Rule at:
http://jdurrett.ba.ttu.edu/3345/handouts/RL-rule.html
