This seems to achieve what I am looking for... But I don't fully understand 'how' it works.
template <class C>
class Foo {
public:
static void printName(){ Serial.println(C::name); }
class Bar : public Foo<Bar> {
public:
static const char* name;
}; const char* Bar::name = "Bar";
class Baz : public Foo<Baz> {
public:
}; const char* Baz::name = "Baz";
Bar::printName();
Baz::printName();
void loop() { }
Why is there not an error when referencing 'name' inside Foo? At that point Bar hasn't been created to declare what name is, and there's no knowing that C:: will even have a var called name.
Does the compiler take it on blind faith that you'll resolve that yourself?
Because you have declared 'name' as public static in both classes Bar and Baz and are invoking using Bar::printName() and Baz::printName(). The base class has no role whatsoever.
I do get an error if I try to create a different derived class that DOESN'T have a 'name':
sketch.ino: In instantiation of 'static void Foo<C>::printName() [with C = Daz]':
sketch.ino:25:7: required from here
sketch.ino:4:28: error: 'name' is not a member of 'Daz'
Error during build: exit status 1
So the compiler is checking that at least.
Trying it this way made it click a little more for me I guess:
template <class C>
class Foo {
public:
public:
public:
class Daz : public Foo<Daz> {
public:
static int name;
}; int Daz::name = 5;
Bar::printName();
Baz::printName();
Daz::printName();
void loop() { }
template <class C>
class Foo {
public:
static void printName(){ Serial.println(name); }
public:
template<>
const char* Foo<Bar>::name = "Bar";
public:
template<>
const char* Foo<Baz>::name = "Baz";
Bar::printName();
Baz::printName();
void loop() { }
This was my original approach I think. If I recall correctly it worked in the Wokwi simulator but not on the real hardware with VSCode/Platformio and a Teensy 4.1. But I'm not with the hardware at the moment so I can't confirm that.
class Base
protected:
char _name[100]
public:
Base(const char* name)
strcpy_s(_name, name, 100); //Check syntax.
void printName()
printf("Name: %s", _name);
class Bar :: public Base
public:
//Check syntax
//Basically we are just invoking the base class constructor with a defaukt name
Bar() :: Base("BAR")
//Check syntax
//Basically we are just invoking the base class constructor with a user supplied name
Bar(const char* name) :: Base(name)
class Bar1 :: public Base
public:
//Check syntax
Bar1() :: Base("BAR1")
//Check syntax
Bar1(const char* name) :: Base(name)
//Declare pointers for later initialisation
Base *b = NULL;
Base *b1 = NULL;
b = new Bar(); //Create instance of class Bar
b1 = new Bar1(); //Create instance of class Bar1
b -> printName();
b1 -> printName();
b = new Bar("1234"); //Create instance of class Bar
b1 = new Bar1("5678"); //Create instance of class Bar1
b -> printName();
b1 -> printName();
I'm not certain that particular example would carry across how I need to use it.
I'm looking for the name variable to be shared across all instances of a certain derived class (although unique to each class that derives)... And for 'name' to accessible inside base. The templating isn't related to my attempt to get 'name' to work... It's just that by base class IS a template class, so it's important to include it here.
In that case you will need to make Bar itself a base class of another class, move the _name variable inside it, make it protected static and implement the printName() method in it. Then make classes FooBar derive from Bar This way all your pointers can be of type Base, and initialised as FoorBar().
