Understanding the code
I am trying to break down the code.
The program is reading the video file in raw format from SD card and is playing it on the lcd screen
format of the video is 200x120
Buffer is declared
#define NLINES 30
uint16_t buf[200NLINES]; // so the size of the buffer is 20030*2 bytes 12000Bytes
so it holds 20 lines of each frame of the video.
The program goes like this (wd=200, ht=120, nl=20)
// Params:
// name - file name
// wd,ht - width, height of the video (raw data has no header with such info)
// nl - num lines read in one operation (nlwd2 bytes are loaded)
if(!file.open(name, O_CREAT | O_RDONLY)) { //this is clear it opens up the file
lcdSPI(); lcd.fillScreen(YELLOW);
sd.errorHalt(F(“File open failed”));
file.seekSet(0);
unsigned long sdStartTime,frTime,lcdTime,sdTime=0;
while(file.available()) {
sdTime = 0;
frTime = millis();
for(int i=0;i<ht/nl;i++) { // here is where I am confused. For every line
sdStartTime = millis(); // it it reads 20 lines to a buffer???
int rd = file.read(buf,wd2nl);
sdTime += millis()-sdStartTime;
lcdSPI();
for(int j=0;j<nl;j++) lcd.drawImage(0,inl+j+(statMode>0?0:4),lcd.width(),1,buf+20+jwd);
// I do not understand what woull be the result of
// buf+20+j*wd where buffer in this case has
// has 12000bytes written to it.
//how do I interpret his
frTime = millis()-frTime;
lcdTime = frTime-sdTime;
lcd.setCursor(0,lcd.height()-7);
file.close();
Thanks for any feedback
You need to post the complete program so we can see how the variables have been defined.
Also this cramped style makes code very hard to read
look how much easier it is to read with a little white-space
for( int i = 0; i < ht / nl; i++) {
And please use the code button </> when posting code
…R
I am using the different PCD screen and I do not use any buttons so there is a lot of logic that I removed from the code.
I am ultimately interested in showvideo function.
I have other issues with that code as well e.g I am not sure how the gui managed to compile the code where
#define NLINES 30
uint16_t buf[200*NLINES];
clearly exceeds the global varibles memory pool. Not only for Nano and Uno but also just exceeds it on Arduino Mega.
The guy was using bluepill board.
Here is the original code.
// ST7735 library example
// Requires SdFat, Arduino_ST7735_STM libraries and stm32duino
// (C)2019 Pawel A. Hernik
// YT video: https://youtu.be/o3AqITHf0mo
 ST7735 128x160 1.8" LCD pinout (header at the top, from left):
 #1 LED   -> 3.3V
 #2 SCK   -> SCL/D13/PA5
 #3 SDA   -> MOSI/D11/PA7
 #4 A0/DC -> D8/PA1  or any digital
 #5 RESET -> D9/PA0  or any digital
 #6 CS    -> D10/PA2 or any digital
 #7 GND   -> GND
 #8 VCC   -> 3.3V
           SPI2/SPI1
 SD_SCK  - PB13/PA5
 SD_MISO - PB14/PA6
 SD_MOSI - PB15/PA7
 SD_CS   - PB12/PA4
 STM32 SPI1/SPI2 pins:
 SPI1 MOSI PA7
 SPI1 MISO PA6
 SPI1 SCK  PA5
 SPI1 CS   PA4
 SPI2 MOSI PB15
 SPI2 MISO PB14
 SPI2 SCK  PB13
 SPI2 CS   PB12
 Comments:
 SD uses faster STM32 SPI1 interface which supports 36 Mbps
 Not all SD cards work at 36MBps
 Slow card at 18Mbps gives 22-23fps
 Fast card at 18Mbps gives 25-26fps
 Fast card at 36Mbps gives 33-34fps
 SdFat library uses DMA for SPI transfer
 Big buffer in RAM is used to speed up SPI/DMA transfer
 SPI1 is shared between LCD and SD card
#include <SPI.h>
#include <Adafruit_GFX.h>
#if (__STM32F1__) // bluepill
#define TFT_CS  PA2
#define TFT_DC  PA1
#define TFT_RST PA0
#include <Arduino_ST7735_STM.h>
#else
#define TFT_CS 10
#define TFT_DC  8
#define TFT_RST 9
//#include <Arduino_ST7735_Fast.h>
#endif
#define SCR_WD 128
#define SCR_HT 160
Arduino_ST7735 lcd = Arduino_ST7735(TFT_DC, TFT_RST, TFT_CS);
#include "SdFat.h"
#define USE_SDIO 0
//const uint8_t SD_CS = PB12;
//SdFat sd(2);
const uint8_t SD_CS = PA4;
SdFat sd(1);
// serial output steam
ArduinoOutStream cout(Serial);
#define sdErrorMsg(msg) sd.errorPrint(F(msg));
SdFile file;
void lcdSPI()
  SPI.beginTransaction(SPISettings(36000000, MSBFIRST, SPI_MODE3, DATA_SIZE_16BIT));
#define SD_SPEED 36
void sdSPI()
  SPI.beginTransaction(SD_SCK_MHZ(SD_SPEED));
#define BUTTON PB9
int buttonState;
int prevState = HIGH;
long btDebounce    = 30;
long btMultiClick  = 600;
long btLongClick   = 500;
long btLongerClick = 2000;
long btTime = 0, btTime2 = 0;
int clickCnt = 1;
// 0=idle, 1,2,3=click, -1,-2=longclick
int checkButton()
  int state = digitalRead(BUTTON);
  if( state == LOW && prevState == HIGH ) { btTime = millis(); prevState = state; return 0; } // button just pressed
  if( state == HIGH && prevState == LOW ) { // button just released
    prevState = state;
    if( millis()-btTime >= btDebounce && millis()-btTime < btLongClick ) {
      if( millis()-btTime2<btMultiClick ) clickCnt++; else clickCnt=1;
      btTime2 = millis();
      return clickCnt;
  if( state == LOW && millis()-btTime >= btLongerClick ) { prevState = state; return -2; }
  if( state == LOW && millis()-btTime >= btLongClick ) { prevState = state; return -1; }
  return 0;
int prevButtonState=0;
int handleButton()
  prevButtonState = buttonState;
  buttonState = checkButton();
  return buttonState;
#define NLINES 30
char txt[30];
int statMode=0, prevStat=0;
// Params:
// name - file name
// x,y - start x,y on the screen
// nl - num lines read in one operation (nl*wd*2 bytes are loaded)
// skipFr - num frames to skip
void showVideo(char *name, int x, int y, int wd, int ht, int nl, int skipFr)
  lcd.setTextColor(YELLOW,BLACK);
    sd.errorHalt(F("File open failed"));
  file.seekSet(0);
  handleButton();
    sdTime = 0;
    frTime = millis();
      int rd = file.read(buf,wd*2*nl);
      lcdSPI();
      for(int j=0;j<nl;j++) lcd.drawImage(0,i*nl+j+(statMode>0?0:4),lcd.width(),1,buf+20+j*wd);
    if(buttonState>0) {
      if(++statMode>2) statMode=0;
    if(statMode!=prevStat) {
      lcdSPI();
      if(statMode==0) { lcd.fillRect(0,0,lcd.width(),4,BLACK); lcd.fillRect(0,lcd.height()-4,lcd.width(),4,BLACK); }
      else lcd.fillRect(0,lcd.height()-8,lcd.width(),8,BLACK);
    if(statMode==1)
      snprintf(txt,30,"Fr/SD/LCD: %2ld/%2ld/%2ld %2d fps",frTime,sdTime,lcdTime,1000/frTime);
    if(statMode==2)
      snprintf(txt,30,"%2ld fps",1000/frTime);
    if(statMode>0) {
      lcdSPI(); lcd.print(txt);
    prevStat = statMode;
    if(skipFr>0) file.seekCur(wd*ht*2*skipFr);
    if(handleButton()<0) break;
  if(buttonState<0 && prevButtonState==0) nextVideo();
  file.close();
void setup(void)
  pinMode(BUTTON, INPUT_PULLUP);
  lcd.init();
  lcd.setRotation(3);
  lcd.fillScreen(BLACK);
  lcd.setCursor(0,20); lcd.print("Init");
  //delay(8000);
  if(!sd.cardBegin(SD_CS, SD_SCK_MHZ(SD_SPEED))) {
    lcdSPI(); lcd.fillScreen(RED);
    sdErrorMsg("\nSD Card initialization failed.\n");
  if(!sd.fsBegin()) {
    lcdSPI(); lcd.fillScreen(MAGENTA);
    sdErrorMsg("\nFile System initialization failed.\n");
    return;
  //sd.ls("/",0);
int videoNo=0;
void nextVideo()
  if(++videoNo>1) videoNo=0;
void loop(void)
  if(videoNo==0) { showVideo("food22.raw",0,0, 200,120, 30,1); if(buttonState==0) nextVideo(); }
  else           { showVideo("cars120.raw",0,0, 200,120, 30,0); if(buttonState==0) nextVideo(); }
Dziubym: clearly exceeds the global varibles memory pool. Not only for Nano and Uno but also just exceeds it on Arduino Mega. The guy was using bluepill board.
Looks like it won't work on a Mega, Uno or nano. What is a bluepill? As well as having more memory is it also faster?
...R
Dziubym:
#define NLINES 30
That’s the same as &buff[20+j*wd]. If buff was a 2-dimensional array uint_16 buff[NLINES][200]; (in other words NLINES lines of 200 words) it would be &buff[j][20]… The address of the 21st word of the 200 words in line ‘j’.
I don’t know what special meaning the 21st word has.
The bluepill is a STM32 board which is a 32bit processor, That program is not going to work on a 8 bit processor i.e. uno, mega, nano.
