understanding the datasheet
Model number : SSCSNBN005PDAC5
Link to the sensor and datasheet
http://au.mouser.com/ProductDetail/Honeywell/SSCSNBN005PDAC5/?qs=%2Fha2pyFadujTzXc4EG5AIpywoMeCdsHuWImDF3mnLPxOkVmFo1jG4A%3D%3D
From the data sheet i got that the output is between 5-85% of the voltage( 5V). Also, is the sensor range form - 5psi to + 5psi or 0- 5 psi. The website says 0 - 5 psi, but if i use the sensor model number it corresponds to - 5 psi to + 5 psi
U're right. Its differential +/- 5psi.
Hope its linear. Then its easy : Analog reading 102 for -5psi and 869(870) for +5psi
Since the map-function uses long.. scale up by 100, the divide result by 100.
-> float pressure=map(analogRead(port_number),102,869,-500,500)/100.0 ;
what is the map function used for? Im new to arduino. Thx This is how ive implemented it in my source code
int nozzle1 = A0; // select the input pin for the potentiometer
int nozzle2 = A1; // select the input pin for the potentiometer
#define Vsupply 5.0
#define _10bit 1024.0
#define maxpressure 5.0
#define Pmax 5.0
#define Pmin 0.0
// initialize serial communication at 9600 bits per second:
// read the input on analog pin 0:
int sensorport1 = analogRead(nozzle1);
if(sensorport1>=0 && sensorport1<=51)
sensorport1= 51;
else if(sensorport1>=870 && sensorport1<=1023)
sensorport1= 870;
// read the input on analog pin 1:
int sensorport2 = analogRead(nozzle2);
if(sensorport2>=0 && sensorport2<=51)
sensorport2= 51;
else if(sensorport2>=870 && sensorport2<=1023)
sensorport2= 870;
/* Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V): for a 10 bit resolution. The pressure is in terms of psi of range 0 - 5 psi
The sensor displays output for 15-85% of the supply voltage. Relating the ADC value to the voltage:*/
float voltage = (sensorport1-sensorport2) * (Vsupply / _10bit);
// print out the value you read:
//The sensor displays output for 15-85% of the supply voltage. Relating the ADC value to the voltage:
delay( 1000);
//voltage= (0.8Vsupply)/(Pmax-Pmin)(pressure-Pmin)+ 0.10Vsupply;
float pressure = (voltage/Vsupply - 0.1)
((Pmax - Pmin)/0.8) + Pmin;
// Convert the voltage reading into pressure reading ( psi)
Serial.println(pressure);
Thesis.ino (2.76 KB)
..You got a start.
The sensor does not give you two values, but one.. Which represente the difference of the two.
Take a peek at the MAP-function
You'll fine that it takes care ot the math you need done.
If we use the same datasheet, then this could work
int Psensor = A0;    // select the input pin for the potentiometer
#define Pmax 500.0 // scaled up 100 times
#define Pmin -500.0
float pressure;
  pressure=map(analogRead(Psensor),102,869,Pmin,Pmax)/100.0 ;
  Serial.print(" Pressure difference is ");
  Serial.print (pressure,1);
  Serial.println(" Pascal");
  delay(1000); // read every second
knut_ny:
I got 0.85* 1024= 870 bits (5 psi)
and 0.05*1024 = 51 bits. (-5psi)
How did you get 102 bits for -5psi?
