Understanding the finer aspects of string variables
i am trying to use variables for filenames instead of hardcoded ones to be used like dataFile = SD.open(filename);
i understand that the filename variable can be declared as a string (type char) or as a String object (type String)
i think i can understand the String object usage as i have had experience with string manipulation in BASIC with $A = $B + "C" and the like.
however, if the filenames are fixed (eg. choosing from a menu of a limited set) then one should use the char type since this uses less memory, right ?
my problem now is getting the pairing of the variable and its usage in the function.
working from the examples on the Arduino Reference page;
IF
char* myStrings[]={"This is string 1", "This is string 2", "This is string 3",
"This is string 4", "This is string 5","This is string 6"};
THEN
for (int i = 0; i < 6; i++)  { Serial.println(myStrings[i]); }
results in each sentence being listed.
but
IF
char myStrings[]={"This is string 1 This is string 2 This is string 3 This is string 4 This is string 5 his is string 6"};
THEN
only results in This i
ie. each letter in the single string is viewed as a member of that array.
so far so good - but when i try to start using them in a function like so;
declaration and usage:
char file2use[13]="what2prn.txt";
readFile(file2use[13]);
with the function:
void readFile(char filename)  {
then i get the error message; invalid conversion from 'char' to 'const char*'
(i'm probably still not quite grasping the usage of the '*' as an array pointer(?))
i tried changing the function to
void readFile(char filename[13])  {
  dataFile = SD.open(filename[13]);
but then get the error; invalid conversion from 'char' to 'char*'
:fearful:
could you please point out where i am going wrong with this ?
This variable should be called myString, because there is only one string here.
for (int i = 0; i < 6; i++)  { Serial.println(myStrings); }
I'm assuming that you actually have [ i ] at the end of myStrings, so you are only printing 6 characters.
Create an array with 13 elements, then pass the 14th element (character) in the array to a function. Nope.
Of course you do. Lose the [13]. The function KNOWS how big the array is, because the array is NULL terminated.
The function needs to be defined taking an array. You need to call the function with an array, not a single, out of bounds, element.
hi PaulS, thanks for your continuing help !
PaulS:
just to be clear, that was a matter of semantics and it should be myString[] with the square brackets still, right ?
PaulS:
yes, i think i copied that wrongly - as it is above, it would print the whole string 6 times, irrelevant to int i.
PaulS:
okay, so that's misuse of correct syntax ?
so i do want readFile(file2use); in this case, provided the function is expecting the correct data type, which is... not char but... ??
PaulS:
right, i think i'm getting when to use file2use[13] and when just file2use
PaulS:
okaaay.... i think i'm getting there - not a char, but an array of chars.
so it should be ;
void readFile(char filename[])  {
BINGO !! :smiley:
thanks a big bunch !
okay, just to confirm my understanding of using the '*', if i were to make a function that accepted an array of strings (ie. an array of an array of chars), then i'd declare it like so;
void showFilelist(char* filenames[])  {
 for (int i=0; i<4; i++)  {
  Serial.print ("File #");
  Serial.print (i);
  Serial.print (" is : ");
  Serial.println (filenames[i]);
where the variable is declared;
char filenames[4]={"Menu item 1", "Menu item 2", "Menu item 3", "Menu item 4"};
(almost misused round brackets for the curly ones there...)
That depends. Did you really intend to remove the double quotes and commas from the original array of strings, to make one string?
It is syntactically correct, but logically wrong.
Either array of char or pointer to char.
void readFile(char file2Use[13]);
or
void readFile(char *file2Use);
That's one way. The other would be:
void showFilelist(char **filenames)
Well, I hardly think that "Menu Item 1" is a file name, but the syntax is correct.
The compiler would have bitch-slapped you.
PaulS:
yes, one string - it was just changing the original sketch around to see what happened when i did various stuff.
what i meant was that the square brackets are still necessary, whether or not it's called mystring or mystrings.
(we're dealing with an absolute n00b here you know !)
PaulS:
right, got it.
PaulS:
or
that asterisk should be next to 'char' instead of 'file2Use', right ?
PaulS:
woah - TWO asterisks now ?! :cold_sweat:
PaulS:
yeah, bad example - i was thinking a menu item which would then launch (or read from) a specific file.
i guess i don't need to be "wasting too much time" on this 'menu thing' since it's not exactly what an Arduino needs to be using up its resources for - saw there was already a library for Menu handling for LCDisplays.
bottom line here is i'm learning about datatypes and how to handle them.
PaulS:
heh-heh. just wait 'til i can grab the board by the handles...
it doesn't help that the font isn't very distinctive in showing the two - i actually already have Notepad++ for my php dabbling, didn't realise i could also use it for writing Arduino sketches.
The asterisk indicates that the variable is a pointer. The placement doesn't matter to the compiler, but it does to me.
A statement like:
int *a, b;
defines to variables - a as a pointer to int and b as an int. Putting the asterisk next to the variable makes that clearer (to me) than:
int* a,b;
which seams to imply that a and b are of type pointer to int.
Not that I recommend either approach.
int *a;
int b;
makes it far clearer that a and b are NOT the same type.
Yep. You can have more than that.
That's a good thing, whether its realistic for the Arduino or not.
