Understanding the meaning of a code I found
Hey there,
So basically while searching on how to use bluetooth with arduino for school I found the following code:
//Arduino Turn LED On/Off using Serial Commands
//Created April 22, 2015
//Hammad Tariq, Incubator (Pakistan)
char junk;
String inputString="";
 pinMode(13, OUTPUT);
 pinMode(8, OUTPUT);
  if(Serial.available()){
  while(Serial.available())
      char inChar = (char)Serial.read();
      inputString += inChar;
    Serial.println(inputString);
    while (Serial.available() > 0)
    { junk = Serial.read() ; }
    if(inputString == "a"){
      digitalWrite(13, HIGH);
    }else if(inputString == "b"){
      digitalWrite(13, LOW);
     if(inputString == "c"){
      digitalWrite(8, HIGH);
    }else if(inputString == "d"){
      digitalWrite(8, LOW);
    inputString = "";
I don't fully understand some of the things he has done, for example the part
I was wondering if someone could explain this to me.
Thank you in advance!
That code is how to use the serial cons link - you’d be better off studying the examples on the IDE on serial coms if you want to do that .
This doesn’t use Bluetooth...
if (Serial.available()) //if at least one byte of serial data is available
  while (Serial.available())  //all the time there is still serial data available
    char inChar = (char)Serial.read();  //read a character
    inputString += inChar;  //concatenate the new character with previously received characters
