understanding this error message.
Greetings. I bought a camera module from linksprite and i attached the module like so;
Link Sprite | (Uno + Wifi.Shield )
Tx Pin 2
Rx Pin 3
I used this code to text the camera; ran the take picture example from cameraVC0706 library
#include <camera_VC0706.h>
#include <SD.h>
#include <SoftwareSerial.h>
#define chipSelect 4
#if ARDUINO >= 100
SoftwareSerial cameraconnection = SoftwareSerial(2, 3);
#else
NewSoftSerial cameraconnection = NewSoftSerial(2, 3);
#endif
camera_VC0706 cam = camera_VC0706(&cameraconnection);
#if !defined(SOFTWARE_SPI)
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
	if(chipSelect != 53) pinMode(53, OUTPUT); // SS on Mega
#else
	if(chipSelect != 4) pinMode(4, OUTPUT); // SS on Uno, etc.
#endif
#endif
	pinMode(7,INPUT_PULLUP);
	Serial.println("VC0706 Camera test");
	//SD卡检测
	if (!SD.begin(chipSelect)) {
		Serial.println("Card failed, or not present");
		return;
	// 查询摄像头
	if (cam.begin()) {
		Serial.println("Camera Found:");
		Serial.println("No camera found?");
		return;
	// 摄像头版本号
	char *reply = cam.getVersion();
	if (reply == 0) {
		Serial.print("Failed to get version");
		Serial.println("-----------------");
		Serial.print(reply);
	// 选择合适的图片尺寸 640x480, 320x240 or 160x120
	// 图片越大,传输速度越慢
	cam.setImageSize(VC0706_640x480);
	//cam.setImageSize(VC0706_320x240);
	//cam.setImageSize(VC0706_160x120);
	uint8_t imgsize = cam.getImageSize();
	Serial.print("Image size: ");
	if (imgsize == VC0706_640x480) Serial.println("640x480");
	if (imgsize == VC0706_320x240) Serial.println("320x240");
	if (imgsize == VC0706_160x120) Serial.println("160x120");
	Serial.println("Get ready !");
	if(digitalRead(7)== 0) { //按键检测
		delay(10);
			if (! cam.takePicture())
				Serial.println("Failed to snap!");
				Serial.println("Picture taken!");
			char filename[13];
			strcpy(filename, "IMAGE00.JPG");
			for (int i = 0; i < 100; i++) {
				filename[5] = '0' + i/10;
				filename[6] = '0' + i%10;
				// create if does not exist, do not open existing, write, sync after write
				if (! SD.exists(filename)) {
			File imgFile = SD.open(filename, FILE_WRITE);
			uint16_t jpglen = cam.frameLength();
			Serial.print(jpglen, DEC);
			Serial.println(" byte image");
			Serial.print("Writing image to ");
			Serial.print(filename);
			while (jpglen > 0) {
				// 一次读取32bytes
				uint8_t *buffer;
				uint8_t bytesToRead =  min(32, jpglen); // 调节一次性读取数据大小,从32-64byte ,过大容易不工作
				buffer = cam.readPicture(bytesToRead);
				imgFile.write(buffer, bytesToRead);
				jpglen -= bytesToRead;
			imgFile.close();
			Serial.println("...Done!");
	        cam.resumeVideo();
and this error pops out.
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Uno"
Build options changed, rebuilding all
C:\Program Files (x86)\Arduino\libraries\camera_VC0706\camera_VC0706.cpp:63:9: error: prototype for 'uint8_t camera_VC0706::setMotionStatus(uint8_t, uint8_t, uint8_t)' does not match any in class 'camera_VC0706'
 uint8_t camera_VC0706::setMotionStatus(uint8_t x, uint8_t d1, uint8_t d2) {
In file included from C:\Program Files (x86)\Arduino\libraries\camera_VC0706\camera_VC0706.cpp:10:0:
C:\Program Files (x86)\Arduino\libraries\camera_VC0706\camera_VC0706.h:78:11: error: candidate is: boolean camera_VC0706::setMotionStatus(uint8_t, uint8_t, uint8_t)
   boolean setMotionStatus(uint8_t x, uint8_t d1, uint8_t d2);
Error compiling.
  enabled in File > Preferences.
what does this mean?
thanks in advance.
It looks like an error in the library. It declares that function as boolean in the .h file but then it is uint8_t in the .cpp file.
Open up those two files in a text editor and check the function prototype matches the definition.
