Understeanding ADXL345_WE lib
i run this code in esp32 (code at end of the post) and try to get data from adxl345 , all is ok , just i cant understeand well some parts
Qustion 1:
myAcc.setActivityParameters(ADXL345_AC_MODE, ADXL345_XY0, 0.2);
1. DC / AC Mode:
    ADXL345_DC_MODE - Threshold is the defined one (parameter 3)
    ADXL345_AC_MODE - Threshold = starting acceleration + defined threshold
2. Axes, that are considered:
    ADXL345_XY0  -  x,y
    ADXL345_XYZ  -  all axes
3. Threshold in g
so if value of x and y are betweeen g.x=0.04 | g.x=0.08 and g.y=0.00 | g.y=-0.04
and i dont want to get interrupt if difference is 0.04 , and get interrupt only if difference is more than that what should i set here:
myAcc.setActivityParameters(ADXL345_AC_MODE, ADXL345_XY0, xxx);
Qustion 2:
what really is AC and DC - can u give any example
Qustion 3:
myAcc.setDataRate(ADXL345_DATA_RATE_1_56);
data rates incan be:
3200Hz, 1600Hz, 800Hz, 400Hz, 200Hz, 100Hz, 50Hz, 25Hz, 12.5Hz, 6.25Hz, 3.13Hz, 1.56Hz, 0.78Hz, 0.39Hz, 0.20Hz, 0.10Hz
does this mean if i set to 1Hz the sensor will get g.X , g.Y values every second and comapre
Qustion 4:
myAcc.setRange(ADXL345_RANGE_4G);
ADXL345_RANGE_16G    16g
ADXL345_RANGE_8G      8g
ADXL345_RANGE_4G      4g
ADXL345_RANGE_2G      2g
what is the real difference, of 2g and 16g , if i set 16G does this mean sensor is less sensitive for small movement or can u give me an example
CODE:
#include <Wire.h>
#include <ADXL345_WE.h>
const int interrupt_pin = 23;
volatile bool in_activity = false; // in_activity: activity  interrupt occurred
ADXL345_WE myAcc = ADXL345_WE(0x53);
  Wire.begin();
  pinMode(interrupt_pin, INPUT);
  if (!myAcc.init()) {
    Serial.println("ADXL345 not connected!");
  myAcc.setRange(ADXL345_RANGE_2G);
  attachInterrupt(digitalPinToInterrupt(interrupt_pin), in_activityISR, RISING);
  myAcc.setInterrupt(ADXL345_ACTIVITY, INT_PIN_1);
  myAcc.readAndClearInterrupts();
void loop(){
  if (in_activity == true) {
    String axes = myAcc.getActTapStatusAsString();
    byte intSource = myAcc.readAndClearInterrupts();
    if (myAcc.checkInterrupt(intSource, ADXL345_ACTIVITY)) {
      Serial.print("Activity at: ");
      Serial.println(axes);
void in_activityISR() {
  in_activity = true;
