Does anyone know how i can get a DS18B20 to this code?
Now it can read and save the temperature from the RTC, but i want to read and save the temperature from a seperate DS18B20.
Would be great if theres someone out there who could help me
Source of Data: ☀ How to Build an Arduino Data Logger ☀ | Underwater Arduino Data Loggers
/* A basic RTC triggered datalogger script. Note that I have replaced the
analog pin reads in Tom’s Igoes starter code from //https://www.arduino.cc/en/Tutorial/Datalogger
with DS3231 I2C register reading & the delay has been replaced with sleep & RTC interrupt alarms
#include <SD.h> // I much prefer SdFat.h by Greiman over the old SD.h library used here
#include <SPI.h>
const int chipSelect = 10; //CS moved to pin 10 on the arduino
#include <Wire.h>
#include "LowPower.h" // from https://github.com/rocketscream/Low-Power
#include <RTClib.h> // library from https://github.com/MrAlvin/RTClib there are many other DS3231 libs availiable
RTC_DS3231 RTC;
// creates an RTC object in the code
// variables for reading the RTC time & handling the INT(0) interrupt it generates
#define DS3231_I2C_ADDRESS 0x68
int RTC_INTERRUPT_PIN = 2;
byte Alarmhour;
byte Alarmminute;
byte Alarmday;
char CycleTimeStamp[ ] = "0000/00/00,00:00"; //16 ascii characters (without seconds)
#define SampleIntervalMinutes 1 // Whole numbers 1-30 only, must be a divisor of 60
// CHANGE SampleIntervalMinutes to the number of minutes you want between samples!
// NOTE: the RTC will go down to one second alarm intervals with additonal code
volatile boolean clockInterrupt = false;
//this flag is set to true when the RTC interrupt handler is executed
const char codebuild[] PROGMEM = __FILE__; // loads the compiled source code directory & filename into a varaible
const char header[] PROGMEM = "Timestamp,RTC temp(C),Analog(A0),Add more headers here"; //gets written to second line datalog.txt in setup
//variables for reading the DS3231 RTC temperature register
float temp3231;
byte tMSB = 0;
byte tLSB = 0;
//variables for analog pin reading
int analogPin = 3;
int valA0 = 0;
//indicator LED pins - change to suit your connections
int RED_PIN = 4;
int GREEN_PIN = 5;
int BLUE_PIN = 6;
//pinMode(RTC_INTERRUPT_PIN,INPUT_PULLUP);//RTC alarms low, so need pullup on the D2 line
//Note the above line is not needed if you have hardware pullups on SQW line, and many RTC modules do.
// Setting the SPI pins high helps some sd cards go into sleep mode
// the following pullup resistors only needs to be enabled for the ProMini builds - not the UNO loggers
pinMode(chipSelect, OUTPUT); digitalWrite(chipSelect, HIGH); //ALWAYS pullup the ChipSelect pin with the SD library
//and you may need to pullup MOSI/MISO, usually MOSIpin=11, and MISOpin=12
//pinMode(MOSIpin, OUTPUT); digitalWrite(MOSIpin, HIGH); //pullup the MOSI pin
//pinMode(MISOpin, INPUT); digitalWrite(MISOpin, HIGH); //pullup the MISO pin
delay(1);
Serial.begin(9600); // Open serial communications and wait for port to open:
Wire.begin(); // start the i2c interface for the RTC
RTC.begin(); // start the RTC
// check RTC Status
clearClockTrigger(); //stops RTC from holding the interrupt low if system reset just occured
RTC.turnOffAlarm(1);
DateTime now = RTC.now();
sprintf(CycleTimeStamp, "%04d/%02d/%02d %02d:%02d", now.year(), now.month(), now.day(), ",", now.hour(), now.minute());
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print(F("Initializing SD card…"));
// print lines in the setup loop only happen once
// see if the card is present and can be initialized
if (!SD.begin(chipSelect)) {
Serial.println(F("Card failed, or not present"));
// don’t do anything more:
return;
Serial.println(F("card initialized."));
// You must already have a plain text file file named ‘datalog.txt’ on the SD already for this to work!
//————-print a header to the data file———- OPTIONAL!
File dataFile = SD.open("datalog.txt", FILE_WRITE);
if (dataFile) { // if the file is available, write to it:
dataFile.println((__FlashStringHelper*)header);
dataFile.close();
else {
Serial.println("error opening datalog.txt"); // if the file isn’t open, pop up an error:
pinMode(RED_PIN, OUTPUT); //configure 3 RGB pins as outputs
pinMode(GREEN_PIN, OUTPUT);
pinMode(BLUE_PIN, OUTPUT);
digitalWrite(RED_PIN, LOW);
digitalWrite(GREEN_PIN, HIGH); // startup with green led lit
digitalWrite(BLUE_PIN, LOW);
//============end of setup=================
//—–This part reads the time and disables the RTC alarm
DateTime now = RTC.now(); //this reads the time from the RTC
sprintf(CycleTimeStamp, "%04d/%02d/%02d %02d:%02d", now.year(), now.month(), now.day(), now.hour(), now.minute());
//loads the time into a string variable
//don’t record seconds in the time stamp because
//the interrupt to time reading interval is <1s, so seconds are always ’00’
// We set the clockInterrupt in the ISR, deal with that now:
if (clockInterrupt) {
if (RTC.checkIfAlarm(1)) { //Is the RTC alarm still on?
RTC.turnOffAlarm(1); //then turn it off.
//print (optional) debugging message to the serial window if you wish
//Serial.print("RTC Alarm on INT-0 triggered at ");
//Serial.println(CycleTimeStamp);
clockInterrupt = false; //reset the interrupt flag to false
// read the RTC temp register and print that out
// Note: the DS3231 temp registers (11h-12h) are only updated every 64seconds
Wire.beginTransmission(DS3231_I2C_ADDRESS);
Wire.write(0x11); //the register where the temp data is stored
Wire.endTransmission();
Wire.requestFrom(DS3231_I2C_ADDRESS, 2); //ask for two bytes of data
if (Wire.available()) {
tMSB = Wire.read(); //2’s complement int portion
tLSB = Wire.read(); //fraction portion
temp3231 = ((((short)tMSB << 8) | (short)tLSB) >> 6) / 4.0; // Allows for readings below freezing: thanks to Coding Badly
else {
temp3231 = 0;
//if temp3231 contains zero, then you know you had a problem reading the data from the RTC!
Serial.print(F(". TEMPERATURE from RTC is: "));
Serial.print(temp3231);
Serial.println(F(" Celsius"));
// You could read in other variables here …like the analog pins, I2C sensors, etc
// and just add them to the dataString before you write it to the file
valA0 = analogRead(analogPin);
// for stand-alone ProMini loggers, I monitor the main battery voltage (which is > Aref)
// with a voltage divider: RawBattery - 10MΩ - A0 - 3.3MΩ - GND
// with a 104 ceramic capacitor accross the 3.3MΩ resistor to enable the ADC to read the high impedance resistors
// Then calculate: float batteryVoltage = float((analogRead(A0)/ 255.75)*3.3);
//=========concatenate data into a string =====================
// Add each piece of information to the string that gets written to the SD card with:dataFile.println(dataString);
String dataString = ""; //this line simply erases the string
dataString = dataString + CycleTimeStamp;
dataString = dataString + ", "; //separate data with a comma so they can be imported to separate collumns in a spreadsheet
dataString = dataString + String(temp3231); //this only gives you two decimal places
//With floating point nubmers, if you want more digits after the decimal place replace the above line with these three:
//char buff[10];
//dtostrf(rtc_TEMP_degC, 4, 4, buff); //4 is mininum width, second number is #digits after the decimal
//dataString = dataString + buff;
dataString = dataString + String(valA0);
//========== Now write the data to the SD card ===========
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
if (dataFile) {
dataFile.close();
// print to the serial port too:
Serial.println(dataString);
// if the file isn't open, pop up an error:
else {
Serial.println(F("error opening datalog.txt"));
//============Set the next alarm time =============
Alarmhour = now.hour();
Alarmminute = now.minute() + SampleIntervalMinutes;
Alarmday = now.day();
// check for roll-overs
if (Alarmminute > 59) { //error catching the 60 rollover!
Alarmminute = 0;
Alarmhour = Alarmhour + 1;
if (Alarmhour > 23) {
Alarmhour = 0;
// put ONCE-PER-DAY code here -it will execute on the 24 hour rollover
// then set the alarm
RTC.setAlarm1Simple(Alarmhour, Alarmminute);
RTC.turnOnAlarm(1);
if (RTC.checkAlarmEnabled(1)) {
//you would comment out most of this message printing
//if your logger was actually being deployed in the field
Serial.print(F("RTC Alarm Enabled!"));
Serial.print(F(" Going to sleep for : "));
Serial.print(SampleIntervalMinutes);
Serial.println(F(" minutes"));
Serial.println();Serial.flush();//adds a carriage return & waits for buffer to empty
delay(25); //this optional delay is only here so we can see the LED’s otherwise the entire loop executes so fast you might not see it.
digitalWrite(GREEN_PIN, LOW);
// Note: Normally you would NOT leave a red indicator LED on during sleep! This is just so you can see when your logger is sleeping, & when it's awake
//digitalWrite(RED_PIN, HIGH); // Turn on red led as our indicator that the Arduino is sleeping. Remove this before deployment.
//——– sleep and wait for next RTC alarm ————–
// Enable interrupt on pin2 & attach it to rtcISR function:
attachInterrupt(0, rtcISR, LOW);
// Enter power down state with ADC module disabled to save power:
LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_ON);
//processor starts HERE AFTER THE RTC ALARM WAKES IT UP
detachInterrupt(0); // immediately disable the interrupt on waking
//digitalWrite(RED_PIN, LOW);
digitalWrite(GREEN_PIN, HIGH); //Interupt woke processor, turn on green led
//================ END of the MAIN LOOP ===============
// This is the Interrupt subroutine that only executes when the RTC alarm goes off
void rtcISR() {
clockInterrupt = true;
void clearClockTrigger() // from http://forum.arduino.cc/index.php?topic=109062.0
byte bytebuffer1=0;
Wire.beginTransmission(0x68); //Tell devices on the bus we are talking to the DS3231
Wire.write(0x0F); //Tell the device which address we want to read or write
Wire.endTransmission(); //Before you can write to and clear the alarm flag you have to read the flag first!
Wire.requestFrom(0x68,1); //Read one byte
bytebuffer1=Wire.read(); //In this example we are not interest in actually using the bye
Wire.write(0x0F); //Status Register: Bit 3: zero disables 32kHz, Bit 7: zero enables the main oscilator
Wire.write(0b00000000); //Write the byte. //Bit1: zero clears Alarm 2 Flag (A2F), Bit 0: zero clears Alarm 1 Flag (A1F)
clockInterrupt=false; //Finally clear the flag we use to indicate the trigger occurred
