One side of the board has the folowing pin layout
[ reset - 3v3 - 5v - ground - ? - Vin ] [analog 0 - analog 1- analog 2 - analog 3 - analog 4 - analog 5]
at around Vin, there is a pin that is not documented before or after i'm not sure so it could be
or
[ reset - 3v3 - 5v - ground - Vin -? ]
So i wonder what this ? does, is it perhaps a place to attach external wires for power togther with Vin (instead of usb/or plugin conector) ?
if it is not what is it ?
and if it is not where should i connect (solder) wires to connect to an external power
