Une erreur probablement basique
Bonjour,
Pour tester un nouveau LCD (DFR0464), j'ai utilisé l'exemple suivant pris sur le site Github (ici: https://github.com/DFRobot/DFRobot_RGBLCD1602/tree/master/examples/Roll):
 * @file Roll.ino
 * @brief Roll show 'hello, world!'.
 * @copyright  Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
 * @licence     The MIT License (MIT)
 * @maintainer [yangfeng](feng.yang@dfrobot.com)
 * @version  V1.0
 * @date  2021-09-24
 * @url https://github.com/DFRobot/DFRobot_RGBLCD1602
 Emplacement du programme:
 U:\ELECTRONIQUE\ARDUINO\AFFICHEURS LCD\DFRobot_DFR0464 with RGB backlight\pgm arduino\roll_01\roll_01.ino
#include "DFRobot_RGBLCD1602.h"
Change the RGBaddr value based on the hardware version
       Moudule        | Version| RGBAddr|
  LCD1602 Module      |  V1.0  | 0x60   |
  LCD1602 Module      |  V1.1  | 0x6B   |
  LCD1602 RGB Module  |  V1.0  | 0x60   |
  LCD1602 RGB Module  |  V1.1  | 0x2D   |
DFRobot_RGBLCD1602 lcd(/*RGBAddr*/0x60 ,/*lcdCols*/16,/*lcdRows*/2);  //16 characters and 2 lines of show
     *  @brief initialize the LCD and master IIC
    lcd.init();
    // Print a message to the LCD.
    lcd.print("hello, world!");
    // scroll 13 positions (string length) to the left
    // to move it offscreen left:
    for (int positionCounter = 0; positionCounter < 13; positionCounter++) {
         *  @brief scroll left to display
        lcd.scrollDisplayLeft();//scroll one position left
        // wait a bit:
        delay(150);
    // scroll 29 positions (string length + show length) to the right
    // to move it offscreen right:
    for (int positionCounter = 0; positionCounter < 29; positionCounter++) {
         *  @brief scroll right to display
        lcd.scrollDisplayRight();//scroll one position right
        // wait a bit:
        delay(150);
    // scroll 16 positions (show length + string length) to the left
    // to move it back to center:
    for (int positionCounter = 0; positionCounter < 16; positionCounter++) {
        // scroll one position left:
        // wait a bit:
        delay(150);
    // delay at the end of the full loop:
j'obtiens ce message d'erreur:
Arduino : 1.8.15 (Windows 10), TD: 1.57, Carte : "Arduino Uno"
E:\Programmes\Arduino\arduino-builder -dump-prefs -logger=machine -hardware E:\Programmes\Arduino\hardware -hardware C:\Users\Michel\AppData\Local\Arduino15\packages -tools E:\Programmes\Arduino\tools-builder -tools E:\Programmes\Arduino\hardware\tools\avr -tools C:\Users\Michel\AppData\Local\Arduino15\packages -built-in-libraries E:\Programmes\Arduino\libraries -libraries C:\Users\Michel\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10815 -build-path C:\Users\Michel\AppData\Local\Temp\arduino_build_672 -warnings=none -build-cache C:\Users\Michel\AppData\Local\Temp\arduino_cache_426639 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Michel\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Michel\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\Michel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Michel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Michel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Michel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose U:\ELECTRONIQUE\ARDUINO\AFFICHEURS LCD\DFRobot_DFR0464 with RGB backlight\pgm arduino\roll_01\roll_01.ino
E:\Programmes\Arduino\arduino-builder -compile -logger=machine -hardware E:\Programmes\Arduino\hardware -hardware C:\Users\Michel\AppData\Local\Arduino15\packages -tools E:\Programmes\Arduino\tools-builder -tools E:\Programmes\Arduino\hardware\tools\avr -tools C:\Users\Michel\AppData\Local\Arduino15\packages -built-in-libraries E:\Programmes\Arduino\libraries -libraries C:\Users\Michel\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10815 -build-path C:\Users\Michel\AppData\Local\Temp\arduino_build_672 -warnings=none -build-cache C:\Users\Michel\AppData\Local\Temp\arduino_cache_426639 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Michel\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Michel\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\Michel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Michel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Michel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Michel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose U:\ELECTRONIQUE\ARDUINO\AFFICHEURS LCD\DFRobot_DFR0464 with RGB backlight\pgm arduino\roll_01\roll_01.ino
Using board 'uno' from platform in folder: C:\Users\Michel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Using core 'arduino' from platform in folder: C:\Users\Michel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Detecting libraries used...
"C:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "C:\\Users\\Michel\\AppData\\Local\\Temp\\arduino_build_672\\sketch\\roll_01.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "C:\\Users\\Michel\\AppData\\Local\\Temp\\arduino_build_672\\sketch\\roll_01.ino.cpp" -o nul
"C:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "C:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "C:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src\\utility\\twi.c" -o nul
Generating function prototypes...
"C:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "C:\\Users\\Michel\\AppData\\Local\\Temp\\arduino_build_672\\sketch\\roll_01.ino.cpp" -o "C:\\Users\\Michel\\AppData\\Local\\Temp\\arduino_build_672\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"E:\\Programmes\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Michel\\AppData\\Local\\Temp\\arduino_build_672\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compilation du croquis...
"C:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "C:\\Users\\Michel\\AppData\\Local\\Temp\\arduino_build_672\\sketch\\roll_01.ino.cpp" -o "C:\\Users\\Michel\\AppData\\Local\\Temp\\arduino_build_672\\sketch\\roll_01.ino.cpp.o"
Compiling libraries...
Compiling library "Wire"
"C:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "C:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src\\Wire.cpp" -o "C:\\Users\\Michel\\AppData\\Local\\Temp\\arduino_build_672\\libraries\\Wire\\Wire.cpp.o"
"C:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "C:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src\\utility\\twi.c" -o "C:\\Users\\Michel\\AppData\\Local\\Temp\\arduino_build_672\\libraries\\Wire\\utility\\twi.c.o"
Compiling core...
Using precompiled core: C:\Users\Michel\AppData\Local\Temp\arduino_cache_426639\core\core_arduino_avr_uno_a5afed7245deae3c4ac4b21b0d97f794.a
Linking everything together...
"C:\\Users\\Michel\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\Michel\\AppData\\Local\\Temp\\arduino_build_672/roll_01.ino.elf" "C:\\Users\\Michel\\AppData\\Local\\Temp\\arduino_build_672\\sketch\\roll_01.ino.cpp.o" "C:\\Users\\Michel\\AppData\\Local\\Temp\\arduino_build_672\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\Michel\\AppData\\Local\\Temp\\arduino_build_672\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\Michel\\AppData\\Local\\Temp\\arduino_build_672/..\\arduino_cache_426639\\core\\core_arduino_avr_uno_a5afed7245deae3c4ac4b21b0d97f794.a" "-LC:\\Users\\Michel\\AppData\\Local\\Temp\\arduino_build_672" -lm
C:\Users\Michel\AppData\Local\Temp\ccXmklro.ltrans0.ltrans.o: In function `global constructors keyed to 65535_0_roll_01.ino.cpp.o.1764':
<artificial>:(.text.startup+0x36): undefined reference to `DFRobot_RGBLCD1602::DFRobot_RGBLCD1602(unsigned char, unsigned char, unsigned char, TwoWire*, unsigned char)'
C:\Users\Michel\AppData\Local\Temp\ccXmklro.ltrans0.ltrans.o: In function `setup':
U:\ELECTRONIQUE\ARDUINO\AFFICHEURS LCD\DFRobot_DFR0464 with RGB backlight\pgm arduino\roll_01/roll_01.ino:38: undefined reference to `DFRobot_RGBLCD1602::init()'
C:\Users\Michel\AppData\Local\Temp\ccXmklro.ltrans0.ltrans.o: In function `loop':
U:\ELECTRONIQUE\ARDUINO\AFFICHEURS LCD\DFRobot_DFR0464 with RGB backlight\pgm arduino\roll_01/roll_01.ino:51: undefined reference to `DFRobot_RGBLCD1602::scrollDisplayLeft()'
U:\ELECTRONIQUE\ARDUINO\AFFICHEURS LCD\DFRobot_DFR0464 with RGB backlight\pgm arduino\roll_01/roll_01.ino:62: undefined reference to `DFRobot_RGBLCD1602::scrollDisplayRight()'
U:\ELECTRONIQUE\ARDUINO\AFFICHEURS LCD\DFRobot_DFR0464 with RGB backlight\pgm arduino\roll_01/roll_01.ino:71: undefined reference to `DFRobot_RGBLCD1602::scrollDisplayLeft()'
collect2.exe: error: ld returned 1 exit status
Utilisation de la bibliothèque Wire version 1.0 dans le dossier: C:\Users\Michel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire
exit status 1
Erreur de compilation pour la carte Arduino Uno
J'ai bien installé la bibliothèque "DFRoboto_RGBLCD1602.h" depuis l'IDE Arduino (Gestionnaire de bibliothèques) et dans le répertoire du projet au cas où il la chercherait localement.
Quel est le problème docteur ??!
Je ne suis pas docteur, donc pas facile à dire... Hmmmm...
Pas besoin d'installer la bibliothèque dans le répertoire du code ino. Tu peux déjà l'effacer.
Ensuite, vérifie si le répertoire de la bibliothèque est bien dans ton Arduino/libraries.
Enfin, comment est installée L'IDE ? C'est quelle version ?
Il semble que tu as des choses sur le disque C et d'autres sur le disque E. C'est bizarre, et peut-être une raison pour que l'IDE se perde un peu.
et aussi un disque U (un disque réseau?)
Bien vu oeil de lynx !! :smiley: :smiley:
L'IDE est installé sur E:
Le répertoire arduino15 et les librairies sur C:
Le répertoire projet sur U:
Les librairies standards sont bien trouvées (Wire et ses dépendances sont compilés) mais pas la librairie DFRobot_RGBLCD1602. Il serait intéressant de savoir où elle a été installée.
Et l'IDE peut fonctionner correctement avec ce genre d'installation dispersée ?
Je vois une solution laide (mais non destructrice):
mettre tous les codes liés à votre bibliothèque (surtout ceux du repertoire du projet) dans un petit coin, bien caché.
Faire une réinstallation de la bibliothèque la plus standard possible.. depuis l'IDE
Verifier qu'elle est installée .
Pas sûr: si tu regardes le code, la bibliothèeque est entre " " et pas entre < >, ce qui me laisse penser que le code s'attend à trouver la librairie dans le répertoire du code, non ?
J'ai mis une copie de la librarie dans le répertoire du projet pour les raisons expliquées ci-dessus, elle est dans le même répertoire U que le ".ino" (au même niveau).
La bibliothèque a été installé depuis le Gestionnaire de Bibliothèque, plus standard que ça...
C'est parceque j'ai eu des erreurs que je me suis dit qu'il fallait peut-être la copier dans e répertoire du projet (vu qu'il y a des " " dans le code, et pas les habituels < >, mais je me trompe peut-être).
Et l'IDE a toujours fonctionné depuis des années, donc le fait que lesprojets ne soient pas sur C:\ ne l'a jamais gêné jusqu'à aujourd'hui...
Bon je viens de trouver une solution, mais je voudrais clarifier avec vous !
Pour ne plus avoir d'erreur de compilation, il faut que dans le code je remplace:
par
#include <DFRobot_RGBLCD1602.h>
et là ça passe sans problème à la compilation.
Donc je voudrais savoir dans quel répertoire l'IDE va chercher la librairie pour chacune des deux syntaxes, car il aurait dû trouver la bibliothèque copiée dans le répertoire du projet ??? ...
Merci
Avis sur ce code? posts 45 et 46 donnent des pistes pour l'expliquer (la librairie est connue de tout l'environnement arduino, ce qui est sympa, mais pas au niveau du projet -ce qui n'est pas grave; si vous aviez à la modifier, vous auriez des ennuis- mais c'est une configuration saine (le mainteneur corrige d'éventuelles bugs, sans que vous n'ayez à vous en soucier)
Désolé pour ma réponse tardive, mais je ne reçois pas les notifications de réponse...
J'ai trouvé la solution que je vous ai indiquée, mais comme je n'arrive pas à maitriser quelle bibliothèque l'IDE utilise, même en forçant les guillements " " au lieu des crochets < >, j'ai décidé désoramais d'uploader mes programmes sensibles par AVRDUDE en récupérant le ".hex" généré par l'IDE lors d'une compilation.
Ainsi plus besoin de me préoccuper de la librairei qu'il choisit, je suis sûr que le code uploadé sera toujours le même...
Merci
Oh, l'essentiel est que vous ayez une configuration saine et pas trop compliquée..
(au fait, l'uoload -graver sur une puce ce que vous avez programmé- n'a que des rapports très lointains avec la mise à jour de bibiothèques -des briques logicielles maintenues ailleurs ou que vous vous appropriez- : il faut savoir qui fait quoi, dans ce cas)
