Hi, I was just writing some code and an unexpected error occurred here:
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#include "DHT.h"
#define DHTPIN 2 // what pin we're connected to
// Uncomment whatever type you're using!
#define DHTTYPE DHT11 // DHT 11
DHT dht(DHTPIN, DHTTYPE);
int humi = 0;
int input = 15;
int output = 14;
lcd.begin(16, 2);
dht.begin();
lcd.noDisplay();
delay(100);
lcd.display();
lcd.write("Greenhouse system");
delay(3000);
lcd.clear();
delay(30);
lcd.write("Loading info ...");
delay(3000);
lcd.clear();
delay(100);
void loop(){
delay(2000);
float h = dht.readHumidity();
// Read temperature as Celsius
float t = dht.readTemperature();
// Read temperature as Fahrenheit
float f = dht.readTemperature(true);
lcd.setCursor(1, 1);
lcd.write("Temp(f)= ");
lcd.setCursor(10, 1);
lcd.write(dht.readTemperature());
lcd.setCursor(1, 2);
lcd.write("Humidity = ");
lcd.setCursor(12, 2);
lcd.write(dht.readHumidity());
humi = analogRead(input);
output = analogWrite(humi);
Then the compiler says this:
/tmp/802097090/sketch_jul24a/sketch_jul24a.ino: In function 'void loop()':
/tmp/802097090/sketch_jul24a/sketch_jul24a.ino:51:29: error: too few arguments to function 'void analogWrite(uint8_t, int)'
In file included from /tmp/802097090/build/sketch/sketch_jul24a.ino.cpp:1:0:
/home/builder/.arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/Arduino.h:139:6: note: declared here
void analogWrite(uint8_t pin, int val);
exit status 1
