Unexpected pow() behaviour
The following bit of code produces an unexpected result. When I pass a function parameter into the math.h power function, something goes wrong. In this example it returns 3 when 22 == 4 is expected.
#include <math.h>
void test(int a) {
  int b = (int) pow(2, a);
  Serial.println(b);            // Outputs 3
  test(2);
void loop() {}
It does spit out 4 when I replace a with the number 2 inside the function, so it can’t be a casting/rounding issue. What’s going on here?
It's not really unexpected. If you're only dealing with integer powers of integers, pow is a very poor choice.
AWOL: It's not really unexpected.
How is it not? pow(2, 2) returns 4 whilst pow(2, a) where a = 2 returns 3. That is odd behaviour.
AWOL: If you're only dealing with integer powers of integers, pow is a very poor choice.
What's the better solution?
Your 2 is a compile-time constant. The compiler is good at optimising those away.
For integers, a loop is simpler and more accurate For powers of 2, shifts are probably quicker - a table even quicker.
AWOL: Your 2 is a compile time constant. The compiler is good at optimising those away.
I don't get how an integer at compile time would be different from one being instantiated during run time. I tried compiling the same code (without the serial output) using gcc and TDM-GCC, and it both cases it did return 4.
AWOL: For integers, a loop is simpler and more accurate For powers of 2, shifts are probably quicker.
Ah yes, should have thought of bit shifting. Thanks.
In that case, the pow() function is probably returning a floating point value like 3.99999, which is 3 after converting to an integer.
I don’t get how an integer at compile time would be different from one being instantiated during run time
You could look at the generated assembly language.
A constant at compile time means the compiler can calculate the result, but a variable must be passed to “pow()” at runtime, where the vagaries of 32 bit floating point come into play.
It is never a good idea to pass in the wrong type of data or ignore what is returned. Change your code to:
#include <math.h>
void test(float a) {
  float b = pow(2.0, a);
  Serial.print("b = ");
  test(2.0);
void loop() {}
and the answer 4.0 is returned. Note that I passed 2.0 (a float) to test() and passed two floats to pow() and treated the return type as a float.
pow(float m, float e) converts the integers 2 and m to floats thereby possibly making rounding errors. Then it uses the formula
return exp( e * log(m));
which are three floating point operations, each with their possible rounding errors.
So pow() used for integers has at least 5 possible sources for error.
you can write a simple integer only power function e.g. ipow()
long ipow(int m, uint8_t e) // only positive integer exponents.  31 is max value.
  long rv = 1;
  for (; e >0; e--) rv *= m;
  return rv;
Tonitrum:
What’s the better solution?
Like someone said, shift is a better solution:
#include <math.h>
void test(int a) {
  int b = 0x01 << a;
  test(2);
void loop() {}
did you try that code ? ;)
But only for integer powers of two or its multiples.
AWOL:
It seams that is what we are talking about, right?:
luisilva:
AWOL:
It seems that that is the original intention, but someone in the future reading this may assume that shifts are the universal solution. They're not even necessarily the complete solution here - "a" is, after all a signed integer.
Thanks for the answers guys. I only needed powers of two, so shifting is indeed a cleaner solution.
pow( ) is an almost useless function. In 30 years of writing C/C++, I have never found a good reason to use it myself.
The most common thing people use it for, is squaring numbers but there is really nothing wrong with x * x .
You're about the third person this month to have a similar sort of trouble with it.
michinyon: pow( ) is an almost useless function. In 30 years of writing C/C++, I have never found a good reason to use it myself.
Depends on the application, e.g. cuberoot (volume to side)
float cubeRoot(float x) { if (x >= 0) return pow(x, 1/3.0); return -pow(abs(x), 1/3.0); }
or physics formulas like the dew point
// DEWPOINT
// dewPoint function NOAA
// reference: http://wahiduddin.net/calc/density_algorithms.htm
double dewPoint(double celsius, double humidity)
    double A0= 373.15/(273.15 + celsius);
    double SUM = -7.90298 * (A0-1);
    SUM += 5.02808 * log10(A0);
    SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
    SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
    SUM += log10(1013.246);
    double VP = pow(10, SUM-3) * humidity;
    double T = log(VP/0.61078);   // temp var
    return (241.88 * T) / (17.558-T);
Also good for converting watts to dBm’s and other logarithmic functions.
