Unexpected program behaviour
Hello,
I've spent few hours trying to identify the issue, but no luck.. Code stop/halt on line 163, sometimes it cycling loop() again from the start.
I'm getting rid of using Strings in my program (as it is freezing after a few days and need a restart). So, probably I messed up with char arrays just can't figure out where and why :frowning: :slight_smile:
Any help/advice is highly appreciated! Thanks!
Arduino IDE v.1.8.13
Board: Arduino Nano (ATMega328 (Old Bootloader))
const int inpBuffMaxLen = 200;
char inputBuffer[inpBuffMaxLen];
int minTemp = 0;
int maxTemp = 0;
int obrMinTemp = 0;
int obrMaxTemp = 0;
char smsPhoneStr[12] = "";
char smsPhoneStr2[12] = "";
bool bEnableSms = false;
bool bObratkaEnableSms = false;
int smsIntervalMins;
long lastSmsSentMSec = -9999000;
class CommonA
  public:
    static int indexOf(const char* source, const char* find)
      int srcLen = strlen(source);
      int fndLen = strlen(find);
      if (srcLen == 0 || fndLen == 0 || fndLen > srcLen)
        return -1;
      const char* ptr = strstr(source, find);
      if (ptr) {
        int index = ptr - source;
        if (index >= 0)
          return index;
      return -1;
    static void strRemove(char* str, int pos)
      int len = strlen(str);
      int ind = 0;
      for (int i = pos; i < len; i++)
        str[ind] = str[i];
        ind++;
      str[ind] = '\0';
void setup(void)
void loop(void)
  httpGetSMSConfig();
  delay(300000);
bool httpGetSMSConfig()
  bool bRes = false;
  bool bConnect = true;
  if (bConnect)
    inputBuffer[0] = '\0';
    strcat(inputBuffer, "HTTPCODE:200|L:54|D:\r\nsmsdet=40,55,0,30,60,1,81234567861 81234567861,9,999,");
    char* resStr = &inputBuffer[0];
    Serial.println(resStr);
    int index = -1;
    if ((index = CommonA::indexOf(resStr, "smsdet=")) > -1)
      bRes = true;
      CommonA::strRemove(resStr, index + 8);
      //mintemp
      index = CommonA::indexOf(resStr, ",");
      char minTempStr[5] = "";
      memcpy(minTempStr, resStr, index);
      minTempStr[index] = '\0';
      Serial.print(F("Mintemp: "));
      Serial.println(minTempStr);
      CommonA::strRemove(resStr, index + 1);
      minTemp = atoi(minTempStr);
      //maxtemp
      char maxTempStr[5] = "";
      memcpy(maxTempStr, resStr, index);
      maxTempStr[index] = '\0';
      Serial.print(F("Maxtemp: "));
      Serial.println(maxTempStr);
      maxTemp = atoi(maxTempStr);
      //bEnableSMS
      char enableSmsStr = resStr[index - 1];
      Serial.print(F("enableSMS: "));
      Serial.println(enableSmsStr);
      if (enableSmsStr == '1')
        bEnableSms = true;
        bEnableSms = false;
      //obrMinTemp
      char obrMinTempStr[5] = "";
      memcpy(obrMinTempStr, resStr, index);
      obrMinTempStr[index] = '\0';
      Serial.print(F("ObrMin: "));
      Serial.println(obrMinTempStr);
      obrMinTemp = atoi(obrMinTempStr);
      //obrMaxTemp
      char obrMaxTempStr[5] = "";
      memcpy(obrMaxTempStr, resStr, index);
      obrMaxTempStr[index] = '\0';
      Serial.print(F("ObrMax: "));
      Serial.println(obrMaxTempStr);
      obrMaxTemp = atoi(obrMaxTempStr);
      //bObratkaEnableSMS
      char obratkaEnableSmsStr = resStr[index - 1];
      Serial.print(F("ObrEnabled: "));
      Serial.println(obratkaEnableSmsStr);
      if (obratkaEnableSmsStr == '1')
        bObratkaEnableSms = true;
      //phone
      char phones[25];
      memcpy(phones, resStr, index);
      phones[index] = '\0';
      Serial.print(F("phoneWhole "));
      Serial.println(phones);
      int ind2 = -1;
      if ((ind2 = CommonA::indexOf(phones, " ")) > -1)
        //second num
        memcpy(smsPhoneStr, phones, index);
        smsPhoneStr[index] = '\0';
        CommonA::strRemove(phones, index + 1);
        memcpy(smsPhoneStr2, phones, strlen(phones));
        smsPhoneStr2[strlen(phones)] = '\0';
        memcpy(smsPhoneStr, phones, strlen(phones));
        smsPhoneStr[strlen(phones)] = '\0';
        smsPhoneStr2[0] = '\0';
      Serial.print(F("Phone: "));
      Serial.println(smsPhoneStr);
      //smsIntervalMins
      char smsIntervalMinsStr[10];
      memcpy(smsIntervalMinsStr, resStr, index);
      smsIntervalMinsStr[index] = '\0';
      Serial.print(F("SMS Interval (mins): "));
      Serial.println(smsIntervalMinsStr);
      smsIntervalMins = atoi(smsIntervalMinsStr);
      //lastSmsSentMins
      char smsLastSentStr[5];
      memcpy(smsLastSentStr, resStr, index);
      Serial.print(F("SMS Last sent (mins): "));
      Serial.println(smsLastSentStr);
      int val = atoi(smsLastSentStr);
      if (val <= 0)
        lastSmsSentMSec = -1;
        lastSmsSentMSec = val;
The obvious suspect is that the program is writing outside of array bounds. For example, in this code you never check for the case that index>4, which could be fatal.
It helps to use the "n" versions of the string handling routines, where possible. For example, strncpy(), strncat(), etc.
why do you create a class for your helper functions... just use functions
int strIndexOf(const char* source, const char* find)
    return -1;
  if (ptr) {
    if (index >= 0)
      return index;
  return -1;
  int ind = 0;
    str[ind] = str[i];
    ind++;
  str[ind] = '\0';
Your issue is likely there: you allocate 12 bytes for
then in the code you allocate 25 bytes for
     char phones[25];
which will be initialized with "81234567861 81234567861"
and then you do
     if ((ind2 = strIndexOf(phones, " ")) > -1)
        //second num
==> if the if condition is true, you SHOULD use ind2, not index (that's your bug)
==> if the condition is false, you assume that there is only one phone number and you copy possibly up to 25 bytes into 12 which could lead to disaster. you should check for bounds.
here is a quick rewrite in a test script:
    return -1;
  if (ptr) {
    if (index >= 0)
      return index;
  return -1;
  int ind = 0;
    str[ind] = str[i];
    ind++;
  str[ind] = '\0';
  strcat(inputBuffer, "HTTPCODE:200|L:54|D:\r\nsmsdet=40,55,0,30,60,1,81234567861 81234567000,9,999,");
  char* resStr = inputBuffer;
  int index = strIndexOf(resStr, "smsdet=");
  if (index > -1)  {
    strRemove(resStr, index + 7); // SHOULD THAT BE 7 ?
    index = strIndexOf(resStr, ",");
    int minTemp = atoi(minTempStr);
    //maxtemp
    int maxTemp = atoi(maxTempStr);
    //bEnableSMS
    bool EnableSms = (enableSmsStr == '1');
    //obrMinTemp
    int obrMinTemp = atoi(obrMinTempStr);
    //obrMaxTemp
    int obrMaxTemp = atoi(obrMaxTempStr);
    //bObratkaEnableSMS
    bool bObratkaEnableSms = (obratkaEnableSmsStr == '1');
    //phone
    char phones[25];
    int ind2 = strIndexOf(phones, " ");
    if (ind2 > -1) {
      //second num
      memcpy(smsPhoneStr, phones, ind2);
      smsPhoneStr[ind2] = '\0';
      strRemove(phones, ind2 + 1);
      Serial.print(F("Phone2: "));
      Serial.println(smsPhoneStr2);
    //smsIntervalMins
    int smsIntervalMins = atoi(smsIntervalMinsStr);
    //lastSmsSentMins
    int lastSmsSentMSec = (val <= 0) ? -1 : val;
void loop() {}
Serial Monitor (@ 115200 bauds) will show
[color=purple]
[color=red]HTTPCODE:200|L:54|D:
smsdet=40,55,0,30,60,1,81234567861 81234567000,9,999,[/color]
Mintemp: 40
Maxtemp: 55
enableSMS: 0
ObrMin: 30
ObrMax: 60
ObrEnabled: 1
phoneWhole 81234567861 81234567000
Phone: 81234567861
Phone2: 81234567000
SMS Interval (mins): 9
SMS Last sent (mins): 999
[/color]
seems to be ok now but you should be super careful when mem-copying stuff into buffers to ensure that the size of what you copy fits the buffer size
PS/ parsing your cString could be done way more simply with strtok() and without rearranging the string all the time, just scan things as you go through the buffer. consider this code:
const char* keyword = "smsdet=";
  char* resStr = strstr(inputBuffer, keyword);
  resStr = strtok(resStr + strlen(keyword), ", ");
  while (resStr) {
    resStr = strtok(NULL, ", ");
void loop() {}
[color=purple]
40
55
0
30
60
1
81234567861
81234567000
9
999
[/color]
so you get all your data, it's just a matter of storing them as you go
J-M-L, thanks a lot for addressing my issue!
Bug is trivial when it's disclosed, but so stupid for me being unable to find out for so long :slight_smile:
we have all been there, don't worry!
