Unexpected resistance on breadboard
Hi to all, the first post on Arduino, please be kind. :slight_smile: If you have any good ideas, please suggestion, any advice is helpful.
Recently, I am trying to learn how the ADC works on this Cypress PSoC 4100 board.
The circuit in the picture does nothing but power the board, connect it to the LCD display, and show the readings from the ADC. The ADC is set up to use the internal 1.024V reference with the bypass cap, which is built onto the 4100 board itself. The input to the ADC is on pin 2.0, which is in the upper-right corner of the photo.
I noticed that the ADC never output the minimum value (which is -2048, since it's a 12-bit ADC and outputs signed values), even when I connected the ADC input to one of the ground rails. The only way I was able to get a minimum value is to connect the ADC input directly to the ground pin on the 4100 board.
Using my multimeter I discovered that there was 500-600 ohms of resistance between the breadboard ground rail and the ground pin of the 4100 board! In the photo, the multimeter black wire (entering at the bottom) is connected not exactly to the 4100 board's ground but to the breadboard socket right next to it, while the red wire (also entering at the bottom) is connected to the ground rail on the lower breadboard. That is connected via a black wire on the right to the ground rail on the top breadboard, which his connected to the ground pin.
The multimeter shows 580 ohms of resistance even though it's nothing but metal between these two points. That's causing the ADC (fed via the second red wire right next to the multimeter red wire) to read 100 or so mV instead of the expected zero.
If I wiggle the black wire that connects the ground rails of the top and bottom breadboards, the resistance jumps around a lot, anywhere from 200 ohms to over 1K.
Moving the wires that connect the two breadboards to the left side and away from the LCD signal lines didn't change anything.
If I connect the multimeter red wire to the top breadboard's ground rail, right next to the black wire that connects it to the ground on the 4100 board, I still see about 230 ohms. This is over a distance of about 1cm!
Unplugging the LCD display reduces the the resistance to about 38 ohms.
Removing power by unplugging the USB cable (it's USB-powered so it's all 5 volts) reduces the resistance down to about 6 ohms.
When I tried measuring the resistance between two (connected) ground rails on another otherwise empty breadboard, I saw 3 ohms max.
My question is, what's causing this resistance and how do I get rid of it? Is it some kind of inductance issue? Having 100 mV or so of voltage on the ground rail isn't fatal to the project by itself, but whatever's affecting the ground rail might also affect the input to the ADC, which would throw off the readings.
Thanks!
Remeasure those resistances with all the power OFF.
I think there are some voltages that are making your meter read incorrectly.
Let us know..
terryking228:
Let us know..
OK, I'll do right now, thank you.
Breadboard has always been plagued by this sort of problem- it does not make a reliable connection, sometimes much worse than others. I avoid it and use DuPont line, or when possible, soldered connections for wiring up projects.
guyun:
I think that terry spotted it. The issue is 'incorrect setup' for this particular method of resistance measurement using the multimeter.
While it's ok to make a mistake for this particular case......... just keep in mind that it can be important to have the correct measurement set-up - to avoid damage to device, damage to measurement equipment, and damage to ourselves etc.
Also, make sure that the units of the multimeter reading is correctly interpreted. It appears that your meter doesn't show any units on the LCD.... like ohm, kilo-ohm etc.
Sometimes, there may really be cases where you need to take breadboard resistances into account. The more current there is through some relatively thin wire (with some amount of resistance), the more the voltage drop from one side of that wire to the other. So you might have to consider things like .... use thicker wire? Or don't use breadboard for particular projects.
My display doesn't show K or M units but I always relied on the dial being set correctly. In the OP's picture it showed the dial was set to 2k which means it's displaying in K range up to max 2,000 ohms. When it shows .580 k it is 580 ohms.
I think the mistake is measuring resistance while the breadboard power was on. Unexpected voltage from the circuit can throw meter's reading off.
[quote author=
[/quote]
so embarrassed, I didn't find such a basic problem.
