Unexpected weird problem while programming ESP32
Dear Forum, I use two (separate stand-alone) computers, both running under MicroSoft Windows 10. I use 4 ESP32 DEVKIT V1. Until recently I could upload, using Arduino 1.8.14, all kinds of programs from both computers to all ESPs. Suddenly, on one computer I now get the huge table of strange problems while uploading some of my programs (seen example below, but there are many other programs that do no longer upload to the ESPs) while other programs can still be uploaded and run without any problems. On the other computer all programs can be uploaded to the ESPs.
What I've done over the last weeks: installed Adruino 1.8.14 three times again, renewed the whole list of libraries that I use, deleted recent Windows updates, but so far it seems impossible to figure out what could possibly go wrong here. And as said above: the problem-giving computer does recognise the ESPs, it does upload some programs and simply refuses others while generating long error listings.
Why, Why ????
I hope I used the </> correctly so that the program and error listing are in the correct format. Thanks very much in advance for your help !
<//LET OP: gelijkzetten van de klok: gebruik if (!RTC.isRunning())
//LET OP: aflezen van de klok: gebruik if (RTC.isRunning())
#include <Wire.h>
#include <RTC.h>
static DS1307 RTC;
RTC.begin();
Serial.print("Is Clock Running: ");
	Serial.println("Yes");
	Serial.print(RTC.getDay());
	Serial.print("-");
	Serial.print(RTC.getMonth());
	Serial.print("-");
	Serial.print(RTC.getYear());
	Serial.print(" ");
	Serial.print(RTC.getHours());
	Serial.print(":");
	Serial.print(RTC.getMinutes());
	Serial.print(":");
	Serial.print(RTC.getSeconds());
	Serial.print("");
	if (RTC.getHourMode() == CLOCK_H12)
		switch (RTC.getMeridiem()) {
		case HOUR_AM:
			Serial.print(" AM");
		case HOUR_PM:
			Serial.print(" PM");
	Serial.println("");
	//delay(1000);
	delay(1500);
	Serial.println("No");
	Serial.println("Setting Time");
	//RTC.setHourMode(CLOCK_H12);
	RTC.setHourMode(CLOCK_H24);
	RTC.setDateTime(__DATE__, __TIME__);
	Serial.println("New Time Set");
	Serial.print(__DATE__);
	Serial.print(" ");
	Serial.println(__TIME__);
	RTC.startClock();
//Serial.println("Yes");
Serial.print("-");
Serial.print("-");
Serial.print(" ");
Serial.print(":");
Serial.print(":");
Serial.print("");
case HOUR_AM:
case HOUR_PM:
Serial.println("");
<Arduino:1.8.14 (Windows 10), Board:"DOIT ESP32 DEVKIT V1, 80MHz, 921600, None"
A:\Nieuwe Arduino programmas\DS1307_Adjust_en_printen_OK_OK_Perfect\DS1307_Adjust_en_printen_OK_OK_Perfect.ino: In function 'void setup()':
A:\Nieuwe Arduino programmas\DS1307_Adjust_en_printen_OK_OK_Perfect\DS1307_Adjust_en_printen_OK_OK_Perfect.ino:55:37: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
RTC.setDateTime(DATE, TIME);
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp: In member function 'void DS1307::setHours(uint8_t)':
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp:212:15: warning: unused variable 'meridiem' [-Wunused-variable]
bool h_mode, meridiem;
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp: In member function 'void DS1307::setTime(uint8_t, uint8_t, uint8_t)':
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp:339:15: warning: unused variable 'meridiem' [-Wunused-variable]
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp: In member function 'void DS1307::setEpoch(time_t)':
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp:425:11: warning: unused variable 'year' [-Wunused-variable]
uint16_t year;
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp: In member function 'uint8_t DS1307::getHours()':
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp:208:1: error: control reaches end of non-void function [-Werror=return-type]
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS3231.cpp: In member function 'uint8_t DS3231::getHours()':
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS3231.cpp:256:1: error: control reaches end of non-void function [-Werror=return-type]
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp: In member function 'void DS1307::setDateTime(char*, char*)':
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp:406:10: warning: 'month' may be used uninitialized in this function [-Wmaybe-uninitialized]
setMonth(month);
cc1plus.exe: some warnings being treated as errors
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS3231.cpp: In member function 'void DS3231::setDateTime(char*, char*)':
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS3231.cpp:508:10: warning: 'month' may be used uninitialized in this function [-Wmaybe-uninitialized]
setMonth(month);
exit status 1
Fout bij het compileren voor board DOIT ESP32 DEVKIT V1
Dit rapport zou meer informatie bevatten met
"Uitgebreide uitvoer weergeven tijden compilatie"
optie aan in Bestand -> Voorkeuren.
Further to my earlier question, hee's the full extended error report:
(<Arduino:1.8.14 (Windows 10), Board:"DOIT ESP32 DEVKIT V1, 80MHz, 921600, None"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Ik\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Ik\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries A:\Nieuwe Arduino programmas\libraries -fqbn=esp32:esp32:esp32doit-devkit-v1:FlashFreq=80,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10814 -build-path C:\Users\Ik\AppData\Local\Temp\arduino_build_732989 -warnings=all -build-cache C:\Users\Ik\AppData\Local\Temp\arduino_cache_393343 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -verbose A:\Nieuwe Arduino programmas\DS1307_Adjust_en_printen_OK_OK_Perfect\DS1307_Adjust_en_printen_OK_OK_Perfect.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Ik\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Ik\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries A:\Nieuwe Arduino programmas\libraries -fqbn=esp32:esp32:esp32doit-devkit-v1:FlashFreq=80,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10814 -build-path C:\Users\Ik\AppData\Local\Temp\arduino_build_732989 -warnings=all -build-cache C:\Users\Ik\AppData\Local\Temp\arduino_cache_393343 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -verbose A:\Nieuwe Arduino programmas\DS1307_Adjust_en_printen_OK_OK_Perfect\DS1307_Adjust_en_printen_OK_OK_Perfect.ino
Using board 'esp32doit-devkit-v1' from platform in folder: C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
Using core 'esp32' from platform in folder: C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
cmd /c if exist "A:\Nieuwe Arduino programmas\DS1307_Adjust_en_printen_OK_OK_Perfect\partitions.csv" copy /y "A:\Nieuwe Arduino programmas\DS1307_Adjust_en_printen_OK_OK_Perfect\partitions.csv" "C:\Users\Ik\AppData\Local\Temp\arduino_build_732989\partitions.csv"
cmd /c if not exist "C:\Users\Ik\AppData\Local\Temp\arduino_build_732989\partitions.csv" copy "C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\tools\partitions\default.csv" "C:\Users\Ik\AppData\Local\Temp\arduino_build_732989\partitions.csv"
Detecting libraries used...
"C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10814 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="doitESP32devkitV1"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\doitESP32devkitV1" "C:\Users\Ik\AppData\Local\Temp\arduino_build_732989\sketch\DS1307_Adjust_en_printen_OK_OK_Perfect.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0.1]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0.1]
"C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10814 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="doitESP32devkitV1"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\doitESP32devkitV1" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "C:\Users\Ik\AppData\Local\Temp\arduino_build_732989\sketch\DS1307_Adjust_en_printen_OK_OK_Perfect.ino.cpp" -o nul
Alternatives for RTC.h: [RTC-1.0.1@1.0.1]
ResolveLibrary(RTC.h)
-> candidates: [RTC-1.0.1@1.0.1]
"C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10814 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="doitESP32devkitV1"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\doitESP32devkitV1" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IA:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src" "C:\Users\Ik\AppData\Local\Temp\arduino_build_732989\sketch\DS1307_Adjust_en_printen_OK_OK_Perfect.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src\Wire.cpp
"C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10814 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="doitESP32devkitV1"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\doitESP32devkitV1" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IA:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src" "A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp" -o nul
"C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10814 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="doitESP32devkitV1"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\doitESP32devkitV1" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IA:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src" "A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS3231.cpp" -o nul
Using cached library dependencies for file: A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DateTime.cpp
Using cached library dependencies for file: A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\PCF8563.cpp
Generating function prototypes...
"C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10814 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="doitESP32devkitV1"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\doitESP32devkitV1" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IA:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src" "C:\Users\Ik\AppData\Local\Temp\arduino_build_732989\sketch\DS1307_Adjust_en_printen_OK_OK_Perfect.ino.cpp" -o "C:\Users\Ik\AppData\Local\Temp\arduino_build_732989\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Ik\AppData\Local\Temp\arduino_build_732989\preproc\ctags_target_for_gcc_minus_e.cpp"
Sketch aan het compileren...
"C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -Wall -Werror=all -Wextra -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10814 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="doitESP32devkitV1"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\doitESP32devkitV1" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IA:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src" "C:\Users\Ik\AppData\Local\Temp\arduino_build_732989\sketch\DS1307_Adjust_en_printen_OK_OK_Perfect.ino.cpp" -o "C:\Users\Ik\AppData\Local\Temp\arduino_build_732989\sketch\DS1307_Adjust_en_printen_OK_OK_Perfect.ino.cpp.o"
A:\Nieuwe Arduino programmas\DS1307_Adjust_en_printen_OK_OK_Perfect\DS1307_Adjust_en_printen_OK_OK_Perfect.ino: In function 'void setup()':
A:\Nieuwe Arduino programmas\DS1307_Adjust_en_printen_OK_OK_Perfect\DS1307_Adjust_en_printen_OK_OK_Perfect.ino:55:37: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
RTC.setDateTime(DATE, TIME);
Compiling libraries...
Compiling library "Wire"
Vorige gecompileerde bestand C:\Users\Ik\AppData\Local\Temp\arduino_build_732989\libraries\Wire\Wire.cpp.o wordt gebruikt.
Compiling library "RTC-1.0.1"
"C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -Wall -Werror=all -Wextra -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10814 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="doitESP32devkitV1"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\doitESP32devkitV1" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IA:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src" "A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp" -o "C:\Users\Ik\AppData\Local\Temp\arduino_build_732989\libraries\RTC-1.0.1\DS1307.cpp.o"
"C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -Wall -Werror=all -Wextra -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10814 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="doitESP32devkitV1"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\doitESP32devkitV1" "-IC:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\Wire\src" "-IA:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src" "A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS3231.cpp" -o "C:\Users\Ik\AppData\Local\Temp\arduino_build_732989\libraries\RTC-1.0.1\DS3231.cpp.o"
Vorige gecompileerde bestand C:\Users\Ik\AppData\Local\Temp\arduino_build_732989\libraries\RTC-1.0.1\DateTime.cpp.o wordt gebruikt.
Vorige gecompileerde bestand C:\Users\Ik\AppData\Local\Temp\arduino_build_732989\libraries\RTC-1.0.1\PCF8563.cpp.o wordt gebruikt.
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp: In member function 'void DS1307::setHours(uint8_t)':
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp:212:15: warning: unused variable 'meridiem' [-Wunused-variable]
bool h_mode, meridiem;
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp: In member function 'void DS1307::setTime(uint8_t, uint8_t, uint8_t)':
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp:339:15: warning: unused variable 'meridiem' [-Wunused-variable]
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp: In member function 'void DS1307::setEpoch(time_t)':
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp:425:11: warning: unused variable 'year' [-Wunused-variable]
uint16_t year;
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp: In member function 'uint8_t DS1307::getHours()':
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp:208:1: error: control reaches end of non-void function [-Werror=return-type]
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS3231.cpp: In member function 'uint8_t DS3231::getHours()':
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS3231.cpp:256:1: error: control reaches end of non-void function [-Werror=return-type]
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp: In member function 'void DS1307::setDateTime(char*, char*)':
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS1307.cpp:406:10: warning: 'month' may be used uninitialized in this function [-Wmaybe-uninitialized]
setMonth(month);
cc1plus.exe: some warnings being treated as errors
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS3231.cpp: In member function 'void DS3231::setDateTime(char*, char*)':
A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1\src\DS3231.cpp:508:10: warning: 'month' may be used uninitialized in this function [-Wmaybe-uninitialized]
setMonth(month);
Bibliotheek Wire op versie 1.0.1 in map: C:\Users\Ik\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\Wire wordt gebruikt
Bibliotheek RTC-1.0.1 op versie 1.0.1 in map: A:\Nieuwe Arduino programmas\libraries\RTC-1.0.1 wordt gebruikt
exit status 1
Fout bij het compileren voor board DOIT ESP32 DEVKIT V1
OMG what a H U U U U G E text.
re-edit your post in this way:
put the error-messages into the clipboard
click the
button which creates the begin and end of a code-section. Paste clipboard-content through pressing Ctrl-V
For your own investigation search for
": error:" double-point-space-error-double-point
to find the really relevant lines in the error-messages
best regards Stefan
You're absolutely right. I'm (although not with Arduino and ESP) a beginner when it comes to using this forum.
This may sound sturpid, but I have no </> button. What I tried is < Ctrl-V >, and </ Ctrl-V />, and </> Ctrl-V </>, but for whatever reason the first part of the program does not want to fit in.
it is the fragment below that refuses to fit in:
<//LET OP: gelijkzetten van de klok: gebruik if (!RTC.isRunning())
//LET OP: aflezen van de klok: gebruik if (RTC.isRunning())
#include <Wire.h>
#include <RTC.h>
static DS1307 RTC;
RTC.begin();
See the first lines of my original question, above, where this problem popped up.
So, please, before we come to the problem in my question, how do I decently include a program in the format the Forum uses?
Thanks for your help,
Ron
Hi don't "care-about-my-user-name",
alternatively yould write three accent graves ``` in the line above the code and below the code or write [ code ] [/ code ]
(without the spaces if you want to insert error-messages as a code-section.
For a real sketch
There is an automatic function for doing this in the Arduino-IDE
just three steps
  1. press Ctrl-T for autoformatting your code
  2. do a rightclick with the mouse and choose "copy for forum"
  3. paste clipboard into write-window of a posting
best regards Stefan
Dear Stefan,
Thanks, now I realise which button you were aiming at.
I feel a bit ashamed to say, but it seems that my problem is solved in the meantime.
As I said, I re-installed the Arduino IDE three times over, removed the library etcetera, but apparently there were one or more small files left. This morning I have really whiped out each and every file that could possibly refer to Arduino, again re-installed Arduino and much to my surprise (and happyness) the system now runs perfect again.
Once again, I'm sorry that I've bothered you and the Forum with this problem that after all could be solved by myself. But for the future, I'll certainly keep your information about how to submit listings in a question to the forum.
Once again, thanks for your kind help,
Best regards,
Ron.
Hi 2397,
you're welcome. Sometimes we all have tomatos
(or microcontrollers ) on the eyes. ;-))
best regards Stefan
