ESP32, I wrote these functions:
void Display::PrintMessage(String message, bool clear, int offset)
PrintMessage(message.c_str(), clear, offset);
void Display::PrintMessage(const char *message, bool clear, const uint8_t *font, int height, int offset)
if (strlen(message) == 0) return;
if (clear) _u8g2.clearBuffer();
_u8g2.setFont(font);
int w = _u8g2.getStrWidth(message);
int x = (_u8g2.getDisplayWidth() - w) / 2;
int y = _u8g2.getDisplayHeight() / 2 + offset;
_u8g2.setDrawColor(0);
_u8g2.drawBox(0, y - height, _u8g2.getDisplayWidth(), height);
_u8g2.setDrawColor(1);
_u8g2.drawStr(x, y, message);
_u8g2.sendBuffer();
String Languages::GetText(int index)
if (index < _listTranslations.size()) return _listTranslations.get(index);
return String();
where:
MyLinkedList::LinkedList<String> _listTranslations;
Example of usage:
void goHome()
_display.PrintMessage(_languages.GetText(LANG_DISPLAY_HOMING));
state = States::Homing;
I have a lot of similar functions in my code and they work as expected.
Just one of these callings leads to the following exception:
Guru Meditation Error: Core 1 panic'ed (Unhandled debug exception).
Debug exception reason: Stack canary watchpoint triggered (loopTask)
Core 1 register dump:
PC : 0x4010269e PS : 0x00060236 A0 : 0x8010284b A1 : 0x3ffd3700
A2 : 0x3ffd37ac A3 : 0x00000006 A4 : 0x3ffc8658 A5 : 0x00000000
A6 : 0x3ffc8658 A7 : 0xff000000 A8 : 0xa381ee39 A9 : 0x3ffd3860
A10 : 0x3ffc532c A11 : 0x3ffd38ac A12 : 0x00000001 A13 : 0x00000000
A14 : 0x3ffc8658 A15 : 0xff000000 SAR : 0x0000000a EXCCAUSE: 0x00000001
EXCVADDR: 0x00000000 LBEG : 0x40092405 LEND : 0x40092415 LCOUNT : 0xfffffffe
Backtrace: 0x4010269b:0x3ffd3700 0x40102848:0x3ffd3740 0x4010288b:0x3ffd3760 0x40102901:0x3ffd3780 0x400d7dea:0x3ffd37a0 0x400d7df5:0x3ffd37e0 0x400d7df5:0x3ffd3820 0x400d7df5:0x3ffd3860 0x400d7df5:0x3ffd38a0 0x400d7df5:0x3ffd38e0 0x400d7df5:0x3ffd3920 0x400d7df5:0x3ffd3960 0x400d7df5:0x3ffd39a0 0x400d7df5:0x3ffd39e0 0x400d7df5:0x3ffd3a20 0x400d7df5:0x3ffd3a60 0x400d7df5:0x3ffd3aa0 0x400d7df5:0x3ffd3ae0 0x400d7df5:0x3ffd3b20 0x400d7df5:0x3ffd3b60 0x400d7df5:0x3ffd3ba0 0x400d7df5:0x3ffd3be0 0x400d7df5:0x3ffd3c20 0x400d7df5:0x3ffd3c60 0x400d7df5:0x3ffd3ca0 0x400d7df5:0x3ffd3ce0 0x400d7df5:0x3ffd3d20 0x400d7df5:0x3ffd3d60 0x400d7df5:0x3ffd3da0 0x400d7df5:0x3ffd3de0 0x400d7df5:0x3ffd3e20 0x400d7df5:0x3ffd3e60 0x400d7df5:0x3ffd3ea0 0x400d7df5:0x3ffd3ee0 0x400d7df5:0x3ffd3f20 0x400d7df5:0x3ffd3f60 0x400d7df5:0x3ffd3fa0 0x400d7df5:0x3ffd3fe0 0x400d7df5:0x3ffd4020 0x400d7df5:0x3ffd4060 0x400d7df5:0x3ffd40a0 0x400d7df5:0x3ffd40e0 0x400d7df5:0x3ffd4120 0x400d7df5:0x3ffd4160 0x400d7df5:0x3ffd41a0 0x400d7df5:0x3ffd41e0 0x400d7df5:0x3ffd4220 0x400d7df5:0x3ffd4260 0x400d7df5:0x3ffd42a0 0x400d7df5:0x3ffd42e0 0x400d7df5:0x3ffd4320 0x400d7df5:0x3ffd4360 0x400d7df5:0x3ffd43a0 0x400d7df5:0x3ffd43e0 0x400d7df5:0x3ffd4420 0x400d7df5:0x3ffd4460 0x400d7df5:0x3ffd44a0 0x400d7df5:0x3ffd44e0 0x400d7df5:0x3ffd4520 0x400d7df5:0x3ffd4560 0x400d7df5:0x3ffd45a0 0x400d7df5:0x3ffd45e0 0x400d7df5:0x3ffd4620 0x400d7df5:0x3ffd4660 0x400d7df5:0x3ffd46a0 0x400d7df5:0x3ffd46e0 0x400d7df5:0x3ffd4720 0x400d7df5:0x3ffd4760 0x400d7df5:0x3ffd47a0 0x400d7df5:0x3ffd47e0 0x400d7df5:0x3ffd4820 0x400d7df5:0x3ffd4860 0x400d7df5:0x3ffd48a0 0x400d7df5:0x3ffd48e0 0x400d7df5:0x3ffd4920 0x400d7df5:0x3ffd4960 0x400d7df5:0x3ffd49a0 0x400d7df5:0x3ffd49e0 0x400d7df5:0x3ffd4a20 0x400d7df5:0x3ffd4a60 0x400d7df5:0x3ffd4aa0 0x400d7df5:0x3ffd4ae0 0x400d7df5:0x3ffd4b20 0x400d7df5:0x3ffd4b60 0x400d7df5:0x3ffd4ba0 0x400d7df5:0x3ffd4be0 0x400d7df5:0x3ffd4c20 0x400d7df5:0x3ffd4c60 0x400d7df5:0x3ffd4ca0 0x400d7df5:0x3ffd4ce0 0x400d7df5:0x3ffd4d20 0x400d7df5:0x3ffd4d60 0x400d7df5:0x3ffd4da0 0x400d7df5:0x3ffd4de0 0x400d7df5:0x3ffd4e20 0x400d7df5:0x3ffd4e60 0x400d7df5:0x3ffd4ea0 0x400d7df5:0x3ffd4ee0 0x400d7df5:0x3ffd4f20 0x400d7df5:0x3ffd4f60 0x400d7df5:0x3ffd4fa0 |<-CONTINUES
I printed out the heap size and stack watermark just before the call:
Serial.println(esp_get_free_heap_size());
Serial.println(uxTaskGetStackHighWaterMark(NULL));
160156
5856
Changing a bit the code, for example:
_display.PrintMessage("HOMING");
_languages.GetText(LANG_DISPLAY_HOMING); // useless, but just to test the function
leads to a normal behavior, i.e. no reboot.
It's the first time I'm facing such an issue. I tried to read here and there on the web but I found few hints about increasing the stack size, but before going further in this direction I would like to ask here what should I do to find out the root cause of the exception.
