Hello, I am very new to programming and would like to learn more. I have a sketch here to move a stepper on way slowly and then back the other way slowly.
int Pin0 = 8;//definition digital 8 pins as pin to control the IN1 (ULN24L01)
int Pin1 = 9;//definition digital 9 pins as pin to control the IN2 (ULN24L01)
int Pin2 = 10;//definition digital 10 pins as pin to control the IN3 (ULN24L01)
int Pin3 = 11;//definition digital 11 pins as pin to control the IN4 (ULN24L01)
int _step = 512;
int _speed = 1;
pinMode(Pin0, OUTPUT);//Set digital 8 port mode, the OUTPUT for the output
pinMode(Pin1, OUTPUT);//Set digital 9 port mode, the OUTPUT for the output
pinMode(Pin2, OUTPUT);//Set digital 10 port mode, the OUTPUT for the output
pinMode(Pin3, OUTPUT);//Set digital 11 port mode, the OUTPUT for the output
Speed(15);//Stepper motor speed = 15 fast (note:speed from 1 to 15)
Step(512);//Stepper motor forward 512 steps ---- 360 angle
delay(2000);// delay 2S
Speed(1); //Stepper motor speed = 1 slow (note:speed from 1 to 15)
Step(-512);//Stepper motor backward 512 steps ---- 360 angle
delay(2000);//delay 2S
void Speed(int stepperspeed)//set Stepper speed
_speed = 15 - stepperspeed;
if( _speed<1){
_speed = 1;
if( _speed>15){
_speed = 15;
void Step(int _step)//Stepper motor rotation
if(_step>=0){ // Stepper motor forward
for(int i=0;i<_step;i++){
setStep(1, 0, 0, 1);
delay(_speed);
setStep(1, 0, 0, 0);
delay(_speed);
setStep(1, 1, 0, 0);
delay(_speed);
setStep(0, 1, 0, 0);
delay(_speed);
setStep(0, 1, 1, 0);
delay(_speed);
setStep(0, 0, 1, 0);
delay(_speed);
setStep(0, 0, 1, 1);
delay(_speed);
setStep(0, 0, 0, 1);
delay(_speed);
}else{ // Stepper motor backward
for(int i=_step;i<0;i++){
delay(_speed);
delay(_speed);
delay(_speed);
delay(_speed);
delay(_speed);
delay(_speed);
delay(_speed);
delay(_speed);
void setStep(int a, int b, int c, int d)
digitalWrite(Pin0, a);
digitalWrite(Pin1, b);
digitalWrite(Pin2, c);
digitalWrite(Pin3, d);
This code does work, but i want it to spin at full speed(15) in just one direction continuously . I have tried taking different parts of the code out but cannot get it to compile. Some help would be greatly appreciated.
