I have a nifty ISD1760 break-out board. It uses the ISD1760 28-DIP and brings most everything you need out to pins that can be easily connected to the Arduino.
It is marked YL-65, googling will turn up the usual sources. Inexpensive!
After tiring of using the on-board buttons I looked around for some code to use with its SPI functionality.
In these forums I found an old but very useful thread and a good example sketch, viz:
In fact, most code I found seems to have inherited form and shape from this early example. Unfortunately they inherited a bit of an error also. An error the compiler might catch and read something like
/var/folders/gz/t92bgl156gdf2066kn0xpc7w0000gq/T/arduino_modified_sketch_981957/myISD.ino: In function 'ready_wait()':
/var/folders/gz/t92bgl156gdf2066kn0xpc7w0000gq/T/arduino_modified_sketch_981957/myISD.ino:99:19: warning: 'byte3' is used uninitialized in this function [-Wuninitialized]
counter = byte1 + byte2 + byte3;
But I had to go out of my way to get provoke this message. The original error (use of uninitialized variable ) goes unremarked.
I found the error the old fashioned way. I think much of the difficulty and random problems people have had working with might be traced to this error.
Here is the fixed-up original example. It has a “ready_wait” function that actually works - I just changed a while to a do/while. I also adds ready_waiting after the FWD.
Of course time is just wasted in ready_wait, but that’s a matter for another day. With this sketch one can test and sort out all the pieces.
original code from this thread
http://forum.arduino.cc/index.php?topic=38867.0
powers up the 1700
plays from the current pointer on the chip memory
waits until the sample is done
forwards to next recording
loops
here with an improved ready_wait()
//define pins
#define DATAOUT 11 //mosi
#define DATAIN 12 //miso
#define SPICLOCK 13 //sck
#define SLAVESELECT 10 //ss
//opcodes
#define PU 0x01
#define STOP 0x02
#define RESET 0x03
#define CLR_INT 0x04
#define RD_STATUS 0x05
#define RD_PLAY_PTR 0x06
#define PD 0x07
#define RD_REC_PTR 0x08
#define DEVID 0x09
#define PLAY 0x40
#define REC 0x41
#define ERASE 0x42
#define G_ERASE 0x43
#define RD_APC 0x44
#define WR_APC1 0x45
#define WR_APC2 0x65
#define WR_NVCFG 0x46
#define LD_NVCFG 0x47
#define FWD 0x48
#define CHK_MEM 0x49
#define EXTCLK 0x4A
#define SET_PLAY 0x80
#define SET_REC 0x81
#define SET_ERASE 0x82
byte clr;
pinMode(DATAOUT, OUTPUT);
pinMode(DATAIN, INPUT);
pinMode(SPICLOCK, OUTPUT);
pinMode(SLAVESELECT, OUTPUT);
digitalWrite(SLAVESELECT, HIGH); //disable device
SPCR = B01111111; //data lsb, clock high when idle, samples on falling
clr = SPSR;
clr = SPDR;
delay(10);
digitalWrite(SLAVESELECT, LOW);
spi_transfer(PU); // power up
spi_transfer(0x00); // data byte
delay(100);
spi_transfer(CLR_INT); // clear interupt and eom bit
Serial.println("...setup");
spi_transfer(PLAY);
spi_transfer(0x00);
ready_wait();
spi_transfer(FWD); // ?? clear interupt and eom bit
ready_wait();
void ready_wait() {
int counter;
byte byte3;
counter = 0;
do {
counter++;
spi_transfer(RD_STATUS);
spi_transfer(0x00);
byte3 = spi_transfer(0x00);
} while (byte3 << 7 != 128);
// Serial.println(counter);
// delay(100);
char spi_transfer(volatile char data)
SPDR = data; // Start the transmission
while (!(SPSR & (1 << SPIF))) // Wait for the end of the transmission
return SPDR; // return the received byte
alto777
