uninterrupted transmission of large amounts of data via the serial interface
uninterrupted transmission of large amounts of data via the serial interface. I try to transfer a string (5x3x100 = 1500 characters). But sometimes the Transmission ends in the middel of the String. And the String is transmitted in 2 or more parts. I want to send the String in one Transmission.
My code:
//INCLUDES
#include "Tlc5940.h"
//DEFINMES
#define CHANNELS 16
//Variablen
  //Daten
  int offset;
  //TLC5940
  int data[NUM_TLCS * CHANNELS];
  int value;
  //Serial
  char inputBuffer[4];         // a string to hold incoming data
  int dataPointer;
  int inputBufferPointer;
  boolean transmissionCompleted = false;  // whether the string is complete
//INITIALISIERUNGEN
  Tlc.init();
  Serial.begin(57600);
//HAUPTPROGRAMM
  //Set to TLC5940
  //Tlc.clear();
  if( transmissionCompleted ){
    for( int currentDevice = 0; currentDevice < 3; currentDevice++ ){
      for( int channel = 0; channel < CHANNELS * NUM_TLCS; channel++ ){
        Tlc.set(channel, data[channel]);
    Tlc.update();
void serialEvent() {
  while (Serial.available()) {
    // get the new byte:
    char receivedChar = (char)Serial.read();
    //suche nach Trennzeichen
    if( receivedChar == ',' ||  receivedChar == '\n' ) {
      char * PointerOfInputBuffer = inputBuffer;      //inputBufferPointer auf gefundene Zahl erzeugen
      data[dataPointer] = atoi(PointerOfInputBuffer); //Zahl in Form von String in Integer umwandeln
      inputBuffer[0] = 0;                             //Buffer löschen
      inputBuffer[1] = 0;                             //Buffer löschen
      inputBuffer[2] = 0;                             //Buffer löschen
      inputBuffer[3] = 0;                             //Buffer löschen
      dataPointer++;
      inputBufferPointer = 0;
    //kein trennzeichen gefunden
    else {
      inputBuffer[inputBufferPointer] = receivedChar;
      inputBufferPointer++;
    //restliche werte 0 setzen
    for( int i = dataPointer; i < (NUM_TLCS * CHANNELS); i++ ) data[i] = 0;
    if (receivedChar == '\n') {
      transmissionCompleted = true;
      String output;
    output += "<UPDATE>";
    for(int i = 0; i < CHANNELS * NUM_TLCS; i++){
      char buff[12];
      output += itoa(data[i],buff,10);
      output += ",";
    output += "</UPDATE>";
    Serial.print(output);
    Serial.write(3);
      dataPointer = 0;
The String is generated and send here:
String output;
      char buff[12];
      output += ",";
    Serial.write(3);
How can I solve this problem?
Don't use String
how should I send the data?
One byte at a time. I don't see what using String achieves.
Depending on your definition of "uninterrupted", the answer ranges from "not possible" to "piece of cake".
I am receiving the data for the arduino in a java software using an rxtx libary. sometimes the transmission is devided. that's what i mean with interruped.
I don't see why the data has to be transmitted by a single call to Serial.print. You've got over one and a half milliseconds between characters.
So? Put an end-of-record marker on the end of the stream of data sent, and read data until that marker has arrived.
There is no way, using a 64 byte buffer, to send 1500 characters "at once". Not that it makes sense to even try.
solved
Thanks for sharing your solution.
I used the idea from PaulS
