Union Of Bitfields
Hello!
I have a question regarding bitfields. Say I wanted a struct, "Color," that represents a 16 - bit color. It would look something like this:
struct Color{
  uint16_t color=0;
Now, instead, I would like to represent the R,G, and B fields (in RGB565 format). Now, the code looks something like this:
struct Color{
  byte r : 5, g : 6, b : 5;
Now, say I would like both representations. The code that should do this is here:
struct Color{
  union{
    struct{
    uint16_t color;
But sadly, this does not work as intended (the fields r, g, and b are not public).
How do I do this correctly? of course, I could manually calculate the 16 bit representation, but it would be faster to just use the raw data (which should already be in RGB ordering!)
Thanks!
Fuzzyzilla:
struct Color{
  union{
    struct{
    uint16_t color;
static Color c1;
void setup( void )
  c1.color = 0;
  c1.r = 13;
  c1.g = 13;
  c1.b = 13;
void loop( void ) { }
Sketch uses 456 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 11 bytes (0%) of dynamic memory, leaving 2037 bytes for local variables. Maximum is 2048 bytes.
They are public.
Whoops! Stupid mistake. I forgot to put a semicolon after the union declaration, causing an error.
Ok, works as expected! Sorry!
