Union of two programmes
Good morning everyone, to speed things up I’ll give you a brief summary of the problem I have. I have two programs that if loaded separately work and do what I want, the problem now is to put them together in a single program. The first program is used to read incoming messages with the Sim800L, the other sends a signal to a solar controller to turn it on and off. The idea would be to send a message ON or OFF and Arduino turns the controller on and off.
I tried to do that:
#include <ModbusMaster.h>
#define MAX485_DE      10
#define MAX485_RE_NEG  11
// instantiate ModbusMaster object
ModbusMaster node;
void preTransmission()
  digitalWrite(MAX485_RE_NEG, 1);
  digitalWrite(MAX485_DE, 1);
void postTransmission()
  digitalWrite(MAX485_RE_NEG, 0);
  digitalWrite(MAX485_DE, 0);
char incomingByte;
String inputString;
int relay = 13; // Output for Relay Control
       pinMode(MAX485_RE_NEG, OUTPUT);
  pinMode(MAX485_DE, OUTPUT);
  // Init in receive mode
  // Modbus communication runs at 115200 baud
  Serial2.begin(115200);
  // Modbus slave ID 1
  node.begin(1, Serial2);
  // Callbacks allow us to configure the RS485 transceiver correctly
  node.preTransmission(preTransmission);
  node.postTransmission(postTransmission);
      pinMode(relay, OUTPUT);
      digitalWrite(relay, LOW); // Initial state of the relay
      Serial1.begin(9600);
     while(!Serial1.available()){
        Serial1.println("AT");
        Serial.println("Connecting...");
      Serial.println("Connected!");
      Serial1.println("AT+CMGF=1");  //Set SMS to Text Mode
      Serial1.println("AT+CNMI=1,2,0,0,0");  //Procedure to handle newly arrived messages(command name in text: new message indications to TE)
      Serial1.println("AT+CMGL=\"REC UNREAD\""); // Read Unread Messages
     bool state = true;
  if(Serial1.available()){
      delay(100);
      // Serial Buffer
      while(Serial1.available()){
        incomingByte = Serial1.read();
        inputString += incomingByte;
        delay(10);
        Serial.println(inputString);
        inputString.toUpperCase(); // Uppercase the Received Message
        //turn RELAY ON or OFF
        if (inputString.indexOf("ON") > -1){
          digitalWrite(relay, HIGH);
          uint8_t result;
          uint16_t data[6];
           // Toggle the coil at address 0x0002 (Manual Load Control)
          result = node.writeSingleCoil(0x0002, state);
          state = !state;
         if (inputString.indexOf("OFF") > -1){
          uint8_t result;
          uint16_t data[6];
          state = !state;
        delay(50);
        //Delete Messages & Save Memory
        if (inputString.indexOf("OK") == -1){
        Serial1.println("AT+CMGDA=\"DEL ALL\"");
        delay(1000);}
        inputString = "";
As you can see, I only joined the two programs and I inserted the command to turn on the controller under ON and OFF, unfortunately this does not work …
This is what I read on the Serial Monitor:
Connecting...
Connected!
AT
OK
AT+CMGF=1
OK
AT+CNMI=1,2,0,0,0
OK
AT+CMGL="REC U
In Attachment I put the two programs so if someone wants to help me has the two programs working. Hoping for help I wish everyone a good day :slight_smile:
MegaLetturaSMS.ino (1.56 KB)
AccendiSpegniMega2560.ino (2.2 KB)
You can’t use Serial for both Modbus and debugging. Here I have moved Modbus to Serial2. You will have to move the wiring of your Modbus interface chip.
ModbusMaster node;
char incomingByte;
String inputString;
  while (!Serial1.available())
  if (Serial1.available())
    delay(100);
    // Serial Buffer
    while (Serial1.available())
    delay(10);
      node.writeSingleCoil(0x0002, HIGH);
      node.writeSingleCoil(0x0002, LOW);
    delay(50);
    inputString = "";
  We're using a MAX485-compatible RS485 Transceiver.
  Rx/Tx is hooked up to the hardware serial port at 'Serial'.
  The Data Enable and Receiver Enable pins are hooked up as follows:
Thank you so much for your help, I tried the program and it works :slight_smile:
