Unipolar motor circuit
Hello people.
I have pulled a small fan from an old usb laptop cooler and I need to connect it to my arduino.
When I connect it directly to 5v it works as expected. But I need to control the speed of the motor/fan. To accomplish this I've connected it to a bipolar transistor(P2N2222A) and to pin 13 (for testing, I will use PWM) but it doesn't seem to work.
Anybody have any suggestions?
I did managed to get it working. I'm using this schematic
Instead of of a flyback diode I'm using regular LED. I know that this not the best practice but I need it for a project due in a few days and I can't get my hands on one in that short period of time. What is the worst that can happen wile using an LED? Are there alternatives to a diode?
Try 180 ohm, not 2k2. You want the transistor to be in saturation.
Smallest I have is 1k That will have to do.
You want the transistor to saturate to use it as a switch.
Antonio144:
That's NOT the way things work.
If you have more 1K's, then you could put them in parallel for value (5 in parallel = 200ohms).
If all you have is one 1k resistor then
You can try connecting collector to 5V, put pin 13 to the base without a resistor, and place the motor between emitter and Gnd.
You still need that diode, an LED isn't a substitute (alternative.)
The worst thing that can happen: knock out your transistor and maybe your pin 13 with it.
Several hours later now and no replies.
He mentioned it's a fan from a laptop cooler, so probably a brushless fan / internal driver. Why he used "unipolar motor" in the subject is of course ... odd.
Chagrin:
Wouldn't be the first time that anyone used a jumble of terms about whatever it is and I was just anticipating "the worst", no matter what, as closely as I thought to approximate such.
