Arduino: 1.6.7 Hourly Build 2015/11/13 05:42 (Windows 8.1), Board: “Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)”
Warning: platform.txt from core ‘Arduino AVR Boards’ contains deprecated recipe.preproc.macros="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} {preproc.macros.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.cpp.extra_flags} {build.extra_flags} {includes} “{source_file}”, automatically converted to recipe.preproc.macros="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} {preproc.macros.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.cpp.extra_flags} {build.extra_flags} {includes} “{source_file}” -o “{preprocessed_file_path}”. Consider upgrading this core.
Warning: platform.txt from core ‘Arduino i586 Boards’ contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} “{build.path}/{archive_file}” “{object_file}”, automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} “{archive_file_path}” “{object_file}”. Consider upgrading this core.
Board Intel:i586:izmir_fd doesn’t define a ‘build.board’ preference. Auto-set to: I586_IZMIR_FD
Board Intel:i586:izmir_fg doesn’t define a ‘build.board’ preference. Auto-set to: I586_IZMIR_FG
WARNING: Category ‘’ in library OneWire is not valid. Setting to ‘Uncategorized’
Sketch uses 1,518 bytes (0%) of program storage space. Maximum is 253,952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8,183 bytes for local variables. Maximum is 8,192 bytes.
avrdude: ser_open(): can’t open device “\.\COM11”: The system cannot find the file specified.
avrdude: ser_drain(): read error: The handle is invalid.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I have my Arduino Mega 2560 in COM11 and when I test it to other computers, it is working fine. I have a problem with this even with Arduino Galileo. I think it’s because of the software or I installed it in a wrong way. Help me :(( I need this to solve by this week… I tried to reinstall it but it doesn’t work.
In addition, my codes were like this:
void setup(){
pinMode(13, OUTPUT);
void loop(){
digitalWrite(13, HIGH);
delay(300);
digitalWrite(13, LOW);
delay(300);
