Vorrei imparare ad unire gli scketch... spero che qualcuno mi possa instradare.
Nel particolare devo unire
. scketch DHT11
int pin=4;
DHT11 dht11(pin);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
int err;
float temp, humi;
if((err=dht11.read(humi, temp))==0)
Serial.print("temperature:");
Serial.print(temp);
Serial.print(" humidity:");
Serial.print(humi);
Serial.print("Error No :");
Serial.print(err);
delay(DHT11_RETRY_DELAY); //delay for reread
. sketch DS18B20
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices
// (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
void setup(void)
// start serial port
Serial.println("Dallas Temperature IC Control Library Demo");
// Start up the library
sensors.begin();
void loop(void)
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
Serial.print(" Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
Serial.print("Temperature for Device 1 is: ");
Serial.print(sensors.getTempCByIndex(0)); // Why "byIndex"?
// You can have more than one IC on the same bus.
// 0 refers to the first IC on the wire
in rete si trovano discussioni... ad esempio Unire due sketch - Software - Arduino Forum
ma non spiega come fare ... datemi una mano a capire anche con link vari
grazie... forse era meglio postarlo nella sezione software....
