Using PlatformIO on Windows10 I have been building a project for the Adafruit Huzzah breakout board which uses an ESP-12 device.
Now I want to build it for an ESP-07S device because it has a WiFi antenna connector. The reason is that the on-board antenna is not sensitive enough so I need an external antenna. Otherwise the project works fine on the Huzzah.
So I have created a new environment setting for it by copying the original and replacing the board designator as follows (from my platformio.ini file):
[env:esp07s-serial]
platform = espressif8266@2.5.2
board = esp07s
;board_build.flash_mode = dout
framework = arduino
lib_deps =
tzapu/WiFiManager@^0.16.0
knolleary/PubSubClient@^2.8
paulstoffregen/OneWire@^2.3.7
milesburton/DallasTemperature@^3.11.0
arduino-libraries/NTPClient@^3.2.1
upload_speed = 115200
upload_port = COM4
monitor_speed = 115200
monitor_port = COM4
But what happens is that when I hit build for this environment it complains as follows:
Executing task: C:\Users\Bosse\.platformio\penv\Scripts\platformio.exe run --environment esp07s-serial
Processing esp07s-serial (platform: espressif8266@2.5.2; board: esp07s; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
Error: Unknown board ID 'esp07s'
I have no idea why this happens, the board is part of the Espressif framework as far as I can understand, so what can I do to get this to work?
