Unknown Error for compiling my code onto my Arduino/Genuino Uno
While searching for a code to run a joystick that I purchased as my mouse I stumbled upon this code
#include <mouse.h>
// set pin numbers for switch, joystick axes, and LED:
const int switchPin = 2;      // switch to turn on and off mouse control
const int mouseButton = 3;    // input pin for the mouse pushButton
const int xAxis = A0;         // joystick X axis
const int yAxis = A1;         // joystick Y axis
const int ledPin = 5;         // Mouse control LED
// parameters for reading the joystick:
int range = 12;               // output range of X or Y movement
int responseDelay = 5;        // response delay of the mouse, in ms
int threshold = range / 4;    // resting threshold
int center = range / 2;       // resting position value
boolean mouseIsActive = false;    // whether or not to control the mouse
int lastSwitchState = LOW;        // previous switch state
  pinMode(switchPin, INPUT);       // the switch pin
  pinMode(ledPin, OUTPUT);         // the LED pin
  // take control of the mouse:
  Mouse.begin();
  // read the switch:
  int switchState = digitalRead(switchPin);
  // if it's changed and it's high, toggle the mouse state:
  if (switchState != lastSwitchState) {
    if (switchState == HIGH) {
      mouseIsActive = !mouseIsActive;
      // turn on LED to indicate mouse state:
      digitalWrite(ledPin, mouseIsActive);
  // save switch state for next comparison:
  lastSwitchState = switchState;
  // read and scale the two axes:
  int xReading = readAxis(A0);
  int yReading = readAxis(A1);
  // if the mouse control state is active, move the mouse:
  if (mouseIsActive) {
    Mouse.move(xReading, yReading, 0);
  // read the mouse button and click or not click:
  // if the mouse button is pressed:
  if (digitalRead(mouseButton) == HIGH) {
    // if the mouse is not pressed, press it:
    if (!Mouse.isPressed(MOUSE_LEFT)) {
      Mouse.press(MOUSE_LEFT);
  // else the mouse button is not pressed:
  else {
    // if the mouse is pressed, release it:
    if (Mouse.isPressed(MOUSE_LEFT)) {
      Mouse.release(MOUSE_LEFT);
  delay(responseDelay);
  reads an axis (0 or 1 for x or y) and scales the analog input range to a range
  from 0 to <range>
int readAxis(int thisAxis) {
  // read the analog input:
  int reading = analogRead(thisAxis);
  // map the reading from the analog input range to the output range:
  reading = map(reading, 0, 1023, 0, range);
  // if the output reading is outside from the rest position threshold, use it:
  int distance = reading - center;
  if (abs(distance) < threshold) {
    distance = 0;
  // return the distance for this axis:
  return distance;
While everything seems to be in order whenever I try to compile I get an error that says "Error compiling for board Arduino/Genuino Uno."
I will take any help I can get
Thanks
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
I have figured out my issue from before, but wait, there's more.
I fixed the library address and now this error comes up 'Mouse' not found. Does your sketch include the line '#include <Mouse.h>'? I have tried to take out the library and put it in somewhere else but nothing seems to work.
As with last time, any advice is good advice.
Heres the code
#include <Mouse.h>
  Mouse.begin();
  // read the switch:
  else {
Moderator edit:
tags added.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Your code may have been written for a different model Arduino, check the source, it should tell you what Arduino it was ,meant for.
The fact that it is trying to emulate a USB mouse means it is not a UNO code.
Possibly a Leonardo.
Tom... :slight_smile:
thank you, I appreciate it
Threads merged.
