Unknown LCD-Display
Hi!
I've found a nice little LCD-Dispaly in an old glucose-meter, which I'd like to use which one of my projects.
The display is connected to the PCB by 6 wires. As there are no markings or numbers on the LCD, I don't know how these wires are connected. I figured it must use some kind of SPI or i2c protocol to communicate... So I tried to analyse the connections with my arduino using this simple sketch:
  Serial.begin (15200);
  Serial.println (analogRead(1));
And this was what I measured:
pin1: 1023 (obvioulsy VCC)
pin2: 0 (Ground)
pin3: continously 550
pin4: continously 330
pin5: continously 550
pin6: continously 120
I expected to find at least one pin, where the voltage would regularily alternate between 0 and 1023 (serial clock). But the voltages don't alternate at all... :o
Did I make a mistake somewhere or can someone think of another way to find out how to communicate with that display?
If those pins are digital pins, not analog, then using 'analogRead()' will not tell you very much. Have you tried reading them with a digital input pin? You may need to read all of them simultaneously, rather like a logic analyser.
Well, I found out, that most of these LCD controller-ics have a typical clock frequency of ~60MHz and as Arduino runs on 16MHz, I think it's to slow to analyse those pins...
I think I won't be able to use this LCD after all..
Shame it's too fast to the Arduino. But if you can find out any data on the display, even just a part number, maybe you can find a data sheet, and hence more info about the interface.
What's your source for that information?
--Phil.
