Unknown names (Cellphone Camera conector)
Hello, i need help please, i can´t found information for using a recycled cellphone camera, the conector it´s incompatible, i don´t know how connect the camera to a robot, i don´t know what it is callled this kind of conector, i don´t know what kind of adapter i need, or how to get it, or how much they cost
https://imgur.com/a/wMOys6p
We don’t even know what the hell you’re talking about. You have some sort of phone and some sort of robot and you want to know how to connect them? You don’t think there are any details you might should provide?
Hi Drex,
I think this is the connector that you are looking for. The connectors for cameras are quite standard, so I woudn't be surprised that it is a "CMOS Camera Module - 640x480 - SMD Connector".
But you will need to double check that the distance between the pins is the same for each connector and also the global shape fits, so you will need to measure this by hand. But I am quite confident that if it the connector that I mentioned above!
