Hello,
I've had an issue with my MKR1000 for a few days. It appears as unknown usb device in the USB controllers section of device managers. It should be noted it used to work fine and the last code I uploaded was a simple AnalogRead/Serial.print (see at the end of the post).
What I tried :
-> Connect to the default COM port, upload a basic code (example->basic->serial read) and reset during upload -arduino IDE "couldn't find a board on the selected port" ;
-> Connect it to another computer -still doesn't work ;
-> Use another cable -still doesn't work ;
-> Use another arduino -the other arduino works ;
-> Loop test (RX-TX + GND-RESET) - no change.
Also, it doesn't appear in "Other Device" as "Unknown device", only in the USB controllers section.
I was willing to try to manually update it with ftdiport.inf but I don't know which driver to install ("USB Serial Converter [-/A/B/...]").
I have another card (UNO) for Labview, but I don't want to give up on the MKR.
PS: The arduino was connected to a resistance and a thermistor one after another, the arduino reading the voltage of the thermistor.
Below is the last uploaded code:
Serial.begin(96000);
int AnalogPin = 1, i;
double Duree = 1800; // Mesure sur duree secondes
double N = 1800; // N mesures
double dt = 1000000 * Duree / N; //Mesures toute les dt secondes
double R1 = 10000; // Résistance en série utilisée
double E = 3.3; // Tension d'alimentation
double val; // Valeur lue par AnalogPin
double V; // Conversion en tension
double RT; // Calcul résistance d'intérêt
val = analogRead(AnalogPin);
V = E * (val / 1023);
RT = (R1 * V) / (E - V);
Serial.println(i);
Serial.println(RT);
delayMicroseconds(dt);
