Unkown child and not valid message sub-type errors in HA logs
Arduino Uno
NRF24L01+ radio
simple moisture sensor
I am working with a mysensors sketch, attempting to present it to Home Assistant and getting errors I do not understand. I have asked a similar question on the forums but have not received a response and hoping an arduino expert can point me in the right direction.
Arduino Serial Monitor info:
5235 TSF:MSG:SEND,105-105-0-0,s=0,c=1,t=37,pt=4,l=4,sg=0,ft=0,st=OK:-2
5244 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
5250 TSF:TDI:TSL
5252 MCO:SLP:WUP=-1
5253 TSF:TRI:TSB
10	0	10	10	0	10	0	0	0	0		4
0	0	0	0	0	-10	0	0	0	0		-1
resistance bias =5
sensor bias compensated value = 1
5307 TSF:MSG:SEND,105-105-0-0,s=0,c=1,t=37,pt=4,l=4,sg=0,ft=0,st=OK:1
5316 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
5321 TSF:TDI:TSL
wi-fi-moisture-sensor sketch:
 * The MySensors Arduino library handles the wireless radio link and protocol
 * between your home built sensors/actuators and HA controller of choice.
 * The sensors forms a self healing radio network with optional repeaters. Each
 * repeater and gateway builds a routing tables in EEPROM which keeps track of the
 * network topology allowing messages to be routed to nodes.
 * Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
 * Copyright (C) 2013-2019 Sensnology AB
 * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
 * Documentation: http://www.mysensors.org
 * Support Forum: http://forum.mysensors.org
 * This program is free software; you can redistribute it and/or
 * modify it under the terms of the GNU General Public License
 * version 2 as published by the Free Software Foundation.
 * DESCRIPTION
 * Arduino soil moisture based on gypsum sensor/resistive sensor to avoid electric catalyse in soil
 *  Required to interface the sensor: 2 * 4.7kOhm + 2 * 1N4148
 * Gypsum sensor and calibration:
 *  DIY: See http://vanderleevineyard.com/1/category/vinduino/1.html
 *  Built: Davis / Watermark 200SS
 *    http://www.cooking-hacks.com/watermark-soil-moisture-sensor?_bksrc=item2item&_bkloc=product
 *    http://www.irrometer.com/pdf/supportmaterial/sensors/voltage-WM-chart.pdf
 *    cb (centibar) http://www.irrometer.com/basics.html
 *      0-10 Saturated Soil. Occurs for a day or two after irrigation
 *      10-20 Soil is adequately wet (except coarse sands which are drying out at this range)
 *      30-60 Usual range to irrigate or water (except heavy clay soils).
 *      60-100 Usual range to irrigate heavy clay soils
 *      100-200 Soil is becoming dangerously dry for maximum production. Proceed with caution.
 * Connection:
 * D6, D7: alternative powering to avoid sensor degradation
 * A0, A1: alternative resistance measuring
 *  Based on:
 *  "Vinduino" portable soil moisture sensor code V3.00
 *   Date December 31, 2012
 *   Reinier van der Lee and Theodore Kaskalis
 *   www.vanderleevineyard.com
 * Contributor: epierre
// Copyright (C) 2015, Reinier van der Lee
// www.vanderleevineyard.com
// This program is free software: you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation, either version 3 of the License, or
// any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
// GNU General Public License for more details.
// Enable debug prints to serial monitor
#define MY_DEBUG
// Enable and select radio type attached
#define MY_RADIO_RF24
//#define MY_RADIO_NRF5_ESB
//#define MY_RADIO_RFM69
//#define MY_RADIO_RFM95
#include <math.h>       // Conversion equation from resistance to %
#include <MySensors.h>
// Setting up format for reading 3 soil sensors
#define NUM_READS (int)10   // Number of sensor reads for filtering
#define CHILD_ID 0
MyMessage msg(CHILD_ID, V_LEVEL);
uint32_t SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
long buffer[NUM_READS];
int idx;
/// @brief Structure to be used in percentage and resistance values matrix to be filtered (have to be in pairs)
typedef struct {
  int moisture; //!< Moisture
  long resistance; //!< Resistance
} values;
const long knownResistor = 4700;  // Constant value of known resistor in Ohms
int supplyVoltage;                // Measured supply voltage
int sensorVoltage;                // Measured sensor voltage
values valueOf[NUM_READS];        // Calculated moisture percentages and resistances to be sorted and filtered
int i;                            // Simple index variable
  // initialize the digital pins as an output.
  // Pin 6,7 is for sensor 1
  // initialize the digital pin as an output.
  // Pin 6 is sense resistor voltage supply 1
  pinMode(6, OUTPUT);
  // Pin 7 is sense resistor voltage supply 2
  pinMode(7, OUTPUT);
void presentation()
  sendSketchInfo("Soil Moisture Sensor Reverse Polarity", "1.0");
  present(CHILD_ID, S_MOISTURE);
  measure(6,7,1);
  Serial.print ("\t");
  Serial.println (average());
  long read1 = average();
  measure(7,6,0);
  long read2= average();
  long sensor1 = (read1 + read2)/2;
  Serial.print ("resistance bias =" );
  Serial.println (read1-read2);
  Serial.print ("sensor bias compensated value = ");
  Serial.println (sensor1);
  Serial.println ();
  //send back the values
  send(msg.set((int32_t)ceil(sensor1)));
  // delay until next measurement (msec)
  sleep(SLEEP_TIME);
void measure (int phase_b, int phase_a, int analog_input)
  // read sensor, filter, and calculate resistance value
  // Noise filter: median filter
  for (i=0; i<NUM_READS; i++) {
    // Read 1 pair of voltage values
    digitalWrite(phase_a, HIGH);                 // set the voltage supply on
    delayMicroseconds(25);
    supplyVoltage = analogRead(analog_input);   // read the supply voltage
    digitalWrite(phase_a, LOW);                  // set the voltage supply off
    delay(1);
    digitalWrite(phase_b, HIGH);                 // set the voltage supply on
    sensorVoltage = analogRead(analog_input);   // read the sensor voltage
    digitalWrite(phase_b, LOW);                  // set the voltage supply off
    // Calculate resistance
    // the 0.5 add-term is used to round to the nearest integer
    // Tip: no need to transform 0-1023 voltage value to 0-5 range, due to following fraction
    long resistance = (knownResistor * (supplyVoltage - sensorVoltage ) / sensorVoltage) ;
    delay(1);
    addReading(resistance);
    Serial.print (resistance);
// Averaging algorithm
void addReading(long resistance)
  buffer[idx] = resistance;
  idx++;
  if (idx >= NUM_READS) {
    idx = 0;
long average()
  long sum = 0;
  for (int cnt = 0; cnt < NUM_READS; cnt++) {
    sum += buffer[cnt];
  return (long)(sum / NUM_READS);
Associated HA logs:
2020-02-26 07:47:33 WARNING (MainThread) [mysensors] Not a valid message: Not valid message sub-type: 35 for dictionary value @ data['sub_type']
2020-02-26 07:47:34 WARNING (MainThread) [mysensors] Child 0 is unknown
2020-02-26 07:48:05 WARNING (MainThread) [mysensors] Child 0 is unknown
2020-02-26 07:48:36 WARNING (MainThread) [mysensors] Child 0 is unknown
2020-02-26 07:49:07 WARNING (MainThread) [mysensors] Child 0 is unknown
2020-02-26 07:49:30 WARNING (MainThread) [mysensors] Not a valid message: Not valid message sub-type: 21 for dictionary value @ data['sub_type']
2020-02-26 07:49:38 WARNING (MainThread) [mysensors] Child 0 is unknown
2020-02-26 07:50:09 WARNING (MainThread) [mysensors] Child 0 is unknown
Instead of throwing the entire kitchen sink ask the HA forum how to create a simple project to test out your project.
I don't know anything about HA.
I have several other sensors working in HA. This one is producing errors, so it seems entirely appropriate to ask a question relating to arduino here if I am not finding answers elsewhere.
Can you post the code for one that works?
A member of the mysensors forum discovered the library used needed to be declared simply as version: '2.3' in the HA config, not '2.3.2'.
I can still post the code of the other working sensors (did not need library declared) if that would help someone.
MrHutchinsonMN:
So, nothing to do with Arduino at all ?
Outside of an arduino board and sketch being used, it had nothing to do with arduino
