hi
so I have a UNL2004a darlington array that I´m using to drive a unipolar stepper motor.
I followed the motor knob tutorial on arduino.cc
I have a bench lab power supply that is providing the motor with 2.5v, the current draw is 800ma.
I´m having issues with overheating of the darlington array.
so my question is, is this the current draw too great for the array and if so should I add resistors to prevent it or change to a ready made unipolar motor driver ?
thanks
r.
btw, the motor needs 2.5v and 800ma to run. thats what is specified on it anyway and there are no heating issues with the motor itself.
Each darlington can only drive 500mA, and about 650mA for the package.
See:-
http://www.thebox.myzen.co.uk/Tutorial/Power_Examples.html
You normally run a motor like this with a current regulating chopper driver not a darlington.
You use higher voltage, normally 12 or 24 V.
Like these:-
If you want to drive a low voltage unipolar stepper motor in unipolar mode you
would use MOSFETs, not darlingtons, darlingtons waste 1 to 2V, you only have
2.5V to start with.
Choose logic level MOSFETs with Rds(on) < 0.2 ohms or so and they'll handle it OK.
Choose ones with Rds(on) < 0.04 ohms and they won't even get warm.
You haven't said how many wires the motor is - if its 6 or 8 wires it can be
configured as bipolar and driven via chopper-drive IC. If its 5 wires it cannot and
you are stuck with unipolar drive.
If you have 4-wire motor you are confused!
Don't lots of stepper motors have four wires ?
Like this diagram Pololu - Bipolar stepper motor wiring diagram.
michinyon:
Don't lots of stepper motors have four wires ?Like this diagram Pololu - Bipolar stepper motor wiring diagram.
They do but you can't drive them with simple darlingtons, you need a H-bridge.
