unlocking different locks with one keypad code help needed
Hello i have a problem
i want to unlock two different locks with one keywas to unluck different things with the same keypad
i have this code to make it work with one lock and lcd screen
but how to make this works with two locks i have no idea
(sorry for my inglish)
greetings
dennis
CODE
#include <Wire.h>
#include <Keypad.h>
#define Password_Length 8
int signalPin = 12;
char Data[Password_Length];
char Master[Password_Length] = "123A456";
byte data_count = 0, master_count = 0;
bool Pass_is_good;
char customKey;
const byte ROWS = 4;
const byte COLS = 4;
char hexaKeys[ROWS][COLS] = {
 {'1', '2', '3', 'A'},
 {'4', '5', '6', 'B'},
 {'7', '8', '9', 'C'},
 {'*', '0', '#', 'D'}
byte rowPins[ROWS] = {9, 8, 7, 6};
byte colPins[COLS] = {5, 4, 3, 2};
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
LiquidCrystal_I2C lcd(0x21, 16, 2);
void setup(){
 lcd.init();
 lcd.backlight();
 pinMode(signalPin, OUTPUT);
void loop(){
 lcd.setCursor(0,0);
 lcd.print("Enter Password:");
 customKey = customKeypad.getKey();
 if (customKey){
   Data[data_count] = customKey;
   lcd.setCursor(data_count,1);
   lcd.print(Data[data_count]);
   data_count++;
 if(data_count == Password_Length-1){
   lcd.clear();
   if(!strcmp(Data, Master)){
     lcd.print("Correct");
     digitalWrite(signalPin, HIGH);
     delay(5000);
     digitalWrite(signalPin, LOW);
   else{
     lcd.print("Incorrect");
   lcd.clear();
   clearData();
void clearData(){
 while(data_count !=0){
   Data[data_count--] = 0;
 return;
or i found this one maybe better to change to work with two locks ???
#include <Password.h> //http://playground.arduino.cc/uploads/Code/Password.zip //tells to use password library
#include <Keypad.h> //http://www.arduino.cc/playground/uploads/Code/Keypad.zip  //tells to use keypad library
#include <Servo.h> //tells to use servo library
Servo myservo; //declares servo
Password password = Password( "0000" ); //password to unlock, can be changed
const byte ROWS = 4; // Four rows
const byte COLS = 4; // columns
// Define the Keymap
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = { 9, 8, 7, 6 };// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
byte colPins[COLS] = { 5, 4, 3 };
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
  Serial.write(254);
  Serial.write(0x01);
  delay(200);
  pinMode(11, OUTPUT);  //green light
  pinMode(12, OUTPUT);  //red light
  myservo.attach(13); //servo on digital pin 9 //servo
  keypad.addEventListener(keypadEvent); //add an event listener for this keypad
void loop(){
  keypad.getKey();
  myservo.write(0);
  //take care of some special events
  void keypadEvent(KeypadEvent eKey){
  switch (keypad.getState()){
  case PRESSED:
  Serial.print("Enter:");
  Serial.println(eKey);
  delay(10);
  Serial.write(254);
  switch (eKey){
    case '*': checkPassword(); delay(1); break;
    case '#': password.reset(); delay(1); break;
     default: password.append(eKey); delay(1);
void checkPassword(){
if (password.evaluate()){  //if password is right open
    Serial.println("Accepted");
    Serial.write(254);delay(10);
    //Add code to run if it works
    myservo.write(150); //deg
        digitalWrite(11, HIGH);//turn on
    delay(5000); //wait 5 seconds
    digitalWrite(11, LOW);// turn off
}else{
    Serial.println("Denied"); //if passwords wrong keep locked
    //add code to run if it did not work
    myservo.write(0);
    digitalWrite(12, HIGH); //turn on
    delay(500); //wait 5 seconds
    digitalWrite(12, LOW);//turn off
Use two passwords. Each opens a different lock.
But first, get one program running, with one lock and one password and make sure that you understand how it works.
