hi all
i have written a simple program to exchange array of bytes between two arduinos using a couple of NRF24L01
it works fine ,but when i use a hash function(sha256) the transfer stops without a logical explaination ,though the RAM usage is only 33%
transmitter code
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <RF24_config.h>
#include "sha256.h"
This sketch sends a string to a corresponding Arduino
with nrf24 attached. It appends a specific value
(2 in this case) to the end to signify the end of the
message.
#define WHICH_NODE 1
const uint64_t wAddress[] = {0x7878787878LL, 0xB3B4B5B6F1LL, 0xB3B4B5B6CDLL, 0xB3B4B5B6A3LL, 0xB3B4B5B60FLL, 0xB3B4B5B605LL};
const uint64_t PTXpipe = wAddress[WHICH_NODE]; // Pulls the address from the above array for this node's pipe
RF24 radio(8,10);
byte arr[33] ;
uint8_t* hash;
void printHash(uint8_t* hash) {
for (int i=0; i<32; i++) {
//(String)hash = (String) ID + (String) hash;
Serial.print("0123456789abcdef"[hash[i]>>4]);
Serial.print("0123456789abcdef"[hash[i]&0xf]);
void setup(void)
radio.begin();
radio.openWritingPipe(PTXpipe);
radio.stopListening(); }
byte arr[33] ;
char xx[21];
String str ="12345678901234567890";
str.toCharArray(xx, 21);
Sha256.initHmac((uint8_t*)xx,21);
//Serial.println(xx);
Sha256.print("node 1");
// delay(10);
hash=Sha256.resultHmac();
for( int j=0;j<32;j++)
{arr[j]=hash[j];
Serial.print(arr[j],HEX);
delay(10);
arr[32]='\0';
//Serial.println();
radio.write(arr,33);
Serial.println(arr);
Receiver code
#include <RF24.h>
#include <SPI.h>
This sketch receives strings from sending unit via nrf24
and prints them out via serial. The sketch waits until
it receives a specific value (2 in this case), then it
prints the complete message and clears the message buffer.
byte pipeNum = 0;
RF24 radio(8,10);
const uint64_t rAddress[] = {0x7878787878LL, 0xB3B4B5B6F1LL, 0xB3B4B5B6CDLL, 0xB3B4B5B6A3LL, 0xB3B4B5B60FLL, 0xB3B4B5B605LL };
int lastmsg = 1;
char theMessage[33] = "";
void setup(void){
radio.begin();
radio.openReadingPipe(2,rAddress[2]);
radio.openReadingPipe(1,rAddress[1]);
radio.startListening();
void loop(void)
while (radio.available(&pipeNum))
radio.read( theMessage , 33 );
Serial.print("received : ");
Serial.print(theMessage);
Serial.print(" from ");
Serial.print(pipeNum);
when i tried to send another array of bytes other than the one in the hash function it works only when i restart the transmitter’s board
what is the cause of that?
thanks in advance for your help
