Unmanned Quad Copter Project
Hi all,
I'm currently working on a project where I am making a quadcopter. This copter only needs to be able to lift off the ground for a few seconds and then set down safely. I am currently using a Chip Kit Max32 and will be controlling the 4 motors with a motor driver. What is the easiest way I can program this and set it up to give me my desired results? Thanks a lot for all your help.
Perhaps your local Ford dealer could help. Why would you ask questions about some non-Arduino board here?
http://chipkit.net/forum/
The code is similar! Some of the autonomous code I have written for Arduino actually runs better on a ChipKit because it's faster. You can change the loop delay and everything else works.
