I tried to load the ArduinoISP sketch that comes with the IDE, without modifying it, and this is what I get:
In file included from ArduinoISP.cpp:66:
C:\Program Files (x86)\Arduino\arduino-0022\hardware\arduino\cores\arduino/pins_arduino.h:66: error: previous declaration of 'const uint16_t port_to_mode_PGM []' with 'C++' linkage
C:\Program Files (x86)\Arduino\arduino-0022\hardware\arduino\cores\arduino/Arduino.h:127: error: conflicts with new declaration with 'C' linkage
C:\Program Files (x86)\Arduino\arduino-0022\hardware\arduino\cores\arduino/pins_arduino.h:67: error: previous declaration of 'const uint16_t port_to_input_PGM []' with 'C++' linkage
C:\Program Files (x86)\Arduino\arduino-0022\hardware\arduino\cores\arduino/Arduino.h:128: error: conflicts with new declaration with 'C' linkage
C:\Program Files (x86)\Arduino\arduino-0022\hardware\arduino\cores\arduino/pins_arduino.h:68: error: previous declaration of 'const uint16_t port_to_output_PGM []' with 'C++' linkage
C:\Program Files (x86)\Arduino\arduino-0022\hardware\arduino\cores\arduino/Arduino.h:129: error: conflicts with new declaration with 'C' linkage
C:\Program Files (x86)\Arduino\arduino-0022\hardware\arduino\cores\arduino/pins_arduino.h:70: error: previous declaration of 'const uint8_t digital_pin_to_port_PGM []' with 'C++' linkage
C:\Program Files (x86)\Arduino\arduino-0022\hardware\arduino\cores\arduino/Arduino.h:131: error: conflicts with new declaration with 'C' linkage
C:\Program Files (x86)\Arduino\arduino-0022\hardware\arduino\cores\arduino/pins_arduino.h:72: error: previous declaration of 'const uint8_t digital_pin_to_bit_mask_PGM []' with 'C++' linkage
C:\Program Files (x86)\Arduino\arduino-0022\hardware\arduino\cores\arduino/Arduino.h:133: error: conflicts with new declaration with 'C' linkage
C:\Program Files (x86)\Arduino\arduino-0022\hardware\arduino\cores\arduino/pins_arduino.h:73: error: previous declaration of 'const uint8_t digital_pin_to_timer_PGM []' with 'C++' linkage
C:\Program Files (x86)\Arduino\arduino-0022\hardware\arduino\cores\arduino/Arduino.h:134: error: conflicts with new declaration with 'C' linkage
ArduinoISP:56: error: new declaration 'uint8_t write_flash(int)'
ArduinoISP:25: error: ambiguates old declaration 'void write_flash(int)'
ArduinoISP.cpp: In function 'void setup()':
ArduinoISP:601: error: redefinition of 'void setup()'
ArduinoISP:67: error: 'void setup()' previously defined here
ArduinoISP.cpp: At global scope:
ArduinoISP:611: error: redefinition of 'int error'
ArduinoISP:77: error: 'int error' previously defined here
ArduinoISP:612: error: redefinition of 'int pmode'
ArduinoISP:78: error: 'int pmode' previously defined here
ArduinoISP:614: error: redefinition of 'int here'
ArduinoISP:80: error: 'int here' previously declared here
ArduinoISP:615: error: redefinition of 'uint8_t buff [256]'
ArduinoISP:81: error: 'uint8_t buff [256]' previously declared here
ArduinoISP:618: error: redefinition of 'struct param'
ArduinoISP:84: error: previous definition of 'struct param'
ArduinoISP:633: error: invalid type in declaration before ';' token
ArduinoISP:633: error: conflicting declaration 'typedef int parameter'
ArduinoISP:99: error: 'parameter' has a previous declaration as 'typedef struct param parameter'
ArduinoISP:635: error: redefinition of 'parameter param'
ArduinoISP:101: error: 'parameter param' previously declared here
ArduinoISP:638: error: redefinition of 'uint8_t hbval'
ArduinoISP:104: error: 'uint8_t hbval' previously defined here
ArduinoISP:639: error: redefinition of 'int8_t hbdelta'
ArduinoISP:105: error: 'int8_t hbdelta' previously defined here
ArduinoISP.cpp: In function 'void heartbeat()':
ArduinoISP:640: error: redefinition of 'void heartbeat()'
ArduinoISP:106: error: 'void heartbeat()' previously defined here
ArduinoISP.cpp: In function 'void loop()':
ArduinoISP:649: error: redefinition of 'void loop()'
ArduinoISP:115: error: 'void loop()' previously defined here
ArduinoISP.cpp: In function 'uint8_t getch()':
ArduinoISP:664: error: redefinition of 'uint8_t getch()'
ArduinoISP:130: error: 'uint8_t getch()' previously defined here
ArduinoISP.cpp: In function 'void pulse(int, int)':
ArduinoISP:675: error: redefinition of 'void pulse(int, int)'
ArduinoISP:141: error: 'void pulse(int, int)' previously defined here
ArduinoISP.cpp: In function 'void spi_init()':
ArduinoISP:685: error: redefinition of 'void spi_init()'
ArduinoISP:156: error: 'void spi_init()' previously defined here
ArduinoISP.cpp: In function 'void spi_wait()':
ArduinoISP:692: error: redefinition of 'void spi_wait()'
ArduinoISP:163: error: 'void spi_wait()' previously defined here
ArduinoISP.cpp: In function 'uint8_t spi_send(uint8_t)':
ArduinoISP:698: error: redefinition of 'uint8_t spi_send(uint8_t)'
ArduinoISP:169: error: 'uint8_t spi_send(uint8_t)' previously defined here
ArduinoISP.cpp: In function 'uint8_t spi_transaction(uint8_t, uint8_t, uint8_t, uint8_t)':
ArduinoISP:706: error: redefinition of 'uint8_t spi_transaction(uint8_t, uint8_t, uint8_t, uint8_t)'
ArduinoISP:177: error: 'uint8_t spi_transaction(uint8_t, uint8_t, uint8_t, uint8_t)' previously defined here
ArduinoISP.cpp: In function 'void empty_reply()':
ArduinoISP:715: error: redefinition of 'void empty_reply()'
ArduinoISP:186: error: 'void empty_reply()' previously defined here
ArduinoISP.cpp: In function 'void breply(uint8_t)':
ArduinoISP:725: error: redefinition of 'void breply(uint8_t)'
ArduinoISP:197: error: 'void breply(uint8_t)' previously defined here
ArduinoISP.cpp: In function 'void get_version(uint8_t)':
ArduinoISP:736: error: redefinition of 'void get_version(uint8_t)'
ArduinoISP:209: error: 'void get_version(uint8_t)' previously defined here
ArduinoISP.cpp: In function 'void set_parameters()':
ArduinoISP:755: error: redefinition of 'void set_parameters()'
ArduinoISP:228: error: 'void set_parameters()' previously defined here
ArduinoISP.cpp: In function 'void start_pmode()':
ArduinoISP:783: error: redefinition of 'void start_pmode()'
ArduinoISP:253: error: 'void start_pmode()' previously defined here
ArduinoISP.cpp: In function 'void end_pmode()':
ArduinoISP:799: error: redefinition of 'void end_pmode()'
ArduinoISP:269: error: 'void end_pmode()' previously defined here
ArduinoISP.cpp: In function 'void universal()':
ArduinoISP:807: error: redefinition of 'void universal()'
ArduinoISP:277: error: 'void universal()' previously defined here
ArduinoISP.cpp: In function 'void flash(uint8_t, int, uint8_t)':
ArduinoISP:818: error: redefinition of 'void flash(uint8_t, int, uint8_t)'
ArduinoISP:286: error: 'void flash(uint8_t, int, uint8_t)' previously defined here
ArduinoISP.cpp: In function 'void commit(int)':
ArduinoISP:824: error: redefinition of 'void commit(int)'
ArduinoISP:292: error: 'void commit(int)' previously defined here
ArduinoISP.cpp: In function 'int current_page(int)':
ArduinoISP:829: error: redefinition of 'int current_page(int)'
ArduinoISP:302: error: 'int current_page(int)' previously defined here
ArduinoISP.cpp: In function 'uint8_t write_flash(int)':
ArduinoISP:836: error: new declaration 'uint8_t write_flash(int)'
ArduinoISP:311: error: ambiguates old declaration 'void write_flash(int)'
ArduinoISP.cpp: In function 'uint8_t write_eeprom(int)':
ArduinoISP:856: error: redefinition of 'uint8_t write_eeprom(int)'
ArduinoISP:342: error: 'uint8_t write_eeprom(int)' previously defined here
ArduinoISP.cpp: In function 'void program_page()':
ArduinoISP:867: error: redefinition of 'void program_page()'
ArduinoISP:373: error: 'void program_page()' previously defined here
ArduinoISP:880: error: void value not ignored as it ought to be
ArduinoISP.cpp: In function 'uint8_t flash_read(uint8_t, int)':
ArduinoISP:888: error: redefinition of 'uint8_t flash_read(uint8_t, int)'
ArduinoISP:399: error: 'uint8_t flash_read(uint8_t, int)' previously defined here
ArduinoISP.cpp: In function 'char flash_read_page(int)':
ArduinoISP:895: error: redefinition of 'char flash_read_page(int)'
ArduinoISP:406: error: 'char flash_read_page(int)' previously defined here
ArduinoISP.cpp: In function 'char eeprom_read_page(int)':
ArduinoISP:906: error: redefinition of 'char eeprom_read_page(int)'
ArduinoISP:417: error: 'char eeprom_read_page(int)' previously defined here
ArduinoISP.cpp: In function 'void read_page()':
ArduinoISP:915: error: redefinition of 'void read_page()'
ArduinoISP:428: error: 'void read_page()' previously defined here
ArduinoISP.cpp: In function 'void read_signature()':
ArduinoISP:930: error: redefinition of 'void read_signature()'
ArduinoISP:445: error: 'void read_signature()' previously defined here
ArduinoISP.cpp: In function 'int avrisp()':
ArduinoISP:950: error: redefinition of 'int avrisp()'
ArduinoISP:466: error: 'int avrisp()' previously defined here
Does anyone know what might be the problem? I can't find anyone else who has gotten this error before.
