Unneeded dependency in SD.h
The file "SD.h" links to SdFatUtils, in line 21:
#include "utility/SdFatUtil.h"
This is - as far as I see - not required and only makes troubles if you want to avoid having the Serial declared for your project.
The line could simply be commented out.
(btw: The page SD - Arduino Reference should have a link to this forum, but the link there is wrong / dead)
Cheers,
Ralf
Can you provide some more details? Can't remember having had problems (but I don't use the library often enough to remember).
Issue reported on github: SD reference, forum link equals OOPS when following · Issue #11574 · arduino/Arduino · GitHub
In development version I add serial writes for debugging purposes. As this code should not be active in the deployed version, it's deactivated usign define-blocks.
To find potentially unwanted code accessing the serial I currently use this code:
// #define DEBUG
#ifndef DEBUG
  // Avoid that debug code remains in release version
  #define Serial RaiseErrorIfForgotInCode
#endif
This doesn't work if the SD lib is in use.
But for me the most important thing: Why should the SD lib link to a library that is not used anyway?
Probably just redundant code due to an oversight, and clearly nothing to get concerned about.
