UNO all lights on (solved)
Hi
I'm newbie in Arduino and electronics and really enjoying it.
thanks Arduino for making things more simple.
I have written a code but when I upload it to my UNO board all lights includes on led, rx led, tx led and L led attached to pin 13 is on.
the pin 13 itself has no lights when i attached a led.
what could be the problem.
i tried many of examples and they were working good so I'm sure the board it self is healthy.
thanks for answering.
westsun:
Let's see it then :wink:
Here it is:
https://paste.ubuntu.com/25580797/
You shouldn't use pins 0 and 1 because they are used for serial communication with the computer. The onboard LED L is buffered so it lights when the pin 13 isn't pulled low.
but i'm not using pin 1 and 0 data input or output after uploading the sketch.
i tryed to make pin 13 as output but still had the problem.
When the pin 13 is set to OUTPUT LOW, the LED L switches off. Using pins 0 and 1 may confuse the onboard USB-serial converter and the RX/TX LEDs will light. You can use analog pins as additional digital pins.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :slight_smile:
of course i will make it public but when it's finished.
i think everything is working now just need to modify the code to use right pins and one day test.
if it passes the test we can have a color_watch with minimum hardware.
TomGeorge:
Thanks Tom I tried to post the code in here but I got an Error of limitation of 9000 words in 1 post, so I used UBUNTU paste service.
Attach it as an ino file , if it is too big.
