Uno (Atmega328p) instructions taking less than one cycle?
Hi!
I've been playing with unoptimized code and saw something I didn't understand:
Every assignment apparently takes a non-integer number of cycles and a boolean negation apparently takes zero cycles.
Oscilloscope screenshots:
The .ino code:
#pragma GCC optimize ("-O0")
#pragma GCC push_options
  DDRB  = 0xFF; //8 a 13 -> output
  DDRD  = 0x00; //0 a 7 -> input
  PORTD = 0x80; //7 -> pullup
  bool variavel_bool = false;
  int variavel_int = 0x0000;
  long variavel_long = 0x00000000;
  unsigned variavel_unsigned = 0x0000;
  float variavel_float = 0.0;
  char variavel_char = '0';
  while(PIND & 0x80);
  PORTB = 0xFF;
  PORTB = 0x00;
  PORTB = 0xFF;
  variavel_bool = true;
  PORTB = 0x00;
  delay(50);
  while(!(PIND & 0x80));
  while(PIND & 0x80);
  PORTB = 0xFF;
  PORTB = 0x00;
  PORTB = 0xFF;
  variavel_int = 0xF0F0;
  PORTB = 0x00;
  delay(50);
  while(PIND & 0x80);
  PORTB = 0xFF;
  PORTB = 0x00;
  PORTB = 0xFF;
  variavel_long = 0xF0F0F0F0;
  PORTB = 0x00;
  delay(50);
  while(PIND & 0x80);
  PORTB = 0xFF;
  PORTB = 0x00;
  PORTB = 0xFF;
  variavel_unsigned = 0xF0F0;
  PORTB = 0x00;
  delay(50);
  while(PIND & 0x80);
  PORTB = 0xFF;
  PORTB = 0x00;
  PORTB = 0xFF;
  variavel_float = 3.3;
  PORTB = 0x00;
  delay(50);
  while(PIND & 0x80);
  PORTB = 0xFF;
  PORTB = 0x00;
  PORTB = 0xFF;
  variavel_char = '1';
  PORTB = 0x00;
  delay(50);
  while(PIND & 0x80);
  PORTB = 0xFF;
  PORTB = 0x00;
  PORTB = 0xFF;
  variavel_bool != variavel_bool;
  PORTB = 0x00;
  delay(50);
  while(PIND & 0x80);
  PORTB = 0xFF;
  PORTB = 0x00;
  PORTB = 0xFF;
  variavel_int += variavel_int;
  PORTB = 0x00;
  delay(50);
  while(PIND & 0x80);
  PORTB = 0xFF;
  PORTB = 0x00;
  PORTB = 0xFF;
  variavel_long += variavel_long;
  PORTB = 0x00;
  delay(50);
  while(PIND & 0x80);
  PORTB = 0xFF;
  PORTB = 0x00;
  PORTB = 0xFF;
  variavel_unsigned += variavel_unsigned;
  PORTB = 0x00;
  delay(50);
  while(PIND & 0x80);
  PORTB = 0xFF;
  PORTB = 0x00;
  PORTB = 0xFF;
  variavel_float += variavel_float;
  PORTB = 0x00;
  delay(50);
  while(PIND & 0x80);
  PORTB = 0xFF;
  PORTB = 0x00;
  PORTB = 0xFF;
  variavel_char += variavel_char;
  PORTB = 0x00;
  //Serial.begin(300);
  //Serial.println();
void loop() {}
#pragma GCC pop_options
The unoptimized output:
Disassembly of section .text:
00000000 <__vectors>:
   0:   0c 94 34 00     jmp     0x68    ; 0x68 <__ctors_end>
   4:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
   8:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
   c:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  10:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  14:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  18:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  1c:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  20:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  24:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  28:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  2c:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  30:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  34:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  38:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  3c:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  40:   0c 94 a0 00     jmp     0x140   ; 0x140 <__vector_16>
  44:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  48:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  4c:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  50:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  54:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  58:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  5c:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  60:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
  64:   0c 94 46 00     jmp     0x8c    ; 0x8c <__bad_interrupt>
00000068 <__ctors_end>:
  68:   11 24           eor     r1, r1
  6a:   1f be           out     0x3f, r1        ; 63
  6c:   cf ef           ldi     r28, 0xFF       ; 255
  6e:   d8 e0           ldi     r29, 0x08       ; 8
  70:   de bf           out     0x3e, r29       ; 62
  72:   cd bf           out     0x3d, r28       ; 61
00000074 <__do_clear_bss>:
  74:   21 e0           ldi     r18, 0x01       ; 1
  76:   a0 e0           ldi     r26, 0x00       ; 0
  78:   b1 e0           ldi     r27, 0x01       ; 1
  7a:   01 c0           rjmp    .+2             ; 0x7e <.do_clear_bss_start>
0000007c <.do_clear_bss_loop>:
  7c:   1d 92           st      X+, r1
0000007e <.do_clear_bss_start>:
  7e:   a9 30           cpi     r26, 0x09       ; 9
  80:   b2 07           cpc     r27, r18
  82:   e1 f7           brne    .-8             ; 0x7c <.do_clear_bss_loop>
  84:   0e 94 5b 03     call    0x6b6   ; 0x6b6 <main>
  88:   0c 94 67 04     jmp     0x8ce   ; 0x8ce <_exit>
0000008c <__bad_interrupt>:
  8c:   0c 94 00 00     jmp     0       ; 0x0 <__vectors>
00000090 <micros>:
        return m;
unsigned long micros() {
        unsigned long m;
        uint8_t oldSREG = SREG, t;
  90:   3f b7           in      r19, 0x3f       ; 63
        cli();
  92:   f8 94           cli
        m = timer0_overflow_count;
  94:   80 91 05 01     lds     r24, 0x0105     ; 0x800105 <timer0_overflow_count>
  98:   90 91 06 01     lds     r25, 0x0106     ; 0x800106 <timer0_overflow_count+0x1>
  9c:   a0 91 07 01     lds     r26, 0x0107     ; 0x800107 <timer0_overflow_count+0x2>
  a0:   b0 91 08 01     lds     r27, 0x0108     ; 0x800108 <timer0_overflow_count+0x3>
#if defined(TCNT0)
        t = TCNT0;
  a4:   26 b5           in      r18, 0x26       ; 38
#else
        #error TIMER 0 not defined
#endif
#ifdef TIFR0
        if ((TIFR0 & _BV(TOV0)) && (t < 255))
  a6:   a8 9b           sbis    0x15, 0 ; 21
  a8:   05 c0           rjmp    .+10            ; 0xb4 <micros+0x24>
  aa:   2f 3f           cpi     r18, 0xFF       ; 255
  ac:   19 f0           breq    .+6             ; 0xb4 <micros+0x24>
                m++;
  ae:   01 96           adiw    r24, 0x01       ; 1
  b0:   a1 1d           adc     r26, r1
  b2:   b1 1d           adc     r27, r1
#else
        if ((TIFR & _BV(TOV0)) && (t < 255))
                m++;
#endif
        SREG = oldSREG;
  b4:   3f bf           out     0x3f, r19       ; 63
        return ((m << 8) + t) * (64 / clockCyclesPerMicrosecond());
  b6:   ba 2f           mov     r27, r26
  b8:   a9 2f           mov     r26, r25
  ba:   98 2f           mov     r25, r24
  bc:   88 27           eor     r24, r24
  be:   bc 01           movw    r22, r24
  c0:   cd 01           movw    r24, r26
  c2:   62 0f           add     r22, r18
  c4:   71 1d           adc     r23, r1
  c6:   81 1d           adc     r24, r1
  c8:   91 1d           adc     r25, r1
  ca:   42 e0           ldi     r20, 0x02       ; 2
  cc:   66 0f           add     r22, r22
  ce:   77 1f           adc     r23, r23
  d0:   88 1f           adc     r24, r24
  d2:   99 1f           adc     r25, r25
  d4:   4a 95           dec     r20
  d6:   d1 f7           brne    .-12            ; 0xcc <micros+0x3c>
  d8:   08 95           ret
000000da <delay>:
void delay(unsigned long ms)
  da:   8f 92           push    r8
  dc:   9f 92           push    r9
  de:   af 92           push    r10
  e0:   bf 92           push    r11
  e2:   cf 92           push    r12
  e4:   df 92           push    r13
  e6:   ef 92           push    r14
  e8:   ff 92           push    r15
  ea:   6b 01           movw    r12, r22
  ec:   7c 01           movw    r14, r24
        uint32_t start = micros();
  ee:   0e 94 48 00     call    0x90    ; 0x90 <micros>
  f2:   4b 01           movw    r8, r22
  f4:   5c 01           movw    r10, r24
        while (ms > 0) {
                yield();
                while ( ms > 0 && (micros() - start) >= 1000) {
  f6:   c1 14           cp      r12, r1
  f8:   d1 04           cpc     r13, r1
  fa:   e1 04           cpc     r14, r1
  fc:   f1 04           cpc     r15, r1
  fe:   b9 f0           breq    .+46            ; 0x12e <delay+0x54>
 100:   0e 94 48 00     call    0x90    ; 0x90 <micros>
 104:   68 19           sub     r22, r8
 106:   79 09           sbc     r23, r9
 108:   8a 09           sbc     r24, r10
 10a:   9b 09           sbc     r25, r11
 10c:   68 3e           cpi     r22, 0xE8       ; 232
 10e:   73 40           sbci    r23, 0x03       ; 3
 110:   81 05           cpc     r24, r1
 112:   91 05           cpc     r25, r1
 114:   80 f3           brcs    .-32            ; 0xf6 <delay+0x1c>
                        ms--;
 116:   21 e0           ldi     r18, 0x01       ; 1
 118:   c2 1a           sub     r12, r18
 11a:   d1 08           sbc     r13, r1
 11c:   e1 08           sbc     r14, r1
 11e:   f1 08           sbc     r15, r1
                        start += 1000;
 120:   88 ee           ldi     r24, 0xE8       ; 232
 122:   88 0e           add     r8, r24
 124:   83 e0           ldi     r24, 0x03       ; 3
 126:   98 1e           adc     r9, r24
 128:   a1 1c           adc     r10, r1
 12a:   b1 1c           adc     r11, r1
 12c:   e4 cf           rjmp    .-56            ; 0xf6 <delay+0x1c>
 12e:   ff 90           pop     r15
 130:   ef 90           pop     r14
 132:   df 90           pop     r13
 134:   cf 90           pop     r12
 136:   bf 90           pop     r11
 138:   af 90           pop     r10
 13a:   9f 90           pop     r9
 13c:   8f 90           pop     r8
 13e:   08 95           ret
00000140 <__vector_16>:
#if defined(TIM0_OVF_vect)
ISR(TIM0_OVF_vect)
#else
ISR(TIMER0_OVF_vect)
#endif
 140:   1f 92           push    r1
 142:   0f 92           push    r0
 144:   0f b6           in      r0, 0x3f        ; 63
 146:   0f 92           push    r0
 148:   11 24           eor     r1, r1
 14a:   2f 93           push    r18
 14c:   3f 93           push    r19
 14e:   8f 93           push    r24
 150:   9f 93           push    r25
 152:   af 93           push    r26
 154:   bf 93           push    r27
        // copy these to local variables so they can be stored in registers
        // (volatile variables must be read from memory on every access)
        unsigned long m = timer0_millis;
 156:   80 91 01 01     lds     r24, 0x0101     ; 0x800101 <timer0_millis>
 15a:   90 91 02 01     lds     r25, 0x0102     ; 0x800102 <timer0_millis+0x1>
 15e:   a0 91 03 01     lds     r26, 0x0103     ; 0x800103 <timer0_millis+0x2>
 162:   b0 91 04 01     lds     r27, 0x0104     ; 0x800104 <timer0_millis+0x3>
        unsigned char f = timer0_fract;
 166:   30 91 00 01     lds     r19, 0x0100     ; 0x800100 <_edata>
        m += MILLIS_INC;
        f += FRACT_INC;
 16a:   23 e0           ldi     r18, 0x03       ; 3
 16c:   23 0f           add     r18, r19
        if (f >= FRACT_MAX) {
 16e:   2d 37           cpi     r18, 0x7D       ; 125
 170:   58 f5           brcc    .+86            ; 0x1c8 <__vector_16+0x88>
        m += MILLIS_INC;
 172:   01 96           adiw    r24, 0x01       ; 1
 174:   a1 1d           adc     r26, r1
 176:   b1 1d           adc     r27, r1
                f -= FRACT_MAX;
                m += 1;
        timer0_fract = f;
 178:   20 93 00 01     sts     0x0100, r18     ; 0x800100 <_edata>
        timer0_millis = m;
 17c:   80 93 01 01     sts     0x0101, r24     ; 0x800101 <timer0_millis>
 180:   90 93 02 01     sts     0x0102, r25     ; 0x800102 <timer0_millis+0x1>
 184:   a0 93 03 01     sts     0x0103, r26     ; 0x800103 <timer0_millis+0x2>
 188:   b0 93 04 01     sts     0x0104, r27     ; 0x800104 <timer0_millis+0x3>
        timer0_overflow_count++;
 18c:   80 91 05 01     lds     r24, 0x0105     ; 0x800105 <timer0_overflow_count>
 190:   90 91 06 01     lds     r25, 0x0106     ; 0x800106 <timer0_overflow_count+0x1>
 194:   a0 91 07 01     lds     r26, 0x0107     ; 0x800107 <timer0_overflow_count+0x2>
 198:   b0 91 08 01     lds     r27, 0x0108     ; 0x800108 <timer0_overflow_count+0x3>
 19c:   01 96           adiw    r24, 0x01       ; 1
 19e:   a1 1d           adc     r26, r1
 1a0:   b1 1d           adc     r27, r1
 1a2:   80 93 05 01     sts     0x0105, r24     ; 0x800105 <timer0_overflow_count>
 1a6:   90 93 06 01     sts     0x0106, r25     ; 0x800106 <timer0_overflow_count+0x1>
 1aa:   a0 93 07 01     sts     0x0107, r26     ; 0x800107 <timer0_overflow_count+0x2>
 1ae:   b0 93 08 01     sts     0x0108, r27     ; 0x800108 <timer0_overflow_count+0x3>
 1b2:   bf 91           pop     r27
 1b4:   af 91           pop     r26
 1b6:   9f 91           pop     r25
 1b8:   8f 91           pop     r24
 1ba:   3f 91           pop     r19
 1bc:   2f 91           pop     r18
 1be:   0f 90           pop     r0
 1c0:   0f be           out     0x3f, r0        ; 63
 1c2:   0f 90           pop     r0
 1c4:   1f 90           pop     r1
 1c6:   18 95           reti
        m += MILLIS_INC;
        f += FRACT_INC;
                f -= FRACT_MAX;
 1c8:   26 e8           ldi     r18, 0x86       ; 134
 1ca:   23 0f           add     r18, r19
                m += 1;
 1cc:   02 96           adiw    r24, 0x02       ; 2
 1ce:   a1 1d           adc     r26, r1
 1d0:   b1 1d           adc     r27, r1
 1d2:   d2 cf           rjmp    .-92            ; 0x178 <__vector_16+0x38>
000001d4 <loop>:
 1d4:   cf 93           push    r28
 1d6:   df 93           push    r29
 1d8:   cd b7           in      r28, 0x3d       ; 61
 1da:   de b7           in      r29, 0x3e       ; 62
 1dc:   df 91           pop     r29
 1de:   cf 91           pop     r28
 1e0:   08 95           ret
000001e2 <setup>:
 1e2:   cf 93           push    r28
 1e4:   df 93           push    r29
 1e6:   cd b7           in      r28, 0x3d       ; 61
 1e8:   de b7           in      r29, 0x3e       ; 62
 1ea:   2e 97           sbiw    r28, 0x0e       ; 14
 1ec:   0f b6           in      r0, 0x3f        ; 63
 1ee:   f8 94           cli
 1f0:   de bf           out     0x3e, r29       ; 62
 1f2:   0f be           out     0x3f, r0        ; 63
 1f4:   cd bf           out     0x3d, r28       ; 61
 1f6:   84 e2           ldi     r24, 0x24       ; 36
 1f8:   90 e0           ldi     r25, 0x00       ; 0
 1fa:   2f ef           ldi     r18, 0xFF       ; 255
 1fc:   fc 01           movw    r30, r24
 1fe:   20 83           st      Z, r18
 200:   8a e2           ldi     r24, 0x2A       ; 42
 202:   90 e0           ldi     r25, 0x00       ; 0
 204:   fc 01           movw    r30, r24
 206:   10 82           st      Z, r1
 208:   8b e2           ldi     r24, 0x2B       ; 43
 20a:   90 e0           ldi     r25, 0x00       ; 0
 20c:   20 e8           ldi     r18, 0x80       ; 128
 20e:   fc 01           movw    r30, r24
 210:   20 83           st      Z, r18
 212:   19 82           std     Y+1, r1 ; 0x01
 214:   1b 82           std     Y+3, r1 ; 0x03
 216:   1a 82           std     Y+2, r1 ; 0x02
 218:   1c 82           std     Y+4, r1 ; 0x04
 21a:   1d 82           std     Y+5, r1 ; 0x05
 21c:   1e 82           std     Y+6, r1 ; 0x06
 21e:   1f 82           std     Y+7, r1 ; 0x07
 220:   19 86           std     Y+9, r1 ; 0x09
 222:   18 86           std     Y+8, r1 ; 0x08
 224:   1a 86           std     Y+10, r1        ; 0x0a
 226:   1b 86           std     Y+11, r1        ; 0x0b
 228:   1c 86           std     Y+12, r1        ; 0x0c
 22a:   1d 86           std     Y+13, r1        ; 0x0d
 22c:   80 e3           ldi     r24, 0x30       ; 48
 22e:   8e 87           std     Y+14, r24       ; 0x0e
 230:   89 e2           ldi     r24, 0x29       ; 41
 232:   90 e0           ldi     r25, 0x00       ; 0
 234:   fc 01           movw    r30, r24
 236:   80 81           ld      r24, Z
 238:   88 1f           adc     r24, r24
 23a:   88 27           eor     r24, r24
 23c:   88 1f           adc     r24, r24
 23e:   88 23           and     r24, r24
 240:   b9 f7           brne    .-18            ; 0x230 <setup+0x4e>
 242:   85 e2           ldi     r24, 0x25       ; 37
 244:   90 e0           ldi     r25, 0x00       ; 0
 246:   2f ef           ldi     r18, 0xFF       ; 255
 248:   fc 01           movw    r30, r24
 24a:   20 83           st      Z, r18
 24c:   85 e2           ldi     r24, 0x25       ; 37
 24e:   90 e0           ldi     r25, 0x00       ; 0
 250:   fc 01           movw    r30, r24
 252:   10 82           st      Z, r1
 254:   85 e2           ldi     r24, 0x25       ; 37
 256:   90 e0           ldi     r25, 0x00       ; 0
 258:   2f ef           ldi     r18, 0xFF       ; 255
 25a:   fc 01           movw    r30, r24
 25c:   20 83           st      Z, r18
 25e:   81 e0           ldi     r24, 0x01       ; 1
 260:   89 83           std     Y+1, r24        ; 0x01
 262:   85 e2           ldi     r24, 0x25       ; 37
 264:   90 e0           ldi     r25, 0x00       ; 0
 266:   fc 01           movw    r30, r24
 268:   10 82           st      Z, r1
 26a:   62 e3           ldi     r22, 0x32       ; 50
 26c:   70 e0           ldi     r23, 0x00       ; 0
 26e:   80 e0           ldi     r24, 0x00       ; 0
 270:   90 e0           ldi     r25, 0x00       ; 0
 272:   0e 94 6d 00     call    0xda    ; 0xda <delay>
 276:   89 e2           ldi     r24, 0x29       ; 41
 278:   90 e0           ldi     r25, 0x00       ; 0
 27a:   fc 01           movw    r30, r24
 27c:   80 81           ld      r24, Z
 27e:   80 95           com     r24
 280:   88 1f           adc     r24, r24
 282:   88 27           eor     r24, r24
 284:   88 1f           adc     r24, r24
 286:   88 23           and     r24, r24
 288:   b1 f7           brne    .-20            ; 0x276 <setup+0x94>
 28a:   89 e2           ldi     r24, 0x29       ; 41
 28c:   90 e0           ldi     r25, 0x00       ; 0
 28e:   fc 01           movw    r30, r24
 290:   80 81           ld      r24, Z
 292:   88 1f           adc     r24, r24
 294:   88 27           eor     r24, r24
 296:   88 1f           adc     r24, r24
 298:   88 23           and     r24, r24
 29a:   b9 f7           brne    .-18            ; 0x28a <setup+0xa8>
 29c:   85 e2           ldi     r24, 0x25       ; 37
 29e:   90 e0           ldi     r25, 0x00       ; 0
 2a0:   2f ef           ldi     r18, 0xFF       ; 255
 2a2:   fc 01           movw    r30, r24
 2a4:   20 83           st      Z, r18
 2a6:   85 e2           ldi     r24, 0x25       ; 37
 2a8:   90 e0           ldi     r25, 0x00       ; 0
 2aa:   fc 01           movw    r30, r24
 2ac:   10 82           st      Z, r1
 2ae:   85 e2           ldi     r24, 0x25       ; 37
 2b0:   90 e0           ldi     r25, 0x00       ; 0
 2b2:   2f ef           ldi     r18, 0xFF       ; 255
 2b4:   fc 01           movw    r30, r24
 2b6:   20 83           st      Z, r18
 2b8:   80 ef           ldi     r24, 0xF0       ; 240
 2ba:   90 ef           ldi     r25, 0xF0       ; 240
 2bc:   9b 83           std     Y+3, r25        ; 0x03
 2be:   8a 83           std     Y+2, r24        ; 0x02
 2c0:   85 e2           ldi     r24, 0x25       ; 37
 2c2:   90 e0           ldi     r25, 0x00       ; 0
 2c4:   fc 01           movw    r30, r24
 2c6:   10 82           st      Z, r1
 2c8:   62 e3           ldi     r22, 0x32       ; 50
 2ca:   70 e0           ldi     r23, 0x00       ; 0
 2cc:   80 e0           ldi     r24, 0x00       ; 0
 2ce:   90 e0           ldi     r25, 0x00       ; 0
 2d0:   0e 94 6d 00     call    0xda    ; 0xda <delay>
 2d4:   89 e2           ldi     r24, 0x29       ; 41
 2d6:   90 e0           ldi     r25, 0x00       ; 0
 2d8:   fc 01           movw    r30, r24
 2da:   80 81           ld      r24, Z
 2dc:   80 95           com     r24
 2de:   88 1f           adc     r24, r24
 2e0:   88 27           eor     r24, r24
 2e2:   88 1f           adc     r24, r24
 2e4:   88 23           and     r24, r24
 2e6:   b1 f7           brne    .-20            ; 0x2d4 <setup+0xf2>
 2e8:   89 e2           ldi     r24, 0x29       ; 41
 2ea:   90 e0           ldi     r25, 0x00       ; 0
 2ec:   fc 01           movw    r30, r24
 2ee:   80 81           ld      r24, Z
 2f0:   88 1f           adc     r24, r24
 2f2:   88 27           eor     r24, r24
 2f4:   88 1f           adc     r24, r24
 2f6:   88 23           and     r24, r24
 2f8:   b9 f7           brne    .-18            ; 0x2e8 <setup+0x106>
 2fa:   85 e2           ldi     r24, 0x25       ; 37
 2fc:   90 e0           ldi     r25, 0x00       ; 0
 2fe:   2f ef           ldi     r18, 0xFF       ; 255
 300:   fc 01           movw    r30, r24
 302:   20 83           st      Z, r18
 304:   85 e2           ldi     r24, 0x25       ; 37
 306:   90 e0           ldi     r25, 0x00       ; 0
 308:   fc 01           movw    r30, r24
 30a:   10 82           st      Z, r1
 30c:   85 e2           ldi     r24, 0x25       ; 37
 30e:   90 e0           ldi     r25, 0x00       ; 0
 310:   2f ef           ldi     r18, 0xFF       ; 255
 312:   fc 01           movw    r30, r24
 314:   20 83           st      Z, r18
 316:   80 ef           ldi     r24, 0xF0       ; 240
 318:   90 ef           ldi     r25, 0xF0       ; 240
 31a:   dc 01           movw    r26, r24
 31c:   8c 83           std     Y+4, r24        ; 0x04
 31e:   9d 83           std     Y+5, r25        ; 0x05
 320:   ae 83           std     Y+6, r26        ; 0x06
 322:   bf 83           std     Y+7, r27        ; 0x07
 324:   85 e2           ldi     r24, 0x25       ; 37
 326:   90 e0           ldi     r25, 0x00       ; 0
 328:   fc 01           movw    r30, r24
 32a:   10 82           st      Z, r1
 32c:   62 e3           ldi     r22, 0x32       ; 50
 32e:   70 e0           ldi     r23, 0x00       ; 0
 330:   80 e0           ldi     r24, 0x00       ; 0
 332:   90 e0           ldi     r25, 0x00       ; 0
 334:   0e 94 6d 00     call    0xda    ; 0xda <delay>
 338:   89 e2           ldi     r24, 0x29       ; 41
 33a:   90 e0           ldi     r25, 0x00       ; 0
 33c:   fc 01           movw    r30, r24
 33e:   80 81           ld      r24, Z
 340:   80 95           com     r24
 342:   88 1f           adc     r24, r24
 344:   88 27           eor     r24, r24
 346:   88 1f           adc     r24, r24
 348:   88 23           and     r24, r24
 34a:   b1 f7           brne    .-20            ; 0x338 <setup+0x156>
 34c:   89 e2           ldi     r24, 0x29       ; 41
 34e:   90 e0           ldi     r25, 0x00       ; 0
 350:   fc 01           movw    r30, r24
 352:   80 81           ld      r24, Z
 354:   88 1f           adc     r24, r24
 356:   88 27           eor     r24, r24
 358:   88 1f           adc     r24, r24
 35a:   88 23           and     r24, r24
 35c:   b9 f7           brne    .-18            ; 0x34c <setup+0x16a>
 35e:   85 e2           ldi     r24, 0x25       ; 37
 360:   90 e0           ldi     r25, 0x00       ; 0
 362:   2f ef           ldi     r18, 0xFF       ; 255
 364:   fc 01           movw    r30, r24
 366:   20 83           st      Z, r18
 368:   85 e2           ldi     r24, 0x25       ; 37
 36a:   90 e0           ldi     r25, 0x00       ; 0
 36c:   fc 01           movw    r30, r24
 36e:   10 82           st      Z, r1
 370:   85 e2           ldi     r24, 0x25       ; 37
 372:   90 e0           ldi     r25, 0x00       ; 0
 374:   2f ef           ldi     r18, 0xFF       ; 255
 376:   fc 01           movw    r30, r24
 378:   20 83           st      Z, r18
 37a:   80 ef           ldi     r24, 0xF0       ; 240
 37c:   90 ef           ldi     r25, 0xF0       ; 240
 37e:   99 87           std     Y+9, r25        ; 0x09
 380:   88 87           std     Y+8, r24        ; 0x08
 382:   85 e2           ldi     r24, 0x25       ; 37
 384:   90 e0           ldi     r25, 0x00       ; 0
 386:   fc 01           movw    r30, r24
 388:   10 82           st      Z, r1
 38a:   62 e3           ldi     r22, 0x32       ; 50
 38c:   70 e0           ldi     r23, 0x00       ; 0
 38e:   80 e0           ldi     r24, 0x00       ; 0
 390:   90 e0           ldi     r25, 0x00       ; 0
 392:   0e 94 6d 00     call    0xda    ; 0xda <delay>
 396:   89 e2           ldi     r24, 0x29       ; 41
 398:   90 e0           ldi     r25, 0x00       ; 0
 39a:   fc 01           movw    r30, r24
 39c:   80 81           ld      r24, Z
 39e:   80 95           com     r24
 3a0:   88 1f           adc     r24, r24
 3a2:   88 27           eor     r24, r24
 3a4:   88 1f           adc     r24, r24
 3a6:   88 23           and     r24, r24
 3a8:   b1 f7           brne    .-20            ; 0x396 <setup+0x1b4>
 3aa:   89 e2           ldi     r24, 0x29       ; 41
 3ac:   90 e0           ldi     r25, 0x00       ; 0
 3ae:   fc 01           movw    r30, r24
 3b0:   80 81           ld      r24, Z
 3b2:   88 1f           adc     r24, r24
 3b4:   88 27           eor     r24, r24
 3b6:   88 1f           adc     r24, r24
 3b8:   88 23           and     r24, r24
 3ba:   b9 f7           brne    .-18            ; 0x3aa <setup+0x1c8>
 3bc:   85 e2           ldi     r24, 0x25       ; 37
 3be:   90 e0           ldi     r25, 0x00       ; 0
 3c0:   2f ef           ldi     r18, 0xFF       ; 255
 3c2:   fc 01           movw    r30, r24
 3c4:   20 83           st      Z, r18
 3c6:   85 e2           ldi     r24, 0x25       ; 37
 3c8:   90 e0           ldi     r25, 0x00       ; 0
 3ca:   fc 01           movw    r30, r24
 3cc:   10 82           st      Z, r1
 3ce:   85 e2           ldi     r24, 0x25       ; 37
 3d0:   90 e0           ldi     r25, 0x00       ; 0
 3d2:   2f ef           ldi     r18, 0xFF       ; 255
 3d4:   fc 01           movw    r30, r24
 3d6:   20 83           st      Z, r18
 3d8:   83 e3           ldi     r24, 0x33       ; 51
 3da:   93 e3           ldi     r25, 0x33       ; 51
 3dc:   a3 e5           ldi     r26, 0x53       ; 83
 3de:   b0 e4           ldi     r27, 0x40       ; 64
 3e0:   8a 87           std     Y+10, r24       ; 0x0a
 3e2:   9b 87           std     Y+11, r25       ; 0x0b
 3e4:   ac 87           std     Y+12, r26       ; 0x0c
 3e6:   bd 87           std     Y+13, r27       ; 0x0d
 3e8:   85 e2           ldi     r24, 0x25       ; 37
 3ea:   90 e0           ldi     r25, 0x00       ; 0
 3ec:   fc 01           movw    r30, r24
 3ee:   10 82           st      Z, r1
 3f0:   62 e3           ldi     r22, 0x32       ; 50
 3f2:   70 e0           ldi     r23, 0x00       ; 0
 3f4:   80 e0           ldi     r24, 0x00       ; 0
 3f6:   90 e0           ldi     r25, 0x00       ; 0
 3f8:   0e 94 6d 00     call    0xda    ; 0xda <delay>
 3fc:   89 e2           ldi     r24, 0x29       ; 41
 3fe:   90 e0           ldi     r25, 0x00       ; 0
 400:   fc 01           movw    r30, r24
 402:   80 81           ld      r24, Z
 404:   80 95           com     r24
 406:   88 1f           adc     r24, r24
 408:   88 27           eor     r24, r24
 40a:   88 1f           adc     r24, r24
 40c:   88 23           and     r24, r24
 40e:   b1 f7           brne    .-20            ; 0x3fc <setup+0x21a>
 410:   89 e2           ldi     r24, 0x29       ; 41
 412:   90 e0           ldi     r25, 0x00       ; 0
 414:   fc 01           movw    r30, r24
 416:   80 81           ld      r24, Z
 418:   88 1f           adc     r24, r24
 41a:   88 27           eor     r24, r24
 41c:   88 1f           adc     r24, r24
 41e:   88 23           and     r24, r24
 420:   b9 f7           brne    .-18            ; 0x410 <__LOCK_REGION_LENGTH__+0x10>
 422:   85 e2           ldi     r24, 0x25       ; 37
 424:   90 e0           ldi     r25, 0x00       ; 0
 426:   2f ef           ldi     r18, 0xFF       ; 255
 428:   fc 01           movw    r30, r24
 42a:   20 83           st      Z, r18
 42c:   85 e2           ldi     r24, 0x25       ; 37
 42e:   90 e0           ldi     r25, 0x00       ; 0
 430:   fc 01           movw    r30, r24
 432:   10 82           st      Z, r1
 434:   85 e2           ldi     r24, 0x25       ; 37
 436:   90 e0           ldi     r25, 0x00       ; 0
 438:   2f ef           ldi     r18, 0xFF       ; 255
 43a:   fc 01           movw    r30, r24
 43c:   20 83           st      Z, r18
 43e:   81 e3           ldi     r24, 0x31       ; 49
 440:   8e 87           std     Y+14, r24       ; 0x0e
 442:   85 e2           ldi     r24, 0x25       ; 37
 444:   90 e0           ldi     r25, 0x00       ; 0
 446:   fc 01           movw    r30, r24
 448:   10 82           st      Z, r1
 44a:   62 e3           ldi     r22, 0x32       ; 50
 44c:   70 e0           ldi     r23, 0x00       ; 0
 44e:   80 e0           ldi     r24, 0x00       ; 0
 450:   90 e0           ldi     r25, 0x00       ; 0
 452:   0e 94 6d 00     call    0xda    ; 0xda <delay>
 456:   89 e2           ldi     r24, 0x29       ; 41
 458:   90 e0           ldi     r25, 0x00       ; 0
 45a:   fc 01           movw    r30, r24
 45c:   80 81           ld      r24, Z
 45e:   80 95           com     r24
 460:   88 1f           adc     r24, r24
 462:   88 27           eor     r24, r24
 464:   88 1f           adc     r24, r24
 466:   88 23           and     r24, r24
 468:   b1 f7           brne    .-20            ; 0x456 <__LOCK_REGION_LENGTH__+0x56>
 46a:   89 e2           ldi     r24, 0x29       ; 41
 46c:   90 e0           ldi     r25, 0x00       ; 0
 46e:   fc 01           movw    r30, r24
 470:   80 81           ld      r24, Z
 472:   88 1f           adc     r24, r24
 474:   88 27           eor     r24, r24
 476:   88 1f           adc     r24, r24
 478:   88 23           and     r24, r24
 47a:   b9 f7           brne    .-18            ; 0x46a <__LOCK_REGION_LENGTH__+0x6a>
 47c:   85 e2           ldi     r24, 0x25       ; 37
 47e:   90 e0           ldi     r25, 0x00       ; 0
 480:   2f ef           ldi     r18, 0xFF       ; 255
 482:   fc 01           movw    r30, r24
 484:   20 83           st      Z, r18
 486:   85 e2           ldi     r24, 0x25       ; 37
 488:   90 e0           ldi     r25, 0x00       ; 0
 48a:   fc 01           movw    r30, r24
 48c:   10 82           st      Z, r1
 48e:   85 e2           ldi     r24, 0x25       ; 37
 490:   90 e0           ldi     r25, 0x00       ; 0
 492:   2f ef           ldi     r18, 0xFF       ; 255
 494:   fc 01           movw    r30, r24
 496:   20 83           st      Z, r18
 498:   85 e2           ldi     r24, 0x25       ; 37
 49a:   90 e0           ldi     r25, 0x00       ; 0
 49c:   fc 01           movw    r30, r24
 49e:   10 82           st      Z, r1
 4a0:   62 e3           ldi     r22, 0x32       ; 50
 4a2:   70 e0           ldi     r23, 0x00       ; 0
 4a4:   80 e0           ldi     r24, 0x00       ; 0
 4a6:   90 e0           ldi     r25, 0x00       ; 0
 4a8:   0e 94 6d 00     call    0xda    ; 0xda <delay>
 4ac:   89 e2           ldi     r24, 0x29       ; 41
 4ae:   90 e0           ldi     r25, 0x00       ; 0
 4b0:   fc 01           movw    r30, r24
 4b2:   80 81           ld      r24, Z
 4b4:   80 95           com     r24
 4b6:   88 1f           adc     r24, r24
 4b8:   88 27           eor     r24, r24
 4ba:   88 1f           adc     r24, r24
 4bc:   88 23           and     r24, r24
 4be:   b1 f7           brne    .-20            ; 0x4ac <__LOCK_REGION_LENGTH__+0xac>
 4c0:   89 e2           ldi     r24, 0x29       ; 41
 4c2:   90 e0           ldi     r25, 0x00       ; 0
 4c4:   fc 01           movw    r30, r24
 4c6:   80 81           ld      r24, Z
 4c8:   88 1f           adc     r24, r24
 4ca:   88 27           eor     r24, r24
 4cc:   88 1f           adc     r24, r24
 4ce:   88 23           and     r24, r24
 4d0:   b9 f7           brne    .-18            ; 0x4c0 <__LOCK_REGION_LENGTH__+0xc0>
 4d2:   85 e2           ldi     r24, 0x25       ; 37
 4d4:   90 e0           ldi     r25, 0x00       ; 0
 4d6:   2f ef           ldi     r18, 0xFF       ; 255
 4d8:   fc 01           movw    r30, r24
 4da:   20 83           st      Z, r18
 4dc:   85 e2           ldi     r24, 0x25       ; 37
 4de:   90 e0           ldi     r25, 0x00       ; 0
 4e0:   fc 01           movw    r30, r24
 4e2:   10 82           st      Z, r1
 4e4:   85 e2           ldi     r24, 0x25       ; 37
 4e6:   90 e0           ldi     r25, 0x00       ; 0
 4e8:   2f ef           ldi     r18, 0xFF       ; 255
 4ea:   fc 01           movw    r30, r24
 4ec:   20 83           st      Z, r18
 4ee:   8a 81           ldd     r24, Y+2        ; 0x02
 4f0:   9b 81           ldd     r25, Y+3        ; 0x03
 4f2:   88 0f           add     r24, r24
 4f4:   99 1f           adc     r25, r25
 4f6:   9b 83           std     Y+3, r25        ; 0x03
 4f8:   8a 83           std     Y+2, r24        ; 0x02
 4fa:   85 e2           ldi     r24, 0x25       ; 37
 4fc:   90 e0           ldi     r25, 0x00       ; 0
 4fe:   fc 01           movw    r30, r24
 500:   10 82           st      Z, r1
 502:   62 e3           ldi     r22, 0x32       ; 50
 504:   70 e0           ldi     r23, 0x00       ; 0
 506:   80 e0           ldi     r24, 0x00       ; 0
 508:   90 e0           ldi     r25, 0x00       ; 0
 50a:   0e 94 6d 00     call    0xda    ; 0xda <delay>
 50e:   89 e2           ldi     r24, 0x29       ; 41
 510:   90 e0           ldi     r25, 0x00       ; 0
 512:   fc 01           movw    r30, r24
 514:   80 81           ld      r24, Z
 516:   80 95           com     r24
 518:   88 1f           adc     r24, r24
 51a:   88 27           eor     r24, r24
 51c:   88 1f           adc     r24, r24
 51e:   88 23           and     r24, r24
 520:   b1 f7           brne    .-20            ; 0x50e <__LOCK_REGION_LENGTH__+0x10e>
 522:   89 e2           ldi     r24, 0x29       ; 41
 524:   90 e0           ldi     r25, 0x00       ; 0
 526:   fc 01           movw    r30, r24
 528:   80 81           ld      r24, Z
 52a:   88 1f           adc     r24, r24
 52c:   88 27           eor     r24, r24
 52e:   88 1f           adc     r24, r24
 530:   88 23           and     r24, r24
 532:   b9 f7           brne    .-18            ; 0x522 <__LOCK_REGION_LENGTH__+0x122>
 534:   85 e2           ldi     r24, 0x25       ; 37
 536:   90 e0           ldi     r25, 0x00       ; 0
 538:   2f ef           ldi     r18, 0xFF       ; 255
 53a:   fc 01           movw    r30, r24
 53c:   20 83           st      Z, r18
 53e:   85 e2           ldi     r24, 0x25       ; 37
 540:   90 e0           ldi     r25, 0x00       ; 0
 542:   fc 01           movw    r30, r24
 544:   10 82           st      Z, r1
 546:   85 e2           ldi     r24, 0x25       ; 37
 548:   90 e0           ldi     r25, 0x00       ; 0
 54a:   2f ef           ldi     r18, 0xFF       ; 255
 54c:   fc 01           movw    r30, r24
 54e:   20 83           st      Z, r18
 550:   8c 81           ldd     r24, Y+4        ; 0x04
 552:   9d 81           ldd     r25, Y+5        ; 0x05
 554:   ae 81           ldd     r26, Y+6        ; 0x06
 556:   bf 81           ldd     r27, Y+7        ; 0x07
 558:   88 0f           add     r24, r24
 55a:   99 1f           adc     r25, r25
 55c:   aa 1f           adc     r26, r26
 55e:   bb 1f           adc     r27, r27
 560:   8c 83           std     Y+4, r24        ; 0x04
 562:   9d 83           std     Y+5, r25        ; 0x05
 564:   ae 83           std     Y+6, r26        ; 0x06
 566:   bf 83           std     Y+7, r27        ; 0x07
 568:   85 e2           ldi     r24, 0x25       ; 37
 56a:   90 e0           ldi     r25, 0x00       ; 0
 56c:   fc 01           movw    r30, r24
 56e:   10 82           st      Z, r1
 570:   62 e3           ldi     r22, 0x32       ; 50
 572:   70 e0           ldi     r23, 0x00       ; 0
 574:   80 e0           ldi     r24, 0x00       ; 0
 576:   90 e0           ldi     r25, 0x00       ; 0
 578:   0e 94 6d 00     call    0xda    ; 0xda <delay>
 57c:   89 e2           ldi     r24, 0x29       ; 41
 57e:   90 e0           ldi     r25, 0x00       ; 0
 580:   fc 01           movw    r30, r24
 582:   80 81           ld      r24, Z
 584:   80 95           com     r24
 586:   88 1f           adc     r24, r24
 588:   88 27           eor     r24, r24
 58a:   88 1f           adc     r24, r24
 58c:   88 23           and     r24, r24
 58e:   b1 f7           brne    .-20            ; 0x57c <__LOCK_REGION_LENGTH__+0x17c>
 590:   89 e2           ldi     r24, 0x29       ; 41
 592:   90 e0           ldi     r25, 0x00       ; 0
 594:   fc 01           movw    r30, r24
 596:   80 81           ld      r24, Z
 598:   88 1f           adc     r24, r24
 59a:   88 27           eor     r24, r24
 59c:   88 1f           adc     r24, r24
 59e:   88 23           and     r24, r24
 5a0:   b9 f7           brne    .-18            ; 0x590 <__LOCK_REGION_LENGTH__+0x190>
 5a2:   85 e2           ldi     r24, 0x25       ; 37
 5a4:   90 e0           ldi     r25, 0x00       ; 0
 5a6:   2f ef           ldi     r18, 0xFF       ; 255
 5a8:   fc 01           movw    r30, r24
 5aa:   20 83           st      Z, r18
 5ac:   85 e2           ldi     r24, 0x25       ; 37
 5ae:   90 e0           ldi     r25, 0x00       ; 0
 5b0:   fc 01           movw    r30, r24
 5b2:   10 82           st      Z, r1
 5b4:   85 e2           ldi     r24, 0x25       ; 37
 5b6:   90 e0           ldi     r25, 0x00       ; 0
 5b8:   2f ef           ldi     r18, 0xFF       ; 255
 5ba:   fc 01           movw    r30, r24
 5bc:   20 83           st      Z, r18
 5be:   88 85           ldd     r24, Y+8        ; 0x08
 5c0:   99 85           ldd     r25, Y+9        ; 0x09
 5c2:   88 0f           add     r24, r24
 5c4:   99 1f           adc     r25, r25
 5c6:   99 87           std     Y+9, r25        ; 0x09
 5c8:   88 87           std     Y+8, r24        ; 0x08
 5ca:   85 e2           ldi     r24, 0x25       ; 37
 5cc:   90 e0           ldi     r25, 0x00       ; 0
 5ce:   fc 01           movw    r30, r24
 5d0:   10 82           st      Z, r1
 5d2:   62 e3           ldi     r22, 0x32       ; 50
 5d4:   70 e0           ldi     r23, 0x00       ; 0
 5d6:   80 e0           ldi     r24, 0x00       ; 0
 5d8:   90 e0           ldi     r25, 0x00       ; 0
 5da:   0e 94 6d 00     call    0xda    ; 0xda <delay>
 5de:   89 e2           ldi     r24, 0x29       ; 41
 5e0:   90 e0           ldi     r25, 0x00       ; 0
 5e2:   fc 01           movw    r30, r24
 5e4:   80 81           ld      r24, Z
 5e6:   80 95           com     r24
 5e8:   88 1f           adc     r24, r24
 5ea:   88 27           eor     r24, r24
 5ec:   88 1f           adc     r24, r24
 5ee:   88 23           and     r24, r24
 5f0:   b1 f7           brne    .-20            ; 0x5de <__LOCK_REGION_LENGTH__+0x1de>
 5f2:   89 e2           ldi     r24, 0x29       ; 41
 5f4:   90 e0           ldi     r25, 0x00       ; 0
 5f6:   fc 01           movw    r30, r24
 5f8:   80 81           ld      r24, Z
 5fa:   88 1f           adc     r24, r24
 5fc:   88 27           eor     r24, r24
 5fe:   88 1f           adc     r24, r24
 600:   88 23           and     r24, r24
 602:   b9 f7           brne    .-18            ; 0x5f2 <__LOCK_REGION_LENGTH__+0x1f2>
 604:   85 e2           ldi     r24, 0x25       ; 37
 606:   90 e0           ldi     r25, 0x00       ; 0
 608:   2f ef           ldi     r18, 0xFF       ; 255
 60a:   fc 01           movw    r30, r24
 60c:   20 83           st      Z, r18
 60e:   85 e2           ldi     r24, 0x25       ; 37
 610:   90 e0           ldi     r25, 0x00       ; 0
 612:   fc 01           movw    r30, r24
 614:   10 82           st      Z, r1
 616:   85 e2           ldi     r24, 0x25       ; 37
 618:   90 e0           ldi     r25, 0x00       ; 0
 61a:   2f ef           ldi     r18, 0xFF       ; 255
 61c:   fc 01           movw    r30, r24
 61e:   20 83           st      Z, r18
 620:   8a 85           ldd     r24, Y+10       ; 0x0a
 622:   9b 85           ldd     r25, Y+11       ; 0x0b
 624:   ac 85           ldd     r26, Y+12       ; 0x0c
 626:   bd 85           ldd     r27, Y+13       ; 0x0d
 628:   9c 01           movw    r18, r24
 62a:   ad 01           movw    r20, r26
 62c:   bc 01           movw    r22, r24
 62e:   cd 01           movw    r24, r26
 630:   0e 94 aa 03     call    0x754   ; 0x754 <__addsf3>
 634:   dc 01           movw    r26, r24
 636:   cb 01           movw    r24, r22
 638:   8a 87           std     Y+10, r24       ; 0x0a
 63a:   9b 87           std     Y+11, r25       ; 0x0b
 63c:   ac 87           std     Y+12, r26       ; 0x0c
 63e:   bd 87           std     Y+13, r27       ; 0x0d
 640:   85 e2           ldi     r24, 0x25       ; 37
 642:   90 e0           ldi     r25, 0x00       ; 0
 644:   fc 01           movw    r30, r24
 646:   10 82           st      Z, r1
 648:   62 e3           ldi     r22, 0x32       ; 50
 64a:   70 e0           ldi     r23, 0x00       ; 0
 64c:   80 e0           ldi     r24, 0x00       ; 0
 64e:   90 e0           ldi     r25, 0x00       ; 0
 650:   0e 94 6d 00     call    0xda    ; 0xda <delay>
 654:   89 e2           ldi     r24, 0x29       ; 41
 656:   90 e0           ldi     r25, 0x00       ; 0
 658:   fc 01           movw    r30, r24
 65a:   80 81           ld      r24, Z
 65c:   80 95           com     r24
 65e:   88 1f           adc     r24, r24
 660:   88 27           eor     r24, r24
 662:   88 1f           adc     r24, r24
 664:   88 23           and     r24, r24
 666:   b1 f7           brne    .-20            ; 0x654 <__LOCK_REGION_LENGTH__+0x254>
 668:   89 e2           ldi     r24, 0x29       ; 41
 66a:   90 e0           ldi     r25, 0x00       ; 0
 66c:   fc 01           movw    r30, r24
 66e:   80 81           ld      r24, Z
 670:   88 1f           adc     r24, r24
 672:   88 27           eor     r24, r24
 674:   88 1f           adc     r24, r24
 676:   88 23           and     r24, r24
 678:   b9 f7           brne    .-18            ; 0x668 <__LOCK_REGION_LENGTH__+0x268>
 67a:   85 e2           ldi     r24, 0x25       ; 37
 67c:   90 e0           ldi     r25, 0x00       ; 0
 67e:   2f ef           ldi     r18, 0xFF       ; 255
 680:   fc 01           movw    r30, r24
 682:   20 83           st      Z, r18
 684:   85 e2           ldi     r24, 0x25       ; 37
 686:   90 e0           ldi     r25, 0x00       ; 0
 688:   fc 01           movw    r30, r24
 68a:   10 82           st      Z, r1
 68c:   85 e2           ldi     r24, 0x25       ; 37
 68e:   90 e0           ldi     r25, 0x00       ; 0
 690:   2f ef           ldi     r18, 0xFF       ; 255
 692:   fc 01           movw    r30, r24
 694:   20 83           st      Z, r18
 696:   8e 85           ldd     r24, Y+14       ; 0x0e
 698:   88 0f           add     r24, r24
 69a:   8e 87           std     Y+14, r24       ; 0x0e
 69c:   85 e2           ldi     r24, 0x25       ; 37
 69e:   90 e0           ldi     r25, 0x00       ; 0
 6a0:   fc 01           movw    r30, r24
 6a2:   10 82           st      Z, r1
 6a4:   2e 96           adiw    r28, 0x0e       ; 14
 6a6:   0f b6           in      r0, 0x3f        ; 63
 6a8:   f8 94           cli
 6aa:   de bf           out     0x3e, r29       ; 62
 6ac:   0f be           out     0x3f, r0        ; 63
 6ae:   cd bf           out     0x3d, r28       ; 61
 6b0:   df 91           pop     r29
 6b2:   cf 91           pop     r28
 6b4:   08 95           ret
000006b6 <main>:
void init()
        // this needs to be called before setup() or some functions won't
        // work there
        sei();
 6b6:   78 94           sei
        // on the ATmega168, timer 0 is also used for fast hardware pwm
        // (using phase-correct PWM would mean that timer 0 overflowed half as often
        // resulting in different millis() behavior on the ATmega8 and ATmega168)
#if defined(TCCR0A) && defined(WGM01)
        sbi(TCCR0A, WGM01);
 6b8:   84 b5           in      r24, 0x24       ; 36
 6ba:   82 60           ori     r24, 0x02       ; 2
 6bc:   84 bd           out     0x24, r24       ; 36
        sbi(TCCR0A, WGM00);
 6be:   84 b5           in      r24, 0x24       ; 36
 6c0:   81 60           ori     r24, 0x01       ; 1
 6c2:   84 bd           out     0x24, r24       ; 36
        // this combination is for the standard atmega8
        sbi(TCCR0, CS01);
        sbi(TCCR0, CS00);
#elif defined(TCCR0B) && defined(CS01) && defined(CS00)
        // this combination is for the standard 168/328/1280/2560
        sbi(TCCR0B, CS01);
 6c4:   85 b5           in      r24, 0x25       ; 37
 6c6:   82 60           ori     r24, 0x02       ; 2
 6c8:   85 bd           out     0x25, r24       ; 37
        sbi(TCCR0B, CS00);
 6ca:   85 b5           in      r24, 0x25       ; 37
 6cc:   81 60           ori     r24, 0x01       ; 1
 6ce:   85 bd           out     0x25, r24       ; 37
        // enable timer 0 overflow interrupt
#if defined(TIMSK) && defined(TOIE0)
        sbi(TIMSK, TOIE0);
#elif defined(TIMSK0) && defined(TOIE0)
        sbi(TIMSK0, TOIE0);
 6d0:   80 91 6e 00     lds     r24, 0x006E     ; 0x80006e <__DATA_REGION_ORIGIN__+0xe>
 6d4:   81 60           ori     r24, 0x01       ; 1
 6d6:   80 93 6e 00     sts     0x006E, r24     ; 0x80006e <__DATA_REGION_ORIGIN__+0xe>
        // this is better for motors as it ensures an even waveform
        // note, however, that fast pwm mode can achieve a frequency of up
        // 8 MHz (with a 16 MHz clock) at 50% duty cycle
#if defined(TCCR1B) && defined(CS11) && defined(CS10)
        TCCR1B = 0;
 6da:   10 92 81 00     sts     0x0081, r1      ; 0x800081 <__DATA_REGION_ORIGIN__+0x21>
        // set timer 1 prescale factor to 64
        sbi(TCCR1B, CS11);
 6de:   80 91 81 00     lds     r24, 0x0081     ; 0x800081 <__DATA_REGION_ORIGIN__+0x21>
 6e2:   82 60           ori     r24, 0x02       ; 2
 6e4:   80 93 81 00     sts     0x0081, r24     ; 0x800081 <__DATA_REGION_ORIGIN__+0x21>
#if F_CPU >= 8000000L
        sbi(TCCR1B, CS10);
 6e8:   80 91 81 00     lds     r24, 0x0081     ; 0x800081 <__DATA_REGION_ORIGIN__+0x21>
 6ec:   81 60           ori     r24, 0x01       ; 1
 6ee:   80 93 81 00     sts     0x0081, r24     ; 0x800081 <__DATA_REGION_ORIGIN__+0x21>
        sbi(TCCR1, CS10);
#endif
#endif
        // put timer 1 in 8-bit phase correct pwm mode
#if defined(TCCR1A) && defined(WGM10)
        sbi(TCCR1A, WGM10);
 6f2:   80 91 80 00     lds     r24, 0x0080     ; 0x800080 <__DATA_REGION_ORIGIN__+0x20>
 6f6:   81 60           ori     r24, 0x01       ; 1
 6f8:   80 93 80 00     sts     0x0080, r24     ; 0x800080 <__DATA_REGION_ORIGIN__+0x20>
        // set timer 2 prescale factor to 64
#if defined(TCCR2) && defined(CS22)
        sbi(TCCR2, CS22);
#elif defined(TCCR2B) && defined(CS22)
        sbi(TCCR2B, CS22);
 6fc:   80 91 b1 00     lds     r24, 0x00B1     ; 0x8000b1 <__DATA_REGION_ORIGIN__+0x51>
 700:   84 60           ori     r24, 0x04       ; 4
 702:   80 93 b1 00     sts     0x00B1, r24     ; 0x8000b1 <__DATA_REGION_ORIGIN__+0x51>
        // configure timer 2 for phase correct pwm (8-bit)
#if defined(TCCR2) && defined(WGM20)
        sbi(TCCR2, WGM20);
#elif defined(TCCR2A) && defined(WGM20)
        sbi(TCCR2A, WGM20);
 706:   80 91 b0 00     lds     r24, 0x00B0     ; 0x8000b0 <__DATA_REGION_ORIGIN__+0x50>
 70a:   81 60           ori     r24, 0x01       ; 1
 70c:   80 93 b0 00     sts     0x00B0, r24     ; 0x8000b0 <__DATA_REGION_ORIGIN__+0x50>
#endif
#if defined(ADCSRA)
        // set a2d prescaler so we are inside the desired 50-200 KHz range.
        #if F_CPU >= 16000000 // 16 MHz / 128 = 125 KHz
                sbi(ADCSRA, ADPS2);
 710:   80 91 7a 00     lds     r24, 0x007A     ; 0x80007a <__DATA_REGION_ORIGIN__+0x1a>
 714:   84 60           ori     r24, 0x04       ; 4
 716:   80 93 7a 00     sts     0x007A, r24     ; 0x80007a <__DATA_REGION_ORIGIN__+0x1a>
                sbi(ADCSRA, ADPS1);
 71a:   80 91 7a 00     lds     r24, 0x007A     ; 0x80007a <__DATA_REGION_ORIGIN__+0x1a>
 71e:   82 60           ori     r24, 0x02       ; 2
 720:   80 93 7a 00     sts     0x007A, r24     ; 0x80007a <__DATA_REGION_ORIGIN__+0x1a>
                sbi(ADCSRA, ADPS0);
 724:   80 91 7a 00     lds     r24, 0x007A     ; 0x80007a <__DATA_REGION_ORIGIN__+0x1a>
 728:   81 60           ori     r24, 0x01       ; 1
 72a:   80 93 7a 00     sts     0x007A, r24     ; 0x80007a <__DATA_REGION_ORIGIN__+0x1a>
                cbi(ADCSRA, ADPS2);
                cbi(ADCSRA, ADPS1);
                sbi(ADCSRA, ADPS0);
        #endif
        // enable a2d conversions
        sbi(ADCSRA, ADEN);
 72e:   80 91 7a 00     lds     r24, 0x007A     ; 0x80007a <__DATA_REGION_ORIGIN__+0x1a>
 732:   80 68           ori     r24, 0x80       ; 128
 734:   80 93 7a 00     sts     0x007A, r24     ; 0x80007a <__DATA_REGION_ORIGIN__+0x1a>
        // here so they can be used as normal digital i/o; they will be
        // reconnected in Serial.begin()
#if defined(UCSRB)
        UCSRB = 0;
#elif defined(UCSR0B)
        UCSR0B = 0;
 738:   10 92 c1 00     sts     0x00C1, r1      ; 0x8000c1 <__DATA_REGION_ORIGIN__+0x61>
#if defined(USBCON)
        USBDevice.attach();
#endif
        setup();
 73c:   0e 94 f1 00     call    0x1e2   ; 0x1e2 <setup>
        for (;;) {
                loop();
                if (serialEventRun) serialEventRun();
 740:   c0 e0           ldi     r28, 0x00       ; 0
 742:   d0 e0           ldi     r29, 0x00       ; 0
#endif
        setup();
        for (;;) {
                loop();
 744:   0e 94 ea 00     call    0x1d4   ; 0x1d4 <loop>
 748:   20 97           sbiw    r28, 0x00       ; 0
 74a:   e1 f3           breq    .-8             ; 0x744 <main+0x8e>
 74c:   0e 94 00 00     call    0       ; 0x0 <__vectors>
 750:   f9 cf           rjmp    .-14            ; 0x744 <main+0x8e>
00000752 <__subsf3>:
 752:   50 58           subi    r21, 0x80       ; 128
00000754 <__addsf3>:
 754:   bb 27           eor     r27, r27
 756:   aa 27           eor     r26, r26
 758:   0e 94 c1 03     call    0x782   ; 0x782 <__addsf3x>
 75c:   0c 94 2d 04     jmp     0x85a   ; 0x85a <__fp_round>
 760:   0e 94 1f 04     call    0x83e   ; 0x83e <__fp_pscA>
 764:   38 f0           brcs    .+14            ; 0x774 <__addsf3+0x20>
 766:   0e 94 26 04     call    0x84c   ; 0x84c <__fp_pscB>
 76a:   20 f0           brcs    .+8             ; 0x774 <__addsf3+0x20>
 76c:   39 f4           brne    .+14            ; 0x77c <__addsf3+0x28>
 76e:   9f 3f           cpi     r25, 0xFF       ; 255
 770:   19 f4           brne    .+6             ; 0x778 <__addsf3+0x24>
 772:   26 f4           brtc    .+8             ; 0x77c <__addsf3+0x28>
 774:   0c 94 1c 04     jmp     0x838   ; 0x838 <__fp_nan>
 778:   0e f4           brtc    .+2             ; 0x77c <__addsf3+0x28>
 77a:   e0 95           com     r30
 77c:   e7 fb           bst     r30, 7
 77e:   0c 94 16 04     jmp     0x82c   ; 0x82c <__fp_inf>
00000782 <__addsf3x>:
 782:   e9 2f           mov     r30, r25
 784:   0e 94 3e 04     call    0x87c   ; 0x87c <__fp_split3>
 788:   58 f3           brcs    .-42            ; 0x760 <__addsf3+0xc>
 78a:   ba 17           cp      r27, r26
 78c:   62 07           cpc     r22, r18
 78e:   73 07           cpc     r23, r19
 790:   84 07           cpc     r24, r20
 792:   95 07           cpc     r25, r21
 794:   20 f0           brcs    .+8             ; 0x79e <__addsf3x+0x1c>
 796:   79 f4           brne    .+30            ; 0x7b6 <__addsf3x+0x34>
 798:   a6 f5           brtc    .+104           ; 0x802 <__addsf3x+0x80>
 79a:   0c 94 60 04     jmp     0x8c0   ; 0x8c0 <__fp_zero>
 79e:   0e f4           brtc    .+2             ; 0x7a2 <__addsf3x+0x20>
 7a0:   e0 95           com     r30
 7a2:   0b 2e           mov     r0, r27
 7a4:   ba 2f           mov     r27, r26
 7a6:   a0 2d           mov     r26, r0
 7a8:   0b 01           movw    r0, r22
 7aa:   b9 01           movw    r22, r18
 7ac:   90 01           movw    r18, r0
 7ae:   0c 01           movw    r0, r24
 7b0:   ca 01           movw    r24, r20
 7b2:   a0 01           movw    r20, r0
 7b4:   11 24           eor     r1, r1
 7b6:   ff 27           eor     r31, r31
 7b8:   59 1b           sub     r21, r25
 7ba:   99 f0           breq    .+38            ; 0x7e2 <__addsf3x+0x60>
 7bc:   59 3f           cpi     r21, 0xF9       ; 249
 7be:   50 f4           brcc    .+20            ; 0x7d4 <__addsf3x+0x52>
 7c0:   50 3e           cpi     r21, 0xE0       ; 224
 7c2:   68 f1           brcs    .+90            ; 0x81e <__addsf3x+0x9c>
 7c4:   1a 16           cp      r1, r26
 7c6:   f0 40           sbci    r31, 0x00       ; 0
 7c8:   a2 2f           mov     r26, r18
 7ca:   23 2f           mov     r18, r19
 7cc:   34 2f           mov     r19, r20
 7ce:   44 27           eor     r20, r20
 7d0:   58 5f           subi    r21, 0xF8       ; 248
 7d2:   f3 cf           rjmp    .-26            ; 0x7ba <__addsf3x+0x38>
 7d4:   46 95           lsr     r20
 7d6:   37 95           ror     r19
 7d8:   27 95           ror     r18
 7da:   a7 95           ror     r26
 7dc:   f0 40           sbci    r31, 0x00       ; 0
 7de:   53 95           inc     r21
 7e0:   c9 f7           brne    .-14            ; 0x7d4 <__addsf3x+0x52>
 7e2:   7e f4           brtc    .+30            ; 0x802 <__addsf3x+0x80>
 7e4:   1f 16           cp      r1, r31
 7e6:   ba 0b           sbc     r27, r26
 7e8:   62 0b           sbc     r22, r18
 7ea:   73 0b           sbc     r23, r19
 7ec:   84 0b           sbc     r24, r20
 7ee:   ba f0           brmi    .+46            ; 0x81e <__addsf3x+0x9c>
 7f0:   91 50           subi    r25, 0x01       ; 1
 7f2:   a1 f0           breq    .+40            ; 0x81c <__addsf3x+0x9a>
 7f4:   ff 0f           add     r31, r31
 7f6:   bb 1f           adc     r27, r27
 7f8:   66 1f           adc     r22, r22
 7fa:   77 1f           adc     r23, r23
 7fc:   88 1f           adc     r24, r24
 7fe:   c2 f7           brpl    .-16            ; 0x7f0 <__addsf3x+0x6e>
 800:   0e c0           rjmp    .+28            ; 0x81e <__addsf3x+0x9c>
 802:   ba 0f           add     r27, r26
 804:   62 1f           adc     r22, r18
 806:   73 1f           adc     r23, r19
 808:   84 1f           adc     r24, r20
 80a:   48 f4           brcc    .+18            ; 0x81e <__addsf3x+0x9c>
 80c:   87 95           ror     r24
 80e:   77 95           ror     r23
 810:   67 95           ror     r22
 812:   b7 95           ror     r27
 814:   f7 95           ror     r31
 816:   9e 3f           cpi     r25, 0xFE       ; 254
 818:   08 f0           brcs    .+2             ; 0x81c <__addsf3x+0x9a>
 81a:   b0 cf           rjmp    .-160           ; 0x77c <__addsf3+0x28>
 81c:   93 95           inc     r25
 81e:   88 0f           add     r24, r24
 820:   08 f0           brcs    .+2             ; 0x824 <__addsf3x+0xa2>
 822:   99 27           eor     r25, r25
 824:   ee 0f           add     r30, r30
 826:   97 95           ror     r25
 828:   87 95           ror     r24
 82a:   08 95           ret
0000082c <__fp_inf>:
 82c:   97 f9           bld     r25, 7
 82e:   9f 67           ori     r25, 0x7F       ; 127
 830:   80 e8           ldi     r24, 0x80       ; 128
 832:   70 e0           ldi     r23, 0x00       ; 0
 834:   60 e0           ldi     r22, 0x00       ; 0
 836:   08 95           ret
00000838 <__fp_nan>:
 838:   9f ef           ldi     r25, 0xFF       ; 255
 83a:   80 ec           ldi     r24, 0xC0       ; 192
 83c:   08 95           ret
0000083e <__fp_pscA>:
 83e:   00 24           eor     r0, r0
 840:   0a 94           dec     r0
 842:   16 16           cp      r1, r22
 844:   17 06           cpc     r1, r23
 846:   18 06           cpc     r1, r24
 848:   09 06           cpc     r0, r25
 84a:   08 95           ret
0000084c <__fp_pscB>:
 84c:   00 24           eor     r0, r0
 84e:   0a 94           dec     r0
 850:   12 16           cp      r1, r18
 852:   13 06           cpc     r1, r19
 854:   14 06           cpc     r1, r20
 856:   05 06           cpc     r0, r21
 858:   08 95           ret
0000085a <__fp_round>:
 85a:   09 2e           mov     r0, r25
 85c:   03 94           inc     r0
 85e:   00 0c           add     r0, r0
 860:   11 f4           brne    .+4             ; 0x866 <__fp_round+0xc>
 862:   88 23           and     r24, r24
 864:   52 f0           brmi    .+20            ; 0x87a <__fp_round+0x20>
 866:   bb 0f           add     r27, r27
 868:   40 f4           brcc    .+16            ; 0x87a <__fp_round+0x20>
 86a:   bf 2b           or      r27, r31
 86c:   11 f4           brne    .+4             ; 0x872 <__fp_round+0x18>
 86e:   60 ff           sbrs    r22, 0
 870:   04 c0           rjmp    .+8             ; 0x87a <__fp_round+0x20>
 872:   6f 5f           subi    r22, 0xFF       ; 255
 874:   7f 4f           sbci    r23, 0xFF       ; 255
 876:   8f 4f           sbci    r24, 0xFF       ; 255
 878:   9f 4f           sbci    r25, 0xFF       ; 255
 87a:   08 95           ret
0000087c <__fp_split3>:
 87c:   57 fd           sbrc    r21, 7
 87e:   90 58           subi    r25, 0x80       ; 128
 880:   44 0f           add     r20, r20
 882:   55 1f           adc     r21, r21
 884:   59 f0           breq    .+22            ; 0x89c <__fp_splitA+0x10>
 886:   5f 3f           cpi     r21, 0xFF       ; 255
 888:   71 f0           breq    .+28            ; 0x8a6 <__fp_splitA+0x1a>
 88a:   47 95           ror     r20
0000088c <__fp_splitA>:
 88c:   88 0f           add     r24, r24
 88e:   97 fb           bst     r25, 7
 890:   99 1f           adc     r25, r25
 892:   61 f0           breq    .+24            ; 0x8ac <__fp_splitA+0x20>
 894:   9f 3f           cpi     r25, 0xFF       ; 255
 896:   79 f0           breq    .+30            ; 0x8b6 <__fp_splitA+0x2a>
 898:   87 95           ror     r24
 89a:   08 95           ret
 89c:   12 16           cp      r1, r18
 89e:   13 06           cpc     r1, r19
 8a0:   14 06           cpc     r1, r20
 8a2:   55 1f           adc     r21, r21
 8a4:   f2 cf           rjmp    .-28            ; 0x88a <__fp_split3+0xe>
 8a6:   46 95           lsr     r20
 8a8:   f1 df           rcall   .-30            ; 0x88c <__fp_splitA>
 8aa:   08 c0           rjmp    .+16            ; 0x8bc <__fp_splitA+0x30>
 8ac:   16 16           cp      r1, r22
 8ae:   17 06           cpc     r1, r23
 8b0:   18 06           cpc     r1, r24
 8b2:   99 1f           adc     r25, r25
 8b4:   f1 cf           rjmp    .-30            ; 0x898 <__fp_splitA+0xc>
 8b6:   86 95           lsr     r24
 8b8:   71 05           cpc     r23, r1
 8ba:   61 05           cpc     r22, r1
 8bc:   08 94           sec
 8be:   08 95           ret
000008c0 <__fp_zero>:
 8c0:   e8 94           clt
000008c2 <__fp_szero>:
 8c2:   bb 27           eor     r27, r27
 8c4:   66 27           eor     r22, r22
 8c6:   77 27           eor     r23, r23
 8c8:   cb 01           movw    r24, r22
 8ca:   97 f9           bld     r25, 7
 8cc:   08 95           ret
000008ce <_exit>:
 8ce:   f8 94           cli
000008d0 <__stop_program>:
 8d0:   ff cf           rjmp    .-2             ; 0x8d0 <__stop_program>
What am I missing?
I guess you are running it at 16MHz which means each cycle is 62.5ns.
Your scope is connected to pin D7 ?
There will be some latency before the pin is written to even if you use direct pin manipulation (instead of digitalWrite() for example ).
Zero clock cycles for an operation sounds somewhat optimistic.
The exact timing of ALLAVR instructions is defined in the datasheet. If you are seeing something different, then you are not measuring correctly. No instruction executes in less than one clock.
That sounds possible, actually.
It wasn't clear which code piece you were actually talking about, but the difference between if (x) and if (!x) is likely to end up being a changed conditional jump instruction, rather than an actual boolean calculation. (yes, even without optimization.)
  if (PORTB & 0x80) {
  88:	85 e2       	ldi	r24, 0x25	; 37
  8a:	90 e0       	ldi	r25, 0x00	; 0
  8c:	fc 01       	movw	r30, r24
  8e:	80 81       	ld	r24, Z
  90:	88 23       	and	r24, r24
  92:	24 f4       	brge	.+8      	; *** BRANCH if bit clear
    PORTD = 0;
  94:	8b e2       	ldi	r24, 0x2B	; 43
  96:	90 e0       	ldi	r25, 0x00	; 0
  98:	fc 01       	movw	r30, r24
  9a:	10 82       	st	Z, r1
  if (!(PORTB & 0x80)) {
  a2:	80 81       	ld	r24, Z
  a4:	88 23       	and	r24, r24
  a6:	2c f0       	brlt	.+10     	; **** Branch if bit set
    PORTD = 0xFF;
  a8:	8b e2       	ldi	r24, 0x2B	; 43
  aa:	90 e0       	ldi	r25, 0x00	; 0
  ac:	2f ef       	ldi	r18, 0xFF	; 255
  b0:	20 83       	st	Z, r18
  b2:	80 e0       	ldi	r24, 0x00	; 0
  b4:	90 e0       	ldi	r25, 0x00	; 0
  • Did you know that the Wokwi simulator simulates the hardware of a Arduino Uno and is clock accurate ?
  • Did you know that Wokwi can show the assembly code ? I'm not sure if it has to be compiled, perhaps you have to click to start simulation and then stop it. Click with the right button on the sketch, press "Command Palette F1", type "assembly" in the search field and use that command. A extra tab appears with "sketch.lst" with the assembly.
  • Did you know that Wokwi has a Logic Analyzer. The file can be analyzed with PulseView on your computer. Try your code in Wokwi with the Logic Analyzer here: https://wokwi.com/projects/335930694364562004
  • Did you know that PORTB can be used as the full 8 bit. Because when the crystal is active, PB6 and PB7 are internally disconnected. Did you know that PORTC can be used with the full 8 bit, because PC7 does not exist and PC6 is usually ignored by a fuse setting. The analog input channels ADC6 and ADC7 do exist in the chip die, but are not connected to a output pin of the chip of the DIP package. (I think you know these, otherwise you would not have written that code).
Thank you for the answers, everyone.
What was I missing: the clock period.
Due to my PIC background, I always divide the frequency by 4.
Once again, thank you!
