UNO avrdude: stk500_recv(): programmer is not responding
Hello,
I recently purchased a Genuine Arduino Uno and it stopped functioning. I’ve read through the Arduino forum postings and your troubleshooting guide. I’ve tried everything that the forum suggested but it still won’t download new code. I’ve tried installing new drivers, re-starting the computer, re-setting the UNO with the button and the reset pin, installing a new Arduino IDE app, checking the COM port, installing a new online editor on a different computer, I tried a new USB cable and several other things.
• The downloaded program is absent
• It will no longer upload new programs
• It will not reset (LED stays on rx & tx don’t blink)
When I try to download a sketch, even the blink sketch I get a message that “avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x2c”
Do you know what this can be and if there is a fix? Is it a problem with the bootloader?
Thank you for your help. I’ve included the complete error message below,
-Christopher.
./opt/arduino-builder/arduino-builder -compile -core-api-version 10611 -hardware opt/arduino-builder/hardware -hardware ./opt/cores -tools opt/arduino-builder/tools -tools ./opt/tools -built-in-libraries opt/libraries/latest -logger humantags -fqbn arduino:avr:uno -build-cache /tmp -build-path /tmp/045874616/build -verbose -prefs runtime.tools.avr-gcc.path=./opt/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs runtime.tools.avrdude.path=./opt/tools/avrdude/6.3.0-arduino14 -prefs runtime.tools.arduinoOTA.path=./opt/tools/arduinoOTA/1.2.1 -libraries /tmp/045874616/custom -libraries /tmp/045874616/pinned /tmp/045874616/Blink
Sketch uses 930 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
Programming with: Serial
Flashing with command:C:/Users/HHNSlab14/.arduino-create/arduino/avrdude/6.3.0-arduino9/bin/avrdude.exe -CC:/Users/HHNSlab14/.arduino-create/arduino/avrdude/6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:/Users/HHNSLA~1/AppData/Local/Temp/arduino-create-agent337521234/Blink.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:/Users/HHNSlab14/.arduino-create/arduino/avrdude/6.3.0-arduino9/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x2c
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x2c
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x2c
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x2c
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x2c
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x2c
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x2c
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x2c
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x2c
avrdude done. Thank you.
Executing command: exit status 1
