Ok so I am very new to the Arduino and the language. This is my first attempt at anything like this. Please be nice to me.
I am building a boost/vacuum gauge for my car utilizing an uno, a MPX5700AP for the pressure sensor, and a BMP180 to set the absolute pressure. I am following the tutorial here: tutorial
This is his code:
Reads boost from MPX4250AP on Analog 0.
Converts vacuum readings to inHg.
int mapsen = 0; // Set MAP sensor input on Analog port 0
float boost = 0; // Set boost value to 0
float mapval = 0; // Set raw map value to 0
volatile float peakboost = -30.0; // Set peak memory to low number so max displays correctly
float warnpsi = 20.5; // Set PSI for warning
float atmpsi = 13.9637; //Local atmospheric pressure
// include the library code:
#include <LiquidCrystal.h>
#include <LcdBarGraph.h>
#define REDLITE 6 //Red is connected to this Digital pin
#define GREENLITE 5 //Green is connected to this Digital pin
#define BLUELITE 3 //Blue is connected to this Digital pin
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
// you can change the overall brightness by range 0 -> 255
int brightness =255;
byte lcdNumCols = 16; // -- number of columns in the LCD
byte sensorPin = 0; // -- value for this example
//LiquidCrystal lcd(7, 8, 9, 10, 11, 12); // -- creating LCD instance
LcdBarGraph lbg(&lcd, lcdNumCols); // -- creating
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.clear();
setBacklight(100,255,0);
lcd.setCursor(4,0);
lcd.print("Welcome");
lcd.setCursor(4,1);
lcd.print("Cameron");
delay (1500);
lcd.clear();
lcd.setCursor(10,0);
lcd.print("|");
// -- draw bar graph from the analog value readed
lbg.drawValue( analogRead(sensorPin), 1024);
// -- do some delay: frequent draw may cause broken visualization
//delay(100);
mapval= analogRead(mapsen); //Reads the MAP sensor raw value on analog port 0
boost = ((((float)mapval/(float)1023+0.04)/.004)*.145)-atmpsi;
if (boost <0) //If PSI is negative, convert to inHG and display VAC instead of PSI
//boost = boost*2.036021;
lcd.setCursor(0,0);
lcd.print("VAC");
lcd.setCursor(0,0);
lcd.print("PSI");
if (boost > peakboost) //Works the MAX
peakboost = boost;
if (peakboost<-10) //Adjusts numbers over
lcd.setCursor(12,0);
lcd.print(peakboost,1);
if (peakboost>-10)
lcd.setCursor(11,0);
lcd.write(254);
if (peakboost >0)
lcd.write(254);
lcd.setCursor(13,0);
if (peakboost >=10)
if (boost<-10)
lcd.setCursor(4,0);
lcd.print(boost,1);
if (boost>-10)
lcd.setCursor(8,0);
lcd.write(254);
lcd.setCursor(4,0);
lcd.print(boost,1);
if (boost >0)
lcd.setCursor(7,0);
lcd.write(254);
lcd.setCursor(4,0);
lcd.print(boost,1);
if (boost > warnpsi) //If boost exceeds warnpsi then change backlight color
setBacklight(255,0,0);
delay(50);
void setBacklight(uint8_t r, uint8_t g, uint8_t b) {
// normalize the red LED - its brighter than the rest!
r = map(r, 0, 255, 0, 200);
g = map(g, 0, 255, 0, 255);
r = map(r, 0, 255, 0, brightness);
g = map(g, 0, 255, 0, brightness);
b = map(b, 0, 255, 0, brightness);
// common anode so invert!
r = map(r, 0, 255, 255, 0);
g = map(g, 0, 255, 255, 0);
b = map(b, 0, 255, 255, 0);
Serial.print("R = ");
Serial.print(r, DEC);
Serial.print(" G = ");
Serial.print(g, DEC);
Serial.print(" B = ");
Serial.println(b, DEC);
analogWrite(REDLITE, r);
analogWrite(GREENLITE, g);
analogWrite(BLUELITE, b);
The difference is that he isn't utilizing the BMP180 and he is using the MPX4250AP datapage while i am using the MPX5700AP datapage
Can someone help me code the BMP180 so it calibrates the absolute pressure instead of using a fixed absolute pressure which is in the code.
Also do the formulas for the pressure sensors need to be adjusted based on the transfer function formulas on the datapages?
Thanks for the help,
Mike
